Old 06-06-2013, 04:27 PM   #15
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Mosconi 6to8 looks good too.
Old 06-06-2013, 04:44 PM   #16
mid_life_crisis
Drives: FR-S 10 #103 AT
Originally Posted by Skippman View Post
The JL Audio CleanSweep seems to very VERY hit or miss.
In all fairness the Cleansweep shouldn't really be in this list. If I remember correctly, it works by reading the output of the H/U while running a test cd and setting internal equalization so that its own outputs are a nice flat signal that can then be tweaked by your crossovers and amps without having to deal with the lousy factory equalization.
It doesn't have anywhere near the power of a good processor, it's more like a deluxe output converter.
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West
Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid."
mid_life_crisis is offline   Reply With Quote
The Following User Says Thank You to mid_life_crisis For This Useful Post:
Sbeezy (06-06-2013)
Old 06-06-2013, 04:54 PM   #17
cruzinbill
Drives: Argento 6spd FR-S
Not anymore unfortunately. TOS/LINK never seemed to really catch on in car audio for reasons I've never quite understood. The Bit10D is really intended to be used with Audison's line of Voce amps. It has a digital output via RJ-45 into a special module for their amps, the Bit10 is basically the same device minus this functionality and with the controller module an optional accessory.
Knowing your budget and goals would be very helpful.
The big players in the DPS field right now are Audison, Rockford Fosgate, JBL, JL Audio, and to a very lesser extent Alpine. I've heard the Audison in person and it's a phenominal unit. I've also heard good things about the new generation of Rockfords 3sixty line. The JL Audio CleanSweep seems to very VERY hit or miss.
The 360.3 is a nice unit. I have it in the wifes car, there are few things I like about it the bitone doenst have, but theres stuff the bitone has it doesnt... for the money tho Its a good piece.
only issue with that is for the price the interface is complete garbage. I wanted to get it instead of the 360... but was so terrible using the software it turned me off instantly.
cruzinbill is offline   Reply With Quote
Old 06-06-2013, 09:01 PM   #18
Sbeezy
Drives: 2001 ZX2, WRBP BRZ (soon hopefully)
Originally Posted by GaDgeT View Post
MS-8 are awful, had 2 die on me, never could get the tuning right
I've heard this many times over especially the tuning part... no one I know has ever been able to get the stage width right or the centering dead on.
Sent from my SPH-L710 using Tapatalk 2
Sbeezy is offline   Reply With Quote
Old 06-07-2013, 02:56 AM   #19
cruzinbill
Ya they are funky to do stuff with... with trial and error you can get them to sound great, but still have limited user adjustments. If you can find one used forl like 350 its a good deal, more than that..... pass
Old 06-07-2013, 03:07 AM   #20
ft_sjo
Drives: GT86
Go for an Alpine PXA H800 with RUX controller or Audison Bit one
The two most commonly used processors in competitions around Europe. Says it all.
Old 06-07-2013, 03:11 AM   #21
BlueSTaR
BlueSTaR's Avatar
Drives: 13 BRZ Limited & 16 Hyperblue
get this for the sub box instead. http://www.jlaudio.com/product/54216....1050512.0/BRZ
BlueSTaR is offline   Reply With Quote
Old 06-07-2013, 05:30 AM   #22
cruzinbill
Originally Posted by BlueSTaR View Post
not worth the money when he can get the Integrity Concepts cheaper and its a nice piece.
Old 06-07-2013, 11:34 AM   #23
Redmist
Drives: Galaxy Blue BRZ
JBL MS-8 works perfectly for me. If you use it properly with the right equipment, it will give you audiophile quality sound a hell of a lot quicker than a BitOne, 6to8, PS8 etc. I think a lot of amateurs just like having a myriad of bells and whistles to tool around with until it sounds good to them.
Also, the MS-8's method of post-set up EQ'ing is a hell of a lot more sophisticated than the 'nuts and bolts' DSPs and means that you're more likely to improve the sound by tweaking rather than constantly messing it up.
Of course, if you're a professional audio engineer with 20 years experience and very expensive test equipment, it's possible you can do a better job than the MS-8. Also, somebody that lives and breathes car audio and spends several hours per day tuning systems could possibly beat the MS-8....maybe.
Redmist is offline   Reply With Quote
The Following 2 Users Say Thank You to Redmist For This Useful Post:
OnionTou (06-07-2013), welllam (06-08-2013)
Old 06-07-2013, 12:38 PM   #24
cruzinbill
Problem with the MS8 is T/A issues in cars with active 3 way fronts, for some reason it doesn't always process it correctly and you have to run it over and over just to get it close. While, the logic 7 portion for center control and using rears to widen the sound stage is cool, its just a pain with some cars.
I usually recommend it to someone with a factory center who is swapping radios, have them run that over the oem amp and it cleans stuff up nicely.
Old 06-07-2013, 12:49 PM   #25
mid_life_crisis
If you are contemplating setting up a processor, you might want to visit DIYMA and read this how-to thread. It sounds interesting.
http://www.diymobileaudio.com/forum/...your-ears.html
Old 06-07-2013, 08:52 PM   #26
Sbeezy
this is so far from the truth... all the guys i know that use them have 20+ years in audio and tuning plus all the tools to ensure a proper tune like RTA,MLS etc... the algorithms of the system suck plain and simple and they all run high end drivers and amps. The PS8 will whip the piss out of an MS8
Old 06-07-2013, 09:10 PM   #27
Redmist
Guys whose services are made obsolete by a product don't like that product? Shocking.
Old 06-07-2013, 09:24 PM   #28
simplicityinsound
simplicityinsound's Avatar
Drives: 2010 Subaru LGT
I have installed and tuned over 300 dsps..25 or so were ms8s. There r advantages and disadvantages of it versus a more traditional unit. I will try to elaborate more when im back from vacation.
But two things for sure.
1. Ms8 never did or will. Replace an experienced tuner in a car. It was never meant to be that.
2. Experience still counts a lot when setting up the ms8. I would not call it a dsp for someone with zero knowledge. Rather someone with good and solid fundamentals in audio can achieve decent results in as little as 10 to 15 mins.
B
Sent from my SAMSUNG-SGH-I317 using Tapatalk 2
Mobile Electronics Magazine Top 100 Installer 2012-2013
simplicityinsound is offline   Reply With Quote
The Following 4 Users Say Thank You to simplicityinsound For This Useful Post:
kmbkk (06-07-2013), Redmist (06-14-2013), rupert (06-07-2013), Sbeezy (06-07-2013)
gt 86 worth 40k!!!??? 12345qwerty Scion FR-S / Toyota 86 GT86 General Forum 29 04-13-2013 11:56 PM
Is the FR-S worth getting? DIM Scion FR-S / Toyota 86 GT86 General Forum 60 10-29-2012 12:43 AM
Is it worth it? Greaser Scion FR-S / Toyota 86 GT86 General Forum 45 08-10-2012 11:15 AM
is this worth doing denverizzles Engine, Exhaust, Transmission 7 08-03-2012 12:35 PM
What's this worth? Sport-Tech Other Vehicles & General Automotive Discussions 5 04-12-2012 11:21 AM
