Old 06-05-2013, 07:51 PM   #57
Gunman
Drives: 2019 Mazda Miata RF
Looks like the front is still outside the car by a little bit?
Old 06-05-2013, 08:02 PM   #58
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
Perhaps it needs an alignment? Very very nice sir. This is the set up that I am aiming for but I want to add some 5mm spacers to avoid the rub at full lock. Do you have the camber set to 0?
TRD_07 is offline   Reply With Quote
Old 06-05-2013, 08:41 PM   #59
loogs
Drives: on cruise control
we put 3mm spacers on it and it didnt rub but the installer was so against spacers that i decided to skip them. i havent gotten the car aligned yet and dont know what the camber is or how to check it. i might not get an alignment as im leaning towards getting coil overs sooner rather than later. thanks
BTW, the fron doesnt poke out at all. ill post a front pic soon.
loogs is offline   Reply With Quote
The Following User Says Thank You to loogs For This Useful Post:
TRD_07 (06-05-2013)
Old 06-05-2013, 08:49 PM   #60
loogs
its flush
Old 06-05-2013, 08:56 PM   #61
Gunman
Originally Posted by loogs View Post
its flush
I figured it would be, by rough number crunching, which is why I asked. Must have been a bit of shadow in that first picture.
Old 06-05-2013, 09:28 PM   #62
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
I have this exact set-up (different tires/same size) and I don't rub PERIOD on coils. I'm pretty low too. My RPF1s are orange though.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
powerj2 (03-25-2014)
Old 06-05-2013, 09:46 PM   #63
loogs
which coils?
Old 06-05-2013, 10:07 PM   #64
BlaineWasHere
Grip>Drift
Drives: FRS
which coils?
KW V3, but likely the body of any coilover is narrow enough. I'm going to add 5MM spacers anyway so I can go up to 255 and add more front camber.
Old 06-05-2013, 11:16 PM   #65
loogs
you have no issues with the tie rod on full wheel lock?
Old 06-05-2013, 11:29 PM   #66
TRD_07
TRD_07's Avatar
we put 3mm spacers on it and it didnt rub but the installer was so against spacers that i decided to skip them. i havent gotten the car aligned yet and dont know what the camber is or how to check it. i might not get an alignment as im leaning towards getting coil overs sonner rather than later. thanks
Yeah, I'm thinking about going with Koni shocks and RCE Yellow springs but not sure if that set up would clear at full lock to avoid the spacers. On another note, the coils should clear at full lock.
Old 06-05-2013, 11:41 PM   #67
BlaineWasHere
Grip>Drift
Drives: FRS
I've never seen evidence of it.
Old 06-05-2013, 11:52 PM   #68
loogs
well ive never done coilovers on my cars but it looks like im about to do it. a few questions; who makes the adjustments like ride height and firmness? what about camber? how do you know what to set that at? do you do an alignment? if so, before or after all the settings are done? will my mechanic know what to set everything at? hes a really good tuner and he has a sick EVO that he obviously did himself but, ive never spoken to him about coilovers yet. thanks in advance to anyone that answers me.
Old 06-06-2013, 09:06 AM   #69
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
set preload (if at all), ride height (though you'll get a drop from the body of the coilover being shorter than stock), put them on and get an alignment
dori. is offline   Reply With Quote
Old 06-06-2013, 10:49 AM   #70
loogs
so you set everything first and then put them on?
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 07:31 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 04:50 PM
Wheel Directory: Enkei Kojin 17x9.0 +45 Clipdat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 42 08-02-2016 05:18 PM
