Old 06-05-2013, 04:58 PM   #785
daywheniwaschillin
Any plans for a race gas map? Like 100 octane. Or would it be possible to tweak the 93 octane fuel and timing to run 100 octane?
Sent from my SCH-I545 using Tapatalk 2
daywheniwaschillin is offline   Reply With Quote
Old 06-05-2013, 07:58 PM   #786
ML
ML's Avatar
Drives: 13 White MT FR-S
having some issues, the software (v2.0) won't see the chip. Also when I log into the database to download maps, there is nothing in my account.
EDIT: got the chip remapped. Seems like the Unichip would did not like the com port it used to so I had to make a new one? weird. Any firmware or software updates available? Also I still can't see maps in my account
Old 06-06-2013, 02:41 PM   #787
ScionFrsFan
I'm pretty sure if you just have an aftermarket axle back like I do, you don't run the catb option for the tunes. The stock tune I think is fine.
ScionFrsFan is offline   Reply With Quote
Old 06-06-2013, 02:47 PM   #788
bakerr6
Drives: 2013 raven black fr-s
Pm me and I can help you later this weekend. I've run into many of the issues you are
bakerr6 is offline   Reply With Quote
Old 06-06-2013, 02:57 PM   #789
Unichip Jack
Unichip Jack's Avatar
Drives: E36 M3, Whiteout FR-S
ML - PM sent
Cheers
Unichip Jack is offline   Reply With Quote
Old 06-06-2013, 03:32 PM   #790
SloS14
SloS14's Avatar
Drives: 2013 FR-S whiteout
Originally Posted by Unichip Jack View Post
Map variances… sorry I missed this while catching up. Two maps can be “data” identical but “functionally” different while two other maps can contain very different data but be functionally identical… drawing conclusions by looking at files alone can be very misleading.
Hi, I've read read over this entire thread over the past could of days and I'm not understanding this explanation. It was a response to subiestar (who I've quoted below). Maybe there are some intricacies I don't understand with the unichip and how it handles files but it sounds like you are saying that files with identical data can result in different unichip behavior? Thanks
Originally Posted by subiestar View Post
So I was just doing a hex compare, using Beyond Compare software, on some of the maps and I found that a lot of maps in the same category are the same data wise.
for example in the 92 octane Fuel Standard Timing Out folder; the Stock, All Drop-in Filters, and All CatB maps are the same.
Jack - could you give some light on what's different between the stock maps and the All Drop-in / All CatB maps?
Old 06-06-2013, 05:43 PM   #791
Unichip Jack
Load references
SloS14… thanks for the post.
Think of a map like a spreadsheet. If a map is airflow based, one axis references airflow (the MAF for the FT86) and the other axis references engine speed. Where the Unichip goes in the map is a combination of airflow… somewhere between 0% and 100%... and engine speed…somewhere between idle and redline. We can set both the 100% and redline as desired.
Consider, for example, a “brand x” intake set up. With that intake, you’d expect the best airflow for the engine would happen with the intake, a good set of headers, and a good exhaust. We do testing and determine where to set the 100% to ensure we’re making the correct changes at the most airflow that configuration will breath.
Now consider the car with the intake but not the headers or exhaust modifications… by definition, it shouldn’t breathe as well. As a consequence, the load input (MAF) to the Unichip won’t go all the way to the 100% row… it might only get to row 9 instead of row 10 because the airflow is only 90% as much without the headers and exhaust.
Since the corrections are partially airflow based, at that 90% value the corrections are “correct” for either configuration…the difference is without the headers and exhaust modifications, that’s all the higher in the map the engine goes. With the headers and exhaust, the engine can process more air and the Unichip can make additional adjustments. Same map, same data, but the engine gets to different places depending on what it does.
That’s a bit of a simplification, but it’s an important concept because each vehicle, each intake, each headers, etc…are all slightly different so as a result on any particular car where the map actually goes will be slightly different. The Unichip correspondingly goes to a slightly different spot in the map.
Cheers
Old 06-06-2013, 07:57 PM   #792
SloS14
SloS14's Avatar
Jack - as a software developer with some tuning experience I thought you were trying to pull a fast one with the explanation for identical files but what you just said makes sense. Thanks for the reply. I'm still somewhat on the fence but so far the reviews seem overall positive. I've always had good luck making power with piggybacks.
Old 06-07-2013, 03:20 PM   #793
toro73
toro73's Avatar
Drives: 2013 scion FR-S
Whats the status on Flat Foot shifting, rev match and launch control ? pretty much all i am waiting to get the Unichip
toro73 is offline   Reply With Quote
Old 06-07-2013, 05:54 PM   #794
Unichip Jack
toro73... thanks for the post.
Give Tony at Unichip Wholesale a call and he'll be able to help you.
Cheers
Old 06-08-2013, 01:18 AM   #795
jeffchap
jeffchap's Avatar
Drives: 2013 Scion FR-S Raven 6MT
Got my Unichip Q today, and the install went fine until I got to the part about selecting the map. Apparently, I did not purchase the 2 position switch. All I got is the unit itself and the wiring harness.
The installation instructions read:
a. Connect the Map 0/1 Switch black 2-pin Molex plug to the StS's 2 pin Comm connector
b. Position the Map 0/1 Switch Loom as desired
So here's what I've got, a 2 pin connector and a 6 pin connection on the StS with 3 different positions that it can be plugged into:
I plugged it into the middle position, as you see here. My question is, how do I select between the 2 maps? Move the connector to one of the other positions? And if so, which one is which? Or must I also purchase the optional switch in order to change maps? And if I'm limited to only one without the switch, which one is it?
This is the only problem I encountered -- the rest of the install went really smoothly, except getting to a couple of those connectors would be a real bitch if you had large hands.
As for performance, the torque dip is noticeably smoothed out. Of that I'm certain. However, whether that's the result of the valley being shallower or the peaks being lower, I can't really say for certain with just the ol' butt dyno. I've only had the car 2 weeks and haven't really spent enough time with it to be able to say for certain. Plus it only has 750 miles on it, so I'm still not pushing it very hard.
I will say that I took off from a dead stop on dry pavement a couple of times after the install, and the traction control flashed at me. I've never seen that before, so I have to assume that it's generating a little more power, resulting in breaking the tires loose more than it used to.
Stay squatchy, my friends
jeffchap is offline   Reply With Quote
Old 06-08-2013, 06:53 AM   #796
Lytheum
Drives: 2013 BRZ Premium 6MT
Did you buy it used? It should come with the switch. I think I read somewhere it will default to the first map if there is an issue?
Speaking of switching maps. Is there any benefit to resetting the ecu when trying different maps?
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 06-08-2013, 07:36 AM   #797
jeffchap
jeffchap's Avatar
No, I bought it directly from Unichip. It was the 'slightly used' model from their Garage Sale for $100 off. It had a packing list, and everything on the list was there, but no switch was listed.
If I can switch it somehow by moving the connector, that's no big deal. I don't see myself doing it very often. But I just have no idea which position is which, or if that's even how to do it.
Old 06-08-2013, 08:58 AM   #798
KVDB31
KVDB31's Avatar
Drives: 2013 FR-S Asphault
@jeffchap I agree with the last guy, it should be in your kit. I bought the Flux2, so I have an extra one if you'd like to buy one on the cheap! PM me if you're interested.
TSW Nurburgring 18x8, BFG Comp-2 235/40, KW V3's w/ Vorshlags, ECUTek by Evasive, Injen intake, FT86 Header, Motiv OP/DP, Nameless Axleback, 4.88 Weir gears, Subaru Legacy GT brakes, Five Axis spoiler, Shark Fin, 3000k HID's, LED goodies
KVDB31 is offline   Reply With Quote
The Following User Says Thank You to KVDB31 For This Useful Post:
jeffchap (06-08-2013)
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 02:37 PM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 03:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-03-2013 11:05 PM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 05:31 PM
