Old 05-30-2013, 07:10 AM   #15
jkonquer
Drives: 2005 Subaru STI
If you are not tracking the car. then cheap coilovers will do just fine and with softer spring rate, you eont compromise too much comfort either. And companies like bc racing, they offer $50 per shock lifetime rebuild services. So you can have it pretty much life of a car. If you do end up tracking, i would spend few more bucks and buy kw
jkonquer is offline   Reply With Quote
The Following User Says Thank You to jkonquer For This Useful Post:
j2digit (05-30-2013)
Old 05-30-2013, 10:39 AM   #16
BlueLeader
Drives: Ultramarine Blue Scion FRS
Thats a train of thought i had a while back when i got megans for looks. You can achieve the height you want to get that look. Again though for looks, the maintenance is not worth it as cheaper ones ones can break down much easier than quality expensive ones. Personal experience, my megans on my old evo front pass side damper was damaged after 6 months most likely due to all the bumps i had to drive through at my work parking lot. Rebuildng them can be a pain in the ass. Then again, weigh the pros and cons.
I'm in the same boat as you. I do want lowering springs when i get my wheela. Swift springs was recommended by my friend who works in acura.
Sent from my VS930 4G using Tapatalk 2
BlueLeader is offline   Reply With Quote
The Following User Says Thank You to BlueLeader For This Useful Post:
Old 05-30-2013, 10:45 AM   #17
eljefe
Drives: SS BRZ LMTD 6MT, 92 Civic hatch RHD
I spent 160 dollars on Tein S tech springs. I kept my stock shocks. Install took about 2 hours in my driveway.
My handling feels much tighter, stiffer than stock yet still plenty comfortable for daily driving. the drop is pretty low compared to other springs on the market, but i have not scraped or rubbed on anything, even with a wider wheel setupand full passengers in the car. Ive hit a few surprise bumps and potholes so far, even went airborne once, and haven't rubbed.
I went this route because a good spring and shock is better than a cheap coil, and this is not my track car so i dont need a 2000+ dollar set of track coilovers. If/when my stock shocks blow, ill replace them with Koni Yellows. But they seem to be holding up fine so far. I am extremely happy with my purchase, especially at the amount of money i spent.
eljefe is offline   Reply With Quote
The Following User Says Thank You to eljefe For This Useful Post:
Old 05-30-2013, 12:29 PM   #18
j2digit
j2digit's Avatar
Drives: 2000 Integra LS, 2013 FRS Firestorm
thanks for the input but just to clarify, you went ahead and got springs first and when you blow out your shocks is only then you will replace them ? so for now, stock shocks (struts, is that right? - sorry about that - no automotive knowledge here at all) is what you are using?
I did look at Tein springs as my other choice if I do go the spring route.
one last thing, what tire wheel setup are you currently using since you have had no issues with rubbing? thinking of getting 18 x 8.5 fronts and 18 x 9.5 rears
thanks
j2digit is offline   Reply With Quote
Old 05-30-2013, 12:59 PM   #19
Mikepage
Mikepage's Avatar
Drives: Scion FR-S 2013 Raven
Strut = shocks
The stock shocks can handle a middle drope springs whitout any problem.
Just don't drope more then 1 inch if you don't want to modify the suspension geometry too much and perfom an alligment after the installation to correct toe in and out.
You can't adjust camber without buying camber bolt for the front and rear camber adjusting kit for the rear. But 1 inch will not affect too much the camber enought to adjuste it.
Edit : you can buy also camber arms but more expensive and probably better.
o= FR-S =o
Mikepage is offline   Reply With Quote
The Following User Says Thank You to Mikepage For This Useful Post:
Old 05-30-2013, 01:09 PM   #20
SkullWorks
Drives: SSM LT MT BRZ
Originally Posted by Mikepage View Post
Strut = shocks
Let's try and help this guy out with all the info,
A "shock" or shock absorber is used in the rear, it only has to deal with vertical (up, down) motion because the suspension has multiple links and keeps the shock from being loaded.
In the front however, The "shock" also has to help locate the front suspension laterally, therefore it has to be much more stout and is referred to as a "strut" in this configuration,
Our front suspension design is commonly referred to as a McPherson STRUT assembly,
It's like the all squares are rectangles but not all rectangles are squares arrangement.
The Following 6 Users Say Thank You to SkullWorks For This Useful Post:
BlueLeader (06-29-2013), CSG Mike (05-30-2013), Enraged21 (05-31-2013), j2digit (05-30-2013), Mikepage (05-30-2013), Racecomp Engineering (05-30-2013)
Old 05-30-2013, 01:19 PM   #21
BRZPDX
Boosted Member
BRZPDX's Avatar
Drives: 2013 SWP BRZ Limited
Also as a side note, if you want to adjust the rear camber, I would recommend getting the control arms instead of camber adjustment bushing inserts. The inserts are cheaper, but they are a PITA in to install, and you will most likely be having it professionally installed, which is a 3 hour job. Lower control arms are more expensive parts wise, but less labor so the total cost will be about the same. And LCA looks cooler than bushings
People are experiencing wacky camber in the rear after lowering the car. I was lucky enough to be -2.1 R -2.2 L, after dropping on Eibach Sportlines (-1.4in drop). I've heard people were off by +-0.6 on the right and left rears in some cases.
Rock springs until the stock struts blow out. Then go coils, +$1,500.
Suzuki Swift GTI '89, Subaru Impreza L '96, Lancer OZ '03, Subaru Impreza WRX '06, Honda CBR600RR Graffiti, Volvo c30 T5 R '11, Subaru BRZ '13, Audi RS4 2007
SUV's: Mercedes Benz R500 '06, Mercedes Benz ML350 '12
BRZPDX is offline   Reply With Quote
The Following User Says Thank You to BRZPDX For This Useful Post:
Old 05-30-2013, 01:36 PM   #22
eljefe
Correct. I kept my stock shocks and i haven't had any problems yet. I expect the life of them to be decreased vs. stock, but I can live with that. When they blow, ill upgrade to Koni's. Just be careful when you remove the top nut from the shocks not to mess up the seal on the shock piston, heard of a few people who blew their stock shocks immediately because they used an impact gun to remove the top nut.
I'm only running 17x8's +35 front and rear with 225/45/17's. I have plenty of room to go wider in the rear, and you could probably go wider in the front if you wanted, but its already flush enough for me. Im not really into having my wheels stick out past my fender, and i dont like the stretched tire look. I do think i could run that wheel size without any issues though as long as the offset was ok. Look up the Rota RT5 and there are pictures of people who are much lower than me running that wheel size.
Old 05-30-2013, 01:44 PM   #23
Mikepage
Mikepage's Avatar
I used an impact gun without any issue.
o= FR-S =o
j2digit (06-27-2013)
Old 05-30-2013, 01:51 PM   #24
eljefe
I used an impacr gun without any issue
I did too. I was careful and i haven't had any issues, but i saw a thread where several people blew theirs. I used short bursts with the gun to loosen it, and it worked out fine for me.
Old 05-30-2013, 05:01 PM   #25
Superman
Drives: Whiteout Scion FR-S 6MT/GSX-R 1000
This is an interesting post, a lot of choices and directions that you can go. Each person's set up will be determined by what you want to do with your car and your preference as far as looks and ride quality. With your initial budget in your first post of $900-1200, you would be very limited in your choice of coilovers. A KW V3, for example, is in the neighborhood of $2200. Very few quality sets are under the $1200. That may help you make your decision right there if you are not willing to go to a larger budget. Standard lowering springs are fine, but are limited. With coilovers, you have alot of setup choices and are able to change your mind and go to a different set up tomorrow if you choose to. I have been fortunate to have driven several different FR-S with all different set ups. Each is completely different and has different characteristics. Especially since it is your Daily as mine is my Daily, you don't want to hate driving it every day. The car is so well balanced right out of the box, I would hate to ruin that. Take your time and make the best decision for you, if that means spending a little more then that might be worth it in the end.
Superman is offline   Reply With Quote
The Following User Says Thank You to Superman For This Useful Post:
Old 05-30-2013, 05:33 PM   #26
OICU812
Just a dude
OICU812's Avatar
Guys who are going KWV3 are you also purchasing and installing LCA in the back and what is the set and forget known for adjusting camber with KWs up front? Strongly considering going from lowering springs to KWs myself.
The Following User Says Thank You to OICU812 For This Useful Post:
Old 05-30-2013, 08:07 PM   #27
j2digit
j2digit's Avatar
the reviews I've read about kw v3 made me initially make them my first choice- it was only after reading so much reviews that I learned that maybe I don't need to spend that much because of DD use only. I do plan to eventually get LCAs if I go the coilover route. I'll let the pros answer your other questions with regards to camber.
Old 05-31-2013, 01:52 AM   #28
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
I think a V3 is overkill for DD unless you have money to burn. Sure, it's good to have something nice, but come on. I'm sure they'll eventually come out with the V1s, etc. Or even the STs. Basically a V1 without the fancy coating.
Also, RCE/GTWorx has their new set for 1299 right now, I believe. But it's only for the first X number of customers. Didn't read it too closely, as I'm not in the market. Those are based off of KWs, IIRC.
Ok, I was curious so I looked for the link:
http://www.racecompengineering.com/i...-and-fr-s.html
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
The Following 2 Users Say Thank You to 2point0 For This Useful Post:
j2digit (05-31-2013), Mgivens (05-31-2013)
Diagrams for the "FRS' and "RS FRS" (includes US Part numbers) Mrqb22 Cosmetic Modification (Interior/Exterior/Lighting) 31 06-24-2013 09:26 PM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
