Old 06-05-2013, 02:37 PM   #1
Racecomp Engineering
RCE Tarmac 2 CLUBSPORT and RCE Tarmac 0 coilovers available now
Racecomp Engineering has paired with the renowned suspension manufacturer KW Suspensions to bring new and truly customized coilover options to market for the Subaru BRZ and Scion FR-S.
Racecomp Engineering and KW Suspensions have been working together since 2006 to produce the RCE Tarmac line of coilovers for Subaru Impreza and Legacy, claiming an SCCA STU National Championship in a Subaru STI equipped with RCE Tarmac 2 coilovers.
Following an 8 month research and development process that included extensive track testing and over 10,000 test miles on multiple vehicles, Racecomp Engineering is proud to release the Tarmac 2 Clubsport and Tarmac 0 coilover systems for the exciting new sports car platform from Subaru and Toyota. Both options are available now.
________________________________________________
RCE Tarmac 2 Clubsport coilovers were developed as a track focused system for both club racers and weekend warriors alike. Based on KW Clubsport coilovers, the valving profiles and spring rates have been modified with cooperation from KW Suspensions from their standard specifications to increase the potential of the Subaru BRZ and Scion FR-S on real world American roads and tracks. Refined damping results in a sharper reacting and yet more stable vehicle over bumps. Excellent valving and ample bump travel means mid-corner bumps at the track will not upset the chassis and the ride around town is kept civil.
Featuring separate compression and rebound adjustments, the system can be fine-tuned to a driver’s preference or changing track conditions. The result is a coilover that improves grip, builds driver confidence, and lowers lap times.
RCE Tarmac 2 Clubsport coilovers come standard with 400 lbs/in springs front and rear, with optional 500 lbs/in and 600 lbs/in configurations available. These coilovers feature KW’s stainless steel INOX coating for excellent protection against the elements and include a limited LIFETIME warranty.
* Two adjustable damping (separate compression and rebound adjustments)
* Ride height adjustable with a shortened shock body for plenty of bump and droop travel
* Stainless steel INOX coated.
* Track focused 400/400 lbs/in spring rates (7 kg/mm).
* Optional 500/500 and 600/600 rates available.
* Limited LIFETIME warranty
The Following 6 Users Say Thank You to Racecomp Engineering For This Useful Post:
ATL BRZ (06-05-2013), chanomatik (06-12-2013), ill86 (07-12-2013), OjiGeorge (06-06-2013), RYU (06-06-2013), ZetaVI (06-05-2013)
Old 06-05-2013, 02:37 PM   #2
RCE Tarmac 0 coilovers utilize the knowledge gained in the RCE Tarmac development process to bring an affordable and comfortable sporting coilover option to the Subaru BRZ and Scion FR-S aftermarket.
Damping is pre-set with an emphasis on a sporty yet comfortable ride that is at home on the street, in the canyons, at the local autocross, or at the track. Combined with stock top mounts, this is a quiet “set it and forget it” coilover option that lets a user dial in their preferred ride height and get down to driving and enjoying their ride.
RCE Tarmac 0 Clubsport coilovers come standard with 280 lbs/in springs front and rear, with optional spring rates available up to 350 lbs/in. These coilovers feature KW’s stainless steel INOX coating for excellent protection against the elements and include a limited LIFETIME warranty.
* Preset damping
* Comfortable sport derived 280/280 spring rates.
* Optional 350/350lb rates available.
The Following 5 Users Say Thank You to Racecomp Engineering For This Useful Post:
ATL BRZ (06-05-2013), chanomatik (06-12-2013), ill86 (07-12-2013), Mgivens (06-05-2013), RYU (06-06-2013)
Old 06-05-2013, 02:37 PM   #3
space saved for dynos....
Old 06-05-2013, 02:43 PM   #4
These are available now, please PM for pricing info (I won't post it here). There will be a separate vendor thread soon.
Glad to answer tech questions in this thread.
We are really excited about both of these options and have been working on them hard for the last 8 months. We took our time and are very happy with the result.
- Andy
Old 06-05-2013, 03:13 PM   #5
FT-86 SpeedFactory
FT-86 SpeedFactory's Avatar
Looking good guys!! We just got our stock in of the Tarmac 2 Clubsports, as well.
We just got photos taken of them Pretty sure a set will have to end up on one of our cars........
FT-86 SpeedFactory is offline   Reply With Quote
The Following 4 Users Say Thank You to FT-86 SpeedFactory For This Useful Post:
ATL BRZ (06-05-2013), Mgivens (06-05-2013), Racecomp Engineering (06-05-2013), Sportsguy83 (06-05-2013)
Old 06-05-2013, 03:30 PM   #6
ATL BRZ
TEQSPORT Brand Manager
ATL BRZ's Avatar
Drives: '24 GR86 + '16 FR-S
Congrats guys, these are BEAUTIFUL!
I don't know why anyone would shop elsewhere for quality coilovers that are designed and tested specifically for these cars!
All street, all track, or street/track dual use builds; RCE has everyone covered with these!
The Following 2 Users Say Thank You to ATL BRZ For This Useful Post:
Old 06-05-2013, 03:38 PM   #7
ZetaVI
Gundam Meister
ZetaVI's Avatar
Drives: A Gundam
RCE and Suspension. Works like a charm.
The Following User Says Thank You to ZetaVI For This Useful Post:
Old 06-05-2013, 03:44 PM   #8
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Yep, this ones are destiny for me. Been waiting and waiting to get a suspension. Was set on RCE yellows, then started looking at other brands coilovers, was SET to get them last week and this one come in the radar.
I will order this week the Tarmac 0's. Bart Scott's voice: " CANT WAIT!".
The Following User Says Thank You to Sportsguy83 For This Useful Post:
Old 06-05-2013, 03:45 PM   #9
UnOvertime
UnOvertime's Avatar
Drives: Firestorm FR-S AT
Can't wait for my Tarmac 0's to come in, should be here tomorrow and installed this weekend!
UnOvertime is offline   Reply With Quote
The Following 2 Users Say Thank You to UnOvertime For This Useful Post:
Racecomp Engineering (06-05-2013), tg_1981 (06-09-2013)
Old 06-05-2013, 03:50 PM   #10
Thanks guys! Awesome reading stuff like this...makes us proud to be a part of this community. We've been around since 2003 as RCE and hearing positive stuff like this is a great reminder of why we do it.
And thanks FT86 speedfactory! One of our great dealers that knows their way around an FT86!
- andy
The Following 4 Users Say Thank You to Racecomp Engineering For This Useful Post:
forwallblakmail (07-30-2013), FT-86 SpeedFactory (06-05-2013), RYU (06-06-2013), Sportsguy83 (06-05-2013)
Old 06-05-2013, 04:11 PM   #11
MAKE SURE YOU GUYS USE the GD CHASSIS OEM CONICAL WASHER on the fronts. These go BETWEEN the top PERCH and the mount( OEM, Group-n or COM-C).
[IMG][/IMG]
ATL BRZ (06-05-2013), OjiGeorge (06-06-2013), Sportsguy83 (06-05-2013), whataboutbob (06-06-2013)
Old 06-05-2013, 04:16 PM   #12
Sportsguy83
Drives: Limited BRZ
GREAT to know! Thanks!
Nothing else needed? I will be using OEM tops.
Old 06-05-2013, 04:26 PM   #13
hanabie
hanabie's Avatar
Drives: WRB LMTD '13
tamrac 0, 4k front and 5k rear? how much can I lower my car with tamrac 0?
hanabie is offline   Reply With Quote
Old 06-05-2013, 04:34 PM   #14
Clipdat
Proud of BOXER
Clipdat's Avatar
Drives: Subaru Boxer
Was going to just get some RCE Yellow springs with the stock struts, but the Tarmac 0s look like an even better option...
Originally Posted by humfrz
I'm old and lazy
Racecomp Tarmac II Clubsport coilover JoeBoxer Suspension | Chassis | Brakes -- Sponsored by 949 Racing 47 11-17-2013 12:02 AM
Tarmac Zero Coilovers Specs? tintumz22 Suspension | Chassis | Brakes -- Sponsored by 949 Racing 18 06-14-2013 12:26 AM
KW CLUBSPORT COILOVERS W/ FREE SHIPPING FOR THE SCION FR-S/SUBARU BRZ!!! NJA Brakes, Suspension, Chassis 7 03-30-2013 09:26 PM
Wheel Directory: Enkei ES-Tarmac 16x7.0 +45 quik1987 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1 09-12-2012 01:24 PM
Toyota 86 Tears Up Tarmac at 2012 TAS (TRD, N1, HKS, Up Garage Models) + LFA Roadster knoxviue FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 35 01-20-2012 02:44 AM
