Drives: BRZ Ltd WRB
Trunk will not open
My trunk won't open either from the remote or the button inside the car. I have to fold the backseats and open it from the inside. Anyone else experienced this problem? I will drop by Subaru when I get time for them to have a look at it.
Enkei RPF1/K&N/Perrin crank pulley/Visconti Stg1/Perrin catback and overpipe/KW V3
#2 |
PROUD OF BOXER
Drives: Raven FR-S
Sounds like a simple relay. I doubt it will be a common problem with many people
#3 |
Drives: 2013 Scion FR-S Raven
Open the trunk. Look to the left corner inside the trunk, there's a button. Push it , try again.
| The Following 3 Users Say Thank You to DatDudeLoso For This Useful Post: |
#5 |
Drives: 2013 FR-S Argento
and in case this happens again, there is a key cylinder on the trunk as well, its just not out there in the open for everyone to see, its actually located underneath the little garnish piece where a trunk release button SHOULD be, you'll see it, its more on the right side.
| The Following 2 Users Say Thank You to JRoldy For This Useful Post: | BAE (06-04-2013), DatDudeLoso (06-04-2013) |
#6 |
Keep Calm And Drift On~
Drives: Scion FR-S WhiteOut 6 Speed Manual
Yep , this problem is usually caused by shifting objects in the trunk hitting the button on the left.
It's pretty exposed button. If you can open it via the convenient means , use the trunk cylinder with your key to manually open it and then press the button . Check for correct operation and you should be good to go! Side note, my dealer actually took the time to point out this issue ... Stay Frosty my friends~ |
| The Following User Says Thank You to Wo6M For This Useful Post: | BAE (06-04-2013) |
#7 |
Drives: BRZ Ltd WRB
![]() It worked after I pushed the button. I also found the key cylinder for the trunk and found out there is actually a key inside my remote. Thanks a lot guys! Saved me a trip to the dealer.
#8 |
Your welcome! That's what the community is here for !
Feel free to ask any future concerns as we would all help you out. Stay Frosty ~ |
#9 |
Drives: BRZ(sold), STI
Next time look through the stickies.
#10 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Search pretty much reeks here.
I did an advanced search for "VIN". It came back with "Sorry, no items. You suck at search."
"I gotta rock." -- Charley Brown |
#11 | |
Waited 5 years for this
Drives: '18 MX-5 Club
BTW, you could just use the key to open the trunk also instead of crawling through the folded backseats. |
#12 |
Drives: BRZ Ltd WRB
I found out about the key today. I am folding the backseats by pulling the bands that sticks out on each side of the seats.
| The Following User Says Thank You to BAE For This Useful Post: | Sigh-on-Rice (06-04-2013) |
#13 |
Drives: 2013 FR-S Ultramarine
There are slots for the bands to be pulled through so you can open it from inside the car.
| The Following User Says Thank You to SubieNate For This Useful Post: | Sigh-on-Rice (06-04-2013) |
#14 | ||
![]() That kind of defeats the whole purpose of that little button in the trunk to disable the trunk release though because people can still access the trunk from inside of the car. I don't know what that button is for now.
| Trunk won't pop open | Reflex | Issues | Warranty | Recalls / TSB | 36 | 01-02-2021 04:16 PM |
| Trunk will not open | Hbomb | Issues | Warranty | Recalls / TSB | 33 | 06-12-2017 07:56 AM |
| WTT: Satin White Pearl BRZ Limited Trunk with Spoiler for Wingless Trunk | R0ME0 | Exterior Parts (Aero, Lighting, Etc.) | 3 | 01-07-2014 10:36 PM |
| Anyone else hit a bump and the trunk popped open? | retrosmiths | Issues | Warranty | Recalls / TSB | 7 | 05-30-2013 09:43 AM |
| Trunk won't open | Sparda29 | Issues | Warranty | Recalls / TSB | 13 | 01-11-2013 12:10 PM |
