Old 06-06-2013, 02:54 PM   #211
d4m45cuz
Drives: Scion FRS, Raven
Originally Posted by whitefrs View Post
Did this solve ur issue?
How did u know it was bad?
So, after 60+ miles of driving, no CEL. Seeing as I got a CEL with p0351 while leaving the dealership after my DI seal replacement (and many times subsequent), I think I can safely assume the issue has been resolved. If I had to guess, the breakdown of what causes this goes something like this:
1) Coil goes bad due to overheating (will know more once I take my old coil apart)
2) Bad coil causes overheating in the cylinder. This could be caused by a few things including misfires and/or ECU leaning the mixture in cyl #1 due to incomplete fuel burn.
3) Overheating causes premature degradation of DI seals.
I would get the p0351 codes PRIOR to the seals having gone bad and the firecrackers starting. This tells me the issue is caused by the coils having gone bad.
I have applied the JDM Transient Ignition Retard timings to my ROM via epifan's BRZedit software. Shout out to epifan for being on top of the many different ROMs out there and providing the JDM ROM to me for comparison and merging.
d4m45cuz is offline   Reply With Quote
The Following User Says Thank You to d4m45cuz For This Useful Post:
feldy (11-27-2013)
Old 06-06-2013, 03:17 PM   #212
DJCarbine
Thupercharged
DJCarbine's Avatar
Just an update, I have a direct injector seal tool coming on its way to my house. Its the same part number as posted in the previous page of the thread, I might pull my injectors just to see how well the tool works and to check my injector seals for damage
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following User Says Thank You to DJCarbine For This Useful Post:
CircuitJerk (06-06-2013)
Old 06-06-2013, 04:03 PM   #213
zc06_kisstherain
zc06_kisstherain's Avatar
Drives: SWP BRZ
Great! keep us posted!
Old 06-06-2013, 04:43 PM   #214
wootwoot
Drives: FRS
Keep us posted. Perhaps a DIY for seal replacement? I know every owner on earth would appreciate it.
Old 06-06-2013, 04:51 PM   #215
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Are you able to say where you got it and if there was a link it would be awesome.
Old 06-06-2013, 05:13 PM   #216
DJCarbine
Thupercharged
DJCarbine's Avatar
You will have to call/email these guys the part number as the tool is not listed on their website
Part# 09260-39020-01
sales@autotoolworld.com
1-877-570-6295
2013 FRS
Vortech V3 11psi
Sportsguy83 (06-06-2013)
Old 06-06-2013, 05:14 PM   #217
Sportsguy83
Drives: Limited BRZ
1-877-570-6295
Thanks for the help man!!
The Following User Says Thank You to Sportsguy83 For This Useful Post:
mad_sb (06-06-2013)
Old 06-06-2013, 05:15 PM   #218
mad_sb
Drives: 2013 Asphalt FR-S
I don't think the ecu can trim fuel per cylinder and even if it could, we only have a single up stream 02 sensor so it would not know which cylinder to trim.
If you look at the per cylinder timing compensation maps, cylinders 1 & 2 have almost 4 degrees of timing pulled out from 3600 to 4800 .7 g/rev and up and 2.5 degrees pulled from 6800 to redline.... This could cause higher EGT's on 1 & 2 i think, or pehapse it's not enough retard to increase egt's and they are limiting power on 1 & 2 due to thermal concerns??????
It is very strange that #1 coilpack seems to go bad so often and the two could certainly be linked but I don't think the coilpack issue could cause detonation, but i am assuming the mode of failure is for the plug not to fire at all or very weekly when the coil pack has issues so.... I do agree that heat could be the major cause of coil pack failure and it's possible #1 gets the least air circulation or something.
Old 06-06-2013, 05:47 PM   #219
Lonewolf
Lonewolf's Avatar
Drives: Moped
So now the latest possible way to fix this seal crap is:
1) New coils
2) Transient retards
3) Maybe new direct injectors (or seals if they haven't gone bad)
Toyota/Subaru get your sh*t together
The Following User Says Thank You to Lonewolf For This Useful Post:
wootwoot (06-06-2013)
Old 06-09-2013, 08:34 AM   #220
rx3
What's interesting about this issue, is the fact that many seals apparently did survive when people doubled the output by going FI (which is only possible with more pressure and with it temperature in the combustion chamber).
Maybe it's simply a manufacturing clearance/fitting issue (the tolerances given to the manufacturer(s) of the seals are not tight enough or the dimensions from seal to seal vary too much in the manufacturing process).
Some seals simply have a looser fitting and those seals are now showing problems, since they can transmit less heat and can move more easily.
rx3 is offline   Reply With Quote
Old 06-09-2013, 11:20 AM   #221
xjohnx
Grip>Slip
xjohnx's Avatar
Can any of you guys that have thrown the P0351 and are flashed with EcuTek check c:\Ecutek\proecu-SubaruBRZ.log (your filename may vary based on model) and do a search for P0351 to see if the code would show up when ProECU records and clears the DTCs after the flash process?
If it does, then others could check their logs to see if their cars have ever thrown it in the past (assuming they were reflashing somewhat regularly).
Astroboy (10-03-2014)
Old 06-10-2013, 01:19 AM   #222
Dezoris
Dezoris's Avatar
Got my first firecracker today being on FI. But I was 10k on NA before.
I am sure this just helped the failure accelerate.
Also interesting to note it was also the longest drive I have done since installing FI an 1 hour and 15 minutes.
Old 06-10-2013, 02:17 AM   #223
Carlysh
Carlysh's Avatar
Drives: 2007 Mazda 3, New Raven FR-S 6mt
Originally Posted by vtmike View Post
Fa20club said they have had it in their tune for a month and cars built in the last 2 months have the fix.
So your are saying if I am going to buy a Frs tomorrow it will have the fix of the popping sound just asking want to get good knowledge
Carlysh is offline   Reply With Quote
Old 06-10-2013, 08:00 AM   #224
vtmike
vtmike's Avatar
Drives: Scion FR-S
This is according to fa20club. If what they said is accurate there is still no guarantee when the car was made. Check the production date of the car you're looking to buy.
vtmike is offline   Reply With Quote
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 05:26 PM
Need Help - 2 codes thrown jpit Issues | Warranty | Recalls / TSB 3 04-20-2013 01:41 AM
Bulb codes JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 1 02-17-2013 04:25 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 06:03 PM
