#85 |
Looks like a few guys have too much time on there hands and all they can do is think about me
![]() Anyways this car was doing pretty good on lower boost when we raised the boost we started to get a misfire in the high rpms. Then we started to see a lean condition so we stopped and pulled the pump out. We saw some issues with the pump install and fixed them and started back on the Dyno.. Problems continued... Then did some quick port and direct injection testing.. Car ran very smooth on 100% port injection but would instantly breakup on 100% direct injection. Direct injection Fuel pressure seems fine , so we're going to change the seals. At no point have I left my customer hanging. We came up with a game plan before he left and have talked over the weekend. I find it hilarious that a few of you jump to conclusions so quickly John |
| The Following 2 Users Say Thank You to Visconti For This Useful Post: | Onealpha (05-30-2013), Sportsguy83 (05-29-2013) |
#86 |
I Love custom Turbo kits
Drives: Limited BRZ
Yeah, its impossible to keep everyone happy. In one thread, FRS300 and FA20CLUB were made fun off because it seemed all their communication was through the forum (it wasn't, but that's what users assume). Now on this thread, members assume again the only way of communication between OP and Visconti is through the forum and they are killed because they "think" its lacking.... Ever stop to think that maybe just maybe, OP/Visconti and FRS300/FA20CLUB communicate outside of the forums?? Funny indeed..
#87 |
Drives: Sonic Blue 86GT Manual
I like turtles
| The Following User Says Thank You to Blue86 For This Useful Post: | jamesm (06-03-2013) |
#88 |
Love Boost!!!!!!!!
Drives: Whiteout Scion FR-S
pic of my Bank 1 Sensor 1 and 2
to me it seems good but they are going replace the whole injector Sensor 1
| The Following User Says Thank You to whitefrs For This Useful Post: | Sportsguy83 (06-03-2013) |
#89 |
Drives: Limited BRZ
IMHO (and I'm no expert at all, take with huge grain of salt) The O ring looks out of place in the bottom one and the teflon seal looks out of place in the top one, specially considering the installation instructions are very specific of keeping the teflon one very straight.
#90 |
Who replaced it?
INSTAGRAM @Rcf_700 www.youtube.com/boostindub
| The Following User Says Thank You to charged86 For This Useful Post: | whitefrs (06-03-2013) |
#91 | |
Love Boost!!!!!!!!
#92 |
Love Boost!!!!!!!!
#93 | |
Drives: 2013 Asphalt FR-S
To me the top injector in the picture looks like it is on a cylinder that is not getting enough fuel.. the bottom one looks like normal carbon deposits... if the carbon extended past the teflon seal, then i would for sure think seal failure. JV said the rail pressure looked good so that sort of rules out the DI pump and spill valve, so could be: * DI driver box (but i think a code would be thrown for that) * Coil pack * Plug problem (gap too wide one one or more cylinders if the issue only happens at higher boost) I will leave out the worst case scenario until the other are checked / problem is resolved ![]() While working on the injectors, I would go ahead and replace all the plugs with a fresh, equally gaped set and closely inspect the ones that come out for signs of detonation.
~Namaste~ |
| The Following 2 Users Say Thank You to mad_sb For This Useful Post: | No Limit Motorsport (06-04-2013), Sportsguy83 (06-03-2013) |
#94 | |
Love Boost!!!!!!!!
#95 |
Ok, well, i hope replacing the injector fixes it, but i really don't think you have seal failure so if it were me I would be looking at other causes. P117B points to a DI side fuel supply issue. Reading the plugs, and the injector tips, should help determine if it is isolated to 1 cylinder. And ALL injectors are considered "bank 1" (only 1 upstream 02 sensor) on this engine so i'm curious why you guys only pulled 2 injectors...
~Namaste~ |
#96 | |
Love Boost!!!!!!!!
Should i ask him to pull the other 2
#97 | |
Love Boost!!!!!!!!
#98 | |
Checking the plugs should help you determine the over all health of the motor as will checking all the injectors for seal integrity and injector tips for coloration etc. My guess is if you have a bad injector it will be obvious when you compare the plug and injector to the other 3. One failed injector would be enough to max out the fuel trims since the others would have to compensate to maintain an average target afr in closed loop. If all 4 are fairly uniform then you can start looking at something else like the DI driver box. The thing is, those two codes together would indicate the Di system was not putting out enough fuel under closed loop DI only operation (which means low load on a boosted car) and even with the fuel trims maxed out the front 02 sensor was still seeing a lean condition.... Without seeing some logs all i have to go on is what JV said (ran fine on port only mode) and the rail pressure looked normal.. so that only leaves a few things... bad injector, bad injector driver box, clogged injector etc... I do think you would have a code if the injector driver box has an issue though. When you ran into the issues at higher boost, did it still run good if you dropped the boost back down?
~Namaste~ |
| Injector / seal failure or Miss-fire codes.. please post here | mad_sb | Engine, Exhaust, Transmission | 378 | 04-24-2020 07:33 PM |
| Direct Injector Leaking | Carwhisperer | Issues | Warranty | Recalls / TSB | 356 | 03-13-2020 01:35 PM |
| FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 05:26 PM |
| Brake fluid leaking from pistons/seals normal? | Hanakuso | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 7 | 12-06-2012 03:54 PM |
| Bad window seals? | Dzeremijs | Issues | Warranty | Recalls / TSB | 18 | 10-26-2012 04:24 PM |
