Old 06-05-2013, 03:18 PM   #1
brunofrs
Drives: frs white tri-coat
Wheel Directory: Work VS-XX 18x9.0 +33 / 18x10.0 +33
Hi guys!
Recently, i have find a set of work vs-xx in 5x100 (18x10 +33, 18x9 +21) , I thought the wheels would not go and would rub on the body but surprise ... all is okay. Here are some pictures but i will post more soon..
brunofrs is offline   Reply With Quote
The Following 5 Users Say Thank You to brunofrs For This Useful Post:
Egyptn (11-04-2013), flippy (06-05-2013), Hindi (06-05-2013), R2RO (06-06-2013), VIXEN (06-05-2013)
Old 06-05-2013, 03:23 PM   #2
dabocx
dabocx's Avatar
Drives: Scion FRS
What tire size? And MOAR PHOTOS!
dabocx is offline   Reply With Quote
Old 06-05-2013, 03:27 PM   #3
supragoods
Drives: Ravenfire
so classy (nods head) is that stock height?
supragoods is offline   Reply With Quote
Old 06-05-2013, 03:37 PM   #4
brunofrs
no its on bc rancing coilovers but im not slammed lol..
Old 06-05-2013, 03:37 PM   #5
brunofrs
225/40/18 all around
Old 06-05-2013, 04:07 PM   #6
mav1178
mav1178's Avatar
Drives: 2005 Toyota Camry
I'm not sure those offsets are correct... the VS-XX is a 3-piece wheel and the offsets can't change from what is offered.
And those offsets (on the car, as-listed) are not offered.
What offset are they?
http://www.workwheelsusa.com/media/w...-XX%20Spec.pdf
-alex
diss7 (06-05-2013)
Old 06-05-2013, 04:25 PM   #7
Drftfan
Drives: Argento FR-S
Sick
Drftfan is offline   Reply With Quote
Old 06-05-2013, 09:38 PM   #8
nab335
nab335's Avatar
Drives: e92 335i, FRS, Lexus ls400
looks really nice! and its not rubbing because your not low enough..haha
IG: nabb335
nab335 is offline   Reply With Quote
Old 06-05-2013, 10:13 PM   #9
mav1178
mav1178's Avatar
Would really help the community if correct offset info was posted...
-alex
Old 06-06-2013, 01:16 AM   #10
brunofrs
oups sorry ...corection: 18x9+21, 10+33 .. maybe different offset beacause the step lips... idk..
Old 06-06-2013, 01:30 AM   #11
diss7
Drives: AE86, 2x GT86, TE27
Originally Posted by brunofrs View Post
oups sorry ...corection: 18x9+22, 10+28
I don't see those offsets in those sizes in the Works Catalouge, in either of the 3 centre disk options. Unless I'm blind..
diss7 is offline   Reply With Quote
Old 06-06-2013, 01:52 AM   #12
brunofrs
yess but look at vrmotoring.com and you can see many set have not the offset in work catalogue... maybe a special order idk...
Old 06-06-2013, 09:08 AM   #13
dori.
Señor Member
dori.'s Avatar
Drives: white BRZ 6MT
-alex
could be special order man
dori. is offline   Reply With Quote
Old 06-06-2013, 01:40 PM   #14
mav1178
mav1178's Avatar
You can't customize special order 3-piece wheels that go beyond what the manufacturer offers.
There's only 3 parts to a 3-piece wheel: inner barrel, outer barrel, and center disk.
The center disk is always of a fixed design, usually R-disk, A-disk, or O-disk for different caliper clearance.
The inner/outer barrel is also of a fixed design in the sense that when pieced together, they create the width of the wheel.
So given those 3 fixed parameters, you do not have "custom" offsets available... to be honest, every multi-piece wheel anyone will ever order will always be custom because they are made to the order.
I really suggest you (or anyone else researching) to actually look at the link I posted. You CANNOT order a Work VS-XX beyond what is listed in the PDF... unless you shave the backpad of the wheel 2-3mm to get more offset. But, Work won't do this for you since it won't meet their safety compliance in Japan.
-alex
diss7 (06-06-2013)
Wheel Directory: Work VS-XX 18x9.0 +34/18x9.5 +39 mav1178 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-13-2014 05:09 AM
Wheel Directory: Work Meister S1R 18x9.5 +25 ebphoto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 158 06-09-2014 06:29 PM
Wheel Directory: Work Meister S1R 18x9.0 +35 diss7 Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 01-02-2014 02:05 AM
Wheel Directory: Work Emotion 11R 18x8.5 +45 / 18x9.5 +38 DR1FT Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-04-2013 02:16 PM
Wheel Directory: Work Emotion 11R 18x9.5 +30 autofashionfred Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 08-11-2012 02:39 AM
