Old 06-06-2013, 10:54 AM   #421
Dave-ROR
Site Moderator
Dave-ROR's Avatar
Drives: Stuff
Originally Posted by regal View Post
Has anyone had a blown injector o-ring running an oil cooler?
I'm running a cooler and have not had a failure...... Yet.
-Dave
DD: 2005 Acura TSX
Tow: 2022 F-450
Old 06-06-2013, 11:00 AM   #422
2forme
Originally Posted by HunterGreene View Post
And I would call total bullshit on them. If 7300 is the OEM redline, then the engine can function beyond that level--the engineers just designed a buffer in to keep Joe Schmo from blowing up the car the first time he mashes the accelerator.
You can call BS all you want. (To them) The odds are you won't pursue anything that effects them at a considerable scale so they have no problem essentially telling you to piss off LOL.
I'm not saying you wouldn't, but that's their thought process.
Old 06-06-2013, 11:12 AM   #423
OrbitalEllipses
Drives: Attitude
@CSG Mike I think you should start linking good/interesting posts in the OP.
eg #406, #412, #417, #421
And those are just from this page...
This is where it pays to be in a financial situation where you can go after them, simply on principle.
I have done many things that were grueling, painful, and wasteful even...because I am a principled person.
The Following 3 Users Say Thank You to OrbitalEllipses For This Useful Post:
2forme (06-06-2013), CSG Mike (06-06-2013), xjohnx (06-06-2013)
Old 06-06-2013, 11:29 AM   #424
HunterGreene
Hail Magnet
HunterGreene's Avatar
Thats where a significant amount of bitching can work wonders. If you make yourself enough of a nuisance at the dealership level, they will expend the effort to avoid you going out and badmouthing the dealership. I've had experience with this before, and no need to go after them from a legal perspective. The power of the internet and being able to claim that you'll give your story to Autoblog and Jalopnik gives the average owner a lot more power than they did 10 years ago.
TL : DR--"The squeaky wheel gets the grease"
The Following User Says Thank You to HunterGreene For This Useful Post:
2forme (06-06-2013)
Old 06-06-2013, 01:47 PM   #425
SubieNate
SubieNate's Avatar
Drives: 2013 FR-S Ultramarine
I drove over an hour back to my dealership when I had the cam sensor issue one day after I bought the car. I made it clear I was very unhappy. A month later my free 7 year 100k warranty paperwork showed up.
SubieNate is offline   Reply With Quote
The Following 2 Users Say Thank You to SubieNate For This Useful Post:
HunterGreene (06-06-2013), Marrk (06-06-2013)
Old 06-06-2013, 01:56 PM   #426
HunterGreene
Hail Magnet
Had a similar issue happen after the dealership screwed up the S/C installation on my previous car (tC). And it turned out to be well worth it when the synchros in 3rd and 2nd gear wore out around 80k miles.
Old 06-06-2013, 02:22 PM   #427
P@ul
Apostle
P@ul's Avatar
Drives: JesusMobile
Pics from teardown
Did the dealer finally perform the teardown or did you guys do it?
P@ul is offline   Reply With Quote
Old 06-06-2013, 02:35 PM   #428
xjohnx
Grip>Slip
xjohnx's Avatar
He said earlier in the thread (last Thurs/Fri maybe?) that someone other than his initial contact at Subaru authorized further teardown.
P@ul (06-11-2013)
Old 06-06-2013, 02:35 PM   #429
suaveflooder
This. Mine was over something simple. It was a stripped strut allen hole i found when i was starting to lower the car. I talked to 5 different people and all told me "no." I sent an email to the General Manager or the dealership telling him about the whole situation. That was two days ago. I am sitting in the waiting room of the dealership while they are changing that strut as i write this. Make some noise and don't stop until you reach the top and it will get done
suaveflooder is offline   Reply With Quote
The Following 2 Users Say Thank You to suaveflooder For This Useful Post:
HunterGreene (06-06-2013), whataboutbob (06-07-2013)
Old 06-06-2013, 02:43 PM   #430
SkullWorks
Drives: SSM LT MT BRZ
Originally Posted by Regal
They have the injector position so that normal driving the o-ring won't see over 500F, but keep the engine close to redline for an extended time and that o-ring doesn't stand a chance regardless of timing during a shift.
There is more to this than we are being told. We need an o-ring made from asbestos or ceramic, not Teflon or an organic polymer, any after market vendors have this on their radar?. Teflon is a very poor choice. Makes you wonder if Toyota laid off their materials engineering group during the recession ?
Or we enthusiasts need to take a serious look at our head water temperatures, I'm guessing there is a water jacket right around that o-ring in the head. A better water pump/radiator & oil cooler may be the real fix for spirited driving.
I had addressed this earlier in the thread, but I will bring it up again here.
I have several of the "other" direct injectors here at work on my desk, (we make upgraded pumps for DI motors among other DI solutions)
All gasoline direct injectors i have sampled (except the siemens provided bmw injectors) use very nearly identical injectors, all that changes is the orientation, spray pattern and mounting tabs. this goes for both the Denso and the Bosch injectors, they all use this Teflon band to seal to the head and all in the same location ours is neither closer or further away than any of the others.
Considerations not yet mentioned? perhaps the tolerances on the head are not as tight as the other manufacturers? if there is even .0003 more clearance in the diameter where this seals in the head, it could make all the difference in the world as far as heat transfer, and integrity of the seal.
Lets quit blaming the seal though, it hasn't been an issue in audi's Mazda's nissan's or chevy's yet....the problem lies elsewhere.
BTW you aren't gona find any ceramics that will stretch to get down into the relief where this seal sits.
The Following 7 Users Say Thank You to SkullWorks For This Useful Post:
Bristecom (06-06-2013), CSG Mike (06-06-2013), Hawaiian (06-07-2013), Marrk (06-06-2013), robispec (06-07-2013), Sportsguy83 (06-06-2013), Xero-Limit (06-06-2013)
Old 06-06-2013, 02:47 PM   #431
xjohnx
Grip>Slip
xjohnx's Avatar
Are you sure it hasn't been a problem in Mazda's? I've found a couple places selling upgraded seals to fix issues they've encountered, but I haven't done much research into exactly what they were seeing.
http://www.therpmstore.com/store/p/5...-3-6-CX-7.html
One of the strangest roadblocks faced was that increasing the horsepower meant increasing the cylinder pressure and as a result the load on the fuel injector seals. The fuel injector is located directly in the cylinder and every time the spark plug fires it sees a tremendous pressure spike. Working with fellow enthusiast Scott Chambers, cp-e™ is proud to introduce the solution. An injector seal that will handle the added pressure and stress of a high HP direct injected engine.
http://www.protegegarage.com/1767-fu...azdaspeed.html
or is that a different part all together?
Old 06-06-2013, 02:57 PM   #432
Bamixam
Bamixam's Avatar
Drives: SWP Subaru BRZ Limited MT
In other words root cause is heat (>450F) melting the Teflon, this is a heat soak issue first. Not an instant death by fast throttle/shifting. Just makes more sense to me.
This is a thought I've had in the back of my head for a while. Heat. The oil in this motor runs HOT. Way hotter than what I would consider to be a safe level. There is plenty of evidence of this on the Torque App thread since the PID for Oil Temp was recently discovered.
This guy saw a peak oil temp of 276F while on track running a completely stock motor.
http://www.ft86club.com/forums/showp...&postcount=309
Even just normal driving around town without any heavy throttle is producing fairly high temps.
http://www.ft86club.com/forums/showp...&postcount=181
http://www.ft86club.com/forums/showp...&postcount=182
Perrin also documented the power loss that is associated with high oil temps in this car on their blog.
http://blog.perrinperformance.com/pe...-s-oil-cooler/
In my opinion 276F (or really anything above 230F/110C) seems like it is WAY too hot for engine oil to be sitting at. After my oil cooler, I usually sit around 175F and peak around 185F during around town and freeway driving while on the track during 30 minute sessions, I usually average around 215F while peaking to 220F every once in a while.
Bamixam is offline   Reply With Quote
Old 06-06-2013, 03:09 PM   #433
CSG Mike
CSG Mike's Avatar
The teardown was authorized by the regional rep. The teardown was extensive enough that the entire engine was taken out of the car, and as you can see from the pictures, more or less have the entire engine completely apart.
P@ul (06-06-2013)
Old 06-06-2013, 03:12 PM   #434
#87
I usually post drunk
#87's Avatar
Any final word on the conclusion? i.e. who is financially responsible and why.
#87 is offline   Reply With Quote
We Ask Toyota & Subaru about James May's Claim that Toyota Gets 90% of GT 86/FR-S/BRZ vh_supra26 Scion FR-S / Toyota 86 GT86 General Forum 94 09-15-2013 09:55 PM
Denied service... Chen Northwest 37 09-13-2013 09:37 PM
HELP with diminished value claim! zohare Scion FR-S / Toyota 86 GT86 General Forum 41 04-03-2013 12:17 PM
Hit and Run Insurance Claim CharlieChaos Off-Topic Lounge [WARNING: NO POLITICS] 9 12-26-2012 09:54 PM
Japan loses its claim to "Creepiest Asian Country" reni Off-Topic Lounge [WARNING: NO POLITICS] 3 05-08-2012 12:57 AM
