Old 05-20-2013, 01:06 AM   #85
Tunz
Drives: WRB BRZ Limited
Looks good!
Originally Posted by eseboner View Post
what kid of cat back is that?
Nameless Performance axleback
Tunz is offline   Reply With Quote
Old 05-21-2013, 07:58 PM   #86
JoeBoxer
JoeBoxer's Avatar
Drives: Whiteout FR-S
Originally Posted by FR-S Matt View Post
Thanks! Yeah, for sure. I plan on some suspension work when I recover from the dent in my wallet on these wheels. I stuck with square so I can rotate and balance since this is my DD.
I haven't looked at springs much, but the Eibach springs looked decent. Just need a bit more clearance up front to be more comfortable. Some street coil overs are what I was looking at since they are thinner than the stock ones, but I worry about stiffening the ride too much. Lowest I'd drop is maybe an inch. Still want good clearance. Need to do a lot more research.
Eibachs with or without Koni's is a good choice, for street coilovers i like the Tein Street Basis for around $800 or the new Racecomp Tarmac Zero's for around $1300.
Old 05-21-2013, 08:10 PM   #87
FR-S Matt
I'll take a look at those. I definitely don't think I need a $2000 coilover for what I do. I simply just want more clearance, maybe a drop of an inch or so, but improved handling is always a plus with spirited driving. Hard cornering is what I worry about with my current clearance. I've been taking it easy. I even looked at the Cusco's to match the strut bars, but I think that is a bit much and I haven't seen much info about them. I have plans for turbo later on, but that won't be for a while.
Old 05-21-2013, 08:23 PM   #88
FR-S Matt
Yeah the Cusco streets are even more than the RCE T0, check out the reviews of the street basis. I'm surprised more people aren't running them for the price.
Appreciate the advice, I definitely will. Thanks man!
Old 05-22-2013, 09:40 AM   #89
ayetothejay
ayetothejay's Avatar
looks great! I also have the same size rpf1s but my tire shop
won't go past 225. I hate this wheel poke I get. I'm also using eibach pro-kits. how's the front clearance? feel any rub going to dips, speed bumps, etc?
ayetothejay is offline   Reply With Quote
Old 05-22-2013, 10:28 AM   #90
FR-S Matt
I don't feel any at all on stock up front. Bumps are all clear. I have 2 speed bumps I clear daily in my apartment lot with 0 issues. No problems with dips either but I haven't gone through any tremendous ones that are deeper. Biggest problem I see happening is the stock spring is so large compared to coilovers that a really hard corner may cause a little slight rub on the spring. I have not pushed it that hard on a corner for that reason. The rest of the clearance is outstanding though on 245's. Anything higher than 245 would need spacers or camber adjustment.
Old 05-22-2013, 11:15 AM   #91
ayetothejay
I knew those "tire experts" are just full of it. guess, time to find a new shop. thanks for the reply.
Old 05-22-2013, 12:02 PM   #92
FR-S Matt
You're welcome. It looked bad when the car was raised up putting them on, no lie. Tell them to lower it then watch the clearance. Unless you plan on going airborne, you'll be just fine.
Old 05-23-2013, 02:59 PM   #93
Delacruzmd
Drives: SSM BRZ
BRZ RPF1 and Stance Coilovers
I opted for the often played out but great light wheel, Enkei RPF1 18x9.5 +38 in SBC finish. I paired this with Continental Extreme Contact DW 245/35 all around, which surprisingly enough was quieter than the stock Prius tires despite the widened footprint and improved grip especially in the wet. I lowered the car 2 inches all round with stance coilovers. I initially opted for Eibach sportlines but went with stance because of reviews here and on the nissan forums. I was awaiting KW V1 or RCE Tarmac as I had great experience with them in the past. Honestly, the ride is pretty good, slightly stiffer than stock but not any worse than springs. On the pothole ridden streets of NY, you will feel the potholes/bumps but I have neither bottomed out or rubbed with this setup. As expected, it's lost it's playfullness in the corners but feels more planted but still need to track it with better settings. Currently, I have -1 and -3 camber in the front and rear respectively. Slight poke in front and tucked in the back. I will most probably go with whiteline rear camber bushings as i want the camber to be around -2 to -2.5 all around in the future. Just want to put a shout out to Jeremy of FT86speedfactory for great prices and customer support and to RCT performance in NY for the install and alignment.
Delacruzmd is offline   Reply With Quote
Old 05-23-2013, 09:48 PM   #94
Metabrz
001 of 012
Metabrz's Avatar
Drives: MY12 NZDM Subaru BRZ "BRZ001"
Hey, we've got twins! Nice work.
BRZ001: Peace Love and Wheelies @metabrz on IG
Metabrz is offline   Reply With Quote
Old 05-28-2013, 05:36 PM   #95
Delacruzmd
Drives: SSM BRZ
Thanks for your kind comments. Trust me I love RPF1's for a reason! BTW, my car is silver. I will try to post more pics soon.
Old 06-14-2013, 11:02 PM   #96
Racecomp Engineering
Originally Posted by Metabrz View Post
Installed today with Cusco Street Zero A Coil overs.
What rear camber are you running on your car? ( front too)
Myles
Old 06-15-2013, 10:19 PM   #97
Metabrz
001 of 012
Metabrz's Avatar
Myles
Neg 2* on the front.
Not 100% sure on the back, we just dropped the car without any other mods. I have the print out somewhere will try and find it.
Old 06-16-2013, 09:07 PM   #98
FR-S Matt
Can anyone with 18x9.5's share a picture of how much room is left on the inside front and rear? Like where the rim is to the strut/spring/coilover?
Myles
I could get some pictures of it on stock suspension. I just purchased the Tarmac 0's to get more clearance in front. The rim itself sits a little below the stock spring while the tire itself is only a few MM from rubbing. A hard corner will make it rub slightly.
ft-86 speedfactory
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 06:31 AM
Wheel Directory: Enkei Raijin 18x8.5 +45 / 18x9.5 +45 GuerillaRacing Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 221 08-01-2019 10:30 AM
Enkei RPF1 18x9.5 5x100 38mm Offset Black Wheel - Exclusive Tony Angelo Edition Wheel Infamous Performance Wheels and Tires 122 02-13-2014 11:34 AM
WHITE Enkei NT03+M 18x9.5 / Enkei RPF1 17x9 Touge Factory Wheels and Tires 2 02-05-2013 04:53 PM
F/S Enkei RPF1 5x114.3 18x9 +35 18X9.5 +38 with track tires SsmoothyMonster Wheels and Tires 17 09-24-2012 01:52 AM
