| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#15 |
Drives: 2005 Toyota Camry
#16 | |
Drives: Argento FR-S
Other than a few sets of wheels it shows 57 sets of drag wheels for the frs and 80 for the tt. Same patterns and model. Similar results looking up konigs. 10 vs. 13. |
| The Following User Says Thank You to Drftfan For This Useful Post: | YourFearlessLeader (05-28-2013) |
#17 | |
Sorry, I'm wrong. I should shut up. PCD = the diameter of the imaginary circle in which the lug holes/studs would sit in. So 5x100mm is the same as other 5x100mm cars... in theory. In reality, you have to differentiate between wheel STUD (our cars) versus wheel BOLT (VW/Audi/most German cars). Wheel bolt usually are 14mm diameter, meaning the holes in the wheels are drilled for 14mm. Thus, the conical surface of the bolt is usually wider. Wheel studs are usually 12mm, and that's why most Japanese cars have lugs that are 12x1.25mm (Subaru/Nissan) or 12x1.5mm (Toyota/Honda). You can run a wheel drilled for 14mm wheel bolts on a 12mm stud if given the proper surface for the wheel lugs to sit (or conversely, if you ran the proper lug nuts that can sit in the wheel safely, see most OEM Lexus lug nuts for an easy reference)... but you cannot do it the other way around. Some wheel makers (especially the ones that are cheaper) drill for 14mm and assume the buyer (you) know what you are doing. -alex |
#18 |
Ok that makes sense. Thank you for clarifying. I have been in the tuner car game for 20 years now and I try not to assume I know everything. This is why I like forums. There is still a ton of shit I don't know.
#19 | |
Fitment guides don't tell the enthusiast a thing. I don't rely on forums for detailed information, and most of my wheel/tire/suspension knowledge was me installing 20+ different combinations of wheels on my own car before settling for what I wanted. With the internet, there's just too many "living vicariously through others" and not enough interest in going out there and experimenting on your own. The aftermarket wheel industry will eventually catch up to FRS/BRZ owners... as long as there is interest. It's still very much a business, and those that plan well (design/production/marketing/sales/execution/warranty/etc/etc) will see a good response from end users. -alex |
#20 |
Drives: red frs
#21 | |
Drives: red frs
also your stock lug nuts dont have the correct seat on them for aftermarket wheels either. |
#22 | |
-alex |
#23 |
Drives: '13 BRZ Ltd WRB
Wait, whut? Please explain.
#24 | |
Drives: a car with nice wheels.
#25 |
Drives: red frs
#26 | |
Drives: red frs
in fact i have a set waiting to go on my rabbit track car when the cage is done so i can run aftermarket wheels. i would take a pic but they are a long way from home at the shop. link to a set on ebay. http://www.ebay.com/itm/14x1-5-TO-12...p2047675.l2557 |
#27 | |
Better to say "make sure your lug nuts work on the new wheels." Besides, after buying a set of wheels, lug nuts (if needed) are chump change.
#28 | |
Drives: red frs
| Any Car Rental companies have FR-S' in the US? | BenArmstrong | Scion FR-S / Toyota 86 GT86 General Forum | 21 | 12-02-2016 01:36 AM |
| Can't figure out what noise this is...any takers? | lostmessengers | Issues | Warranty | Recalls / TSB | 5 | 05-21-2013 11:45 PM |
| Go figure! | Pdxc43 | Northwest | 3 | 01-26-2013 09:03 PM |
| BRZ vs WRX Skid Pad Figure 8 | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 1 | 05-29-2012 12:50 PM |
