Old 06-04-2013, 06:52 PM   #1
francosolracer
francosolracer's Avatar
Drives: 13'FRS,10 TC(trad),09'370z(totaled)
Carbon fiber lifetime?
How long a CF hood is going to last just with the gloss finish or how to take care
Sent from my SAMSUNG-SGH-I727 using Tapatalk 2
francosolracer is offline   Reply With Quote
Old 06-04-2013, 06:56 PM   #2
OrbitalEllipses
Drives: Attitude
Depends on if the clearcoat has any UV protection. 1-3 years before it starts yellowing if not, depending on overall quality.
Buy junk, get junk.
Old 06-04-2013, 06:58 PM   #3
francosolracer
Getting Seibon TS stile
Old 06-05-2013, 03:17 PM   #4
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
Drives: '13 Whiteout FRS
I heard the stock hood is almost as light as the carbon fiber anyways..or are you doing it for looks?
CAMBAM_6 is offline   Reply With Quote
Old 06-05-2013, 03:30 PM   #5
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
I believe it's lighter. The STI hood is Aluminum and CF hoods are the same weight +/- 2 lbs. The BRZ hood is appreciably lighter than the STI hood.
And to add further evidence, Robispec's track rat uses a louvered stock hood because it was lighter than the CF hoods they looked into.
The Following User Says Thank You to Draco-REX For This Useful Post:
CAMBAM_6 (06-05-2013)
Old 06-05-2013, 04:12 PM   #6
CAMBAM_6
CAMBAM
CAMBAM_6's Avatar
So basically unless your doing it for looks or you find one with vents for engine cooling purposes your wasting your money OP
The Following User Says Thank You to CAMBAM_6 For This Useful Post:
SkAsphalt (06-06-2013)
Old 06-05-2013, 04:41 PM   #7
DeeezNuuuts83
Drives: 2006 Evo IX SE
Plus there is always the issue of it fitting properly. It's not worth it, and for a carbon fiber hood that will last and fit like it should, it will be pretty expensive. I'd know, I have a fairly uncommon but genuine carbon fiber trunk on my Evo IX, and brand new, they aren't cheap.
DeeezNuuuts83 is offline   Reply With Quote
Old 06-05-2013, 04:53 PM   #8
Hanakuso
It all depends on who and how the CF hood makes it. Some will be heavier and some will be lighter. You can't just lump all CF hoods in one.
If you want OEM quality/fitment and lightweight then it will cost a lot.
Hanakuso is offline   Reply With Quote
The Following 2 Users Say Thank You to Hanakuso For This Useful Post:
Hawk77FT (06-20-2013), Mickeyt86 (06-05-2013)
Old 06-05-2013, 04:54 PM   #9
DeeezNuuuts83
Regardless, the weight savings likely isn't going to be anything significant over a stock aluminum hood and not exactly worth the money or the hassle.
Old 06-05-2013, 05:13 PM   #10
Hanakuso
That should be obvious. Replacing any of the stock exterior panels with the main purpose to save weight is an expensive route.
Old 06-05-2013, 11:19 PM   #11
hypermax
hypermax's Avatar
Drives: BRZ Limited
actually, our hood is lighter than the oem style hood
hypermax is offline   Reply With Quote
Old 06-06-2013, 03:12 AM   #12
ichitaka05
Site Moderator
ichitaka05's Avatar
Drives: ichi 86 Project
If you wanna shave weight go this route
Rear seats bases - 6.2 lbs
Rear seat back - 15 lbs
Spare tire w liner foam - 25.8 lbs
Front floor mat - 2.4 lbs
Rear floor mat - 0.8 lbs
Trunk tool, jack, tow hook - 5.8 lbs
Trunk rug/liner mat - 2.4 lbs
Total shaved 58.4 lbs for free
cdo221 (06-06-2013)
Old 06-06-2013, 06:54 AM   #13
YDNA
YDNA's Avatar
Drives: Raven FR-S
if you really want to lose weight
use 3 lugs on everywheel
take out emblems
take out floor mats
take out radio and speakers and buy a boom box or you a portable cd player with head phones
lose weight
take out abs
start eating subway
you might lose 2lbs-30 lbs
YDNA is offline   Reply With Quote
Old 06-06-2013, 11:43 AM   #14
DeeezNuuuts83
Unless you're drag racing, im not sure how beneficial it would be when that lost weight is going to lighten up the load on the rear axle and make the weight distribution favor the front end a little more. Not by a lot, but it's still something to consider.
The Following User Says Thank You to DeeezNuuuts83 For This Useful Post:
chenshuo (06-18-2013)
Carbon Fiber Mirrors - Shark fin Antenna - Carbon Fiber Accessories-PRICES LISTED!!! F-T Exterior Parts - The Rest 285 08-24-2015 05:42 PM
Vis racing ams carbon fiber trunk and Seibon carbon fiber diffuser Mr.Frs Cosmetic Modification (Interior/Exterior/Lighting) 36 04-08-2015 11:51 AM
Carbon Fiber dash like a BMW? (pictures of M3 carbon fiber interior included) master345 Cosmetic Modification (Interior/Exterior/Lighting) 56 05-04-2014 12:10 PM
VIS Carbon Fiber Tansey86 Cosmetic Modification (Interior/Exterior/Lighting) 8 04-12-2013 11:54 PM
APR Carbon Fiber Lip Kit now available! ShowstoppersUSA Exterior Parts - The Rest 22 04-09-2013 07:42 PM
