Old 06-01-2013, 02:31 PM   #1905
Spidey
Spidey's Avatar
Drives: 2013 FR-S, '85 Corolla GT-S Hatch
Perrin master cylinder brace.
Spidey is offline   Reply With Quote
Old 06-01-2013, 02:49 PM   #1906
FRSTRM
Baby LFA
FRSTRM's Avatar
Drives: Baby LFA
Originally Posted by Retro86 View Post
popped some caps
Where'd you get them? I'd rather not throw $90 on them.
FRSTRM is offline   Reply With Quote
Old 06-01-2013, 04:52 PM   #1907
BadMoon
BadMoon's Avatar
Drives: 2014 GLI Autobahn/Nav
Clay bar and wax treatment. Wife and kids are gone for the weekend. So soon I will be going out for a steak dinner.
Me jokingly "duck facing" in the hood.
BadMoon is offline   Reply With Quote
Old 06-01-2013, 04:57 PM   #1908
BadMoon
BadMoon's Avatar
popped some caps
Yup where can we buy?
Old 06-01-2013, 05:28 PM   #1909
Narcoden
Narcoden's Avatar
Drives: '13 Ultramarine FR-S
Originally Posted by Sportsbro View Post
looking to put a blue light in the interior so when i unlock it the interior glows blue
by replacing the overhead light
can someone please tell me what to buy for this and how to install it?
thanks
today:
I just bought: '2013 + Scion FR-S Subaru BRZ Center Console Armrest' (one with cup-holder placers)
Search Amazon.com for "blue 31mm festoon"
Install is piece of cake, gently pry down the plastic cover of the dome light with a small screw driver (two small openings toward the windshield side) And it just pulls straight down to remove.
I have these in white color and they work great. I got the 10 pack as our civic uses them too and I still have a boat load of spares.
[ame="http://www.amazon.com/gp/product/B00AO4Y0L2/ref=oh_details_o00_s00_i02?ie=UTF8&psc=1"]Cutequeen White 31mm(1.25") 12-SMD 12V Festoon Dome Light LED Bulbs DE3175 DE3021 DE3022 3175(pack of 10) : Amazon.com : Automotive[/ame]
Narcoden is offline   Reply With Quote
Old 06-01-2013, 08:27 PM   #1910
GT 86 Brah
u aware?
GT 86 Brah's Avatar
Drives: it like a turtle.
GT 86 Brah is offline   Reply With Quote
Old 06-01-2013, 09:00 PM   #1911
Mikem53
Drives: FR-S 6MT
Installed techstream on my latop .. cabled to car i was able to turn off DRL's and raise the volume on the door lock/.unlock chirp.. other options
im considering changing next time..
Mikem53 is offline   Reply With Quote
Old 06-01-2013, 11:56 PM   #1912
marky
marky's Avatar
Drives: 2020 BRZ tS #54
fixed my tiny dent and washed/waxed/clean inside
before
after
Old 06-02-2013, 01:50 AM   #1913
DIM
Changed my steering wheel!
DIM is offline   Reply With Quote
Old 06-02-2013, 01:57 AM   #1914
BadMoon
BadMoon's Avatar
Looks real good. Tutorial?
Old 06-02-2013, 02:20 AM   #1915
DIM
I used this.
http://www.ft86club.com/forums/showt...=airbag+emblem
Old 06-02-2013, 09:48 AM   #1916
BadMoon
BadMoon's Avatar
Thanks!
Old 06-02-2013, 10:16 AM   #1917
FRSFirestorm
Red is Fastest
FRSFirestorm's Avatar
Drives: 13 FRS 6MT Firestorm
before
after
Took me a bit to understand what you had going here. Genius to use line reflection to see the dent. Question is how did you pull it. Is the ball glued to the panel and some sort of dent puller? Need details... this is cool.
FRSFirestorm is offline   Reply With Quote
Old 06-02-2013, 10:50 AM   #1918
marky
marky's Avatar
was first time doing it.. as a improviser/innovator it was done with home basic tools lying around my tool box no dent puller tools or bought special dent tools
this was on my driver side front fender btw..
used a plain white paper and used a marker to make lines using a ruler so i can see the dent..
after marking the dent i pop the 3 screws under the fender wheel cover so i can get behind it.. i used a magnet and stuck it on the back inside fender and used a metal ball diff from my RC remote control car as you can see that metal ball so i know what aera to push out the dent from the back then i put some tape so i can feel the exact aera from the back and took the magnet off.
used a hair dryer to heat up the dent a bit to make it soft and pushed the dent from the back with some rounded screw drivers tips and the end of the handle of the screw driver was nice and round that made it smooth after poking with it in a inward spiral till i hit the inside of the dent.. as i pushed on the dent i can see the lines start tot straighten up and that when i knew i was doing it
cant even tell dent is there anymore.... dent was caused by a hugh cardboard box that was blown by the wind and the corner of it hit it seems very thin fender but it was hot so i assume due to heat thats why it dented easy but now its gone saved myself like 80$ .. got a quote then i said screw the quote i got this
was not scared to do this. i knew if i screwed up i will still learn and learning from your own mistakes is the best way to learn
