Old 05-24-2013, 11:38 PM   #71
Carwhisperer
Drives: A lot of supercars.
Originally Posted by Opie View Post
I would say an earlier car that never had a reflash was at greater risk for the possibility of this problem to occur. As updates are released they are programmed into new car builds.
This. I bought mine june 1st with 0 reflashes since right now getting new DI's from Japan's Manufacture with new software.
Carwhisperer is offline   Reply With Quote
Old 05-25-2013, 12:03 AM   #72
vtmike
vtmike's Avatar
Drives: Scion FR-S
That's funny, I got my car the same day. So they did reflash your ecu when swapping out the injectors. Frs or brz?
vtmike is offline   Reply With Quote
Old 05-25-2013, 07:39 AM   #73
mad_sb
Drives: 2013 Asphalt FR-S
I think this is his second set of injectors.
Sounds like the fix is making it's way into some of the EcuTek tuners roms:
http://www.ft86club.com/forums/showp...17&postcount=1
The Following User Says Thank You to mad_sb For This Useful Post:
vtmike (05-25-2013)
Old 05-26-2013, 01:07 AM   #74
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
Drives: Whiteout Scion FR-S
this happen to me today
while John was tuning my car, my seals went bad
now i need to replace them at my own expense.
does anyone know how much the seals are and about how much a shop will chrge to get it fixed
Old 05-26-2013, 01:17 AM   #75
xjohnx
Grip>Slip
xjohnx's Avatar
or someone less scrupulous might try flashing back to stock and taking it into the dealer for warranty repair.
Old 05-26-2013, 01:20 AM   #76
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
im turbo
Old 05-26-2013, 01:53 AM   #77
xjohnx
Grip>Slip
xjohnx's Avatar
im turbo
ah that sucks. how were you able to tell that the injector seals went out?
Old 05-26-2013, 05:06 AM   #78
RAWR BRZ
Drives: 2010 BMW M3, 2013 Subaru BRZ
Mine went out yesterday the 25th. If the 0.6 second thing is true then I know exactly where it happened.
RAWR BRZ is offline   Reply With Quote
Old 05-26-2013, 07:45 AM   #79
whitefrs
Love Boost!!!!!!!!
whitefrs's Avatar
While John was tuning it
Sent from my HTC One using Tapatalk 2
Old 05-26-2013, 08:35 AM   #80
vtmike
vtmike's Avatar
Drives: Scion FR-S
Fa20club said they have had it in their tune for a month and cars built in the last 2 months have the fix.
Old 05-26-2013, 08:45 AM   #81
mad_sb
I would think he was using the latest rom with the fix in it.
It's possible that you experienced a different mode of failure. Since detonation seems to be what causes the failure (actually i would assume the breakdown of the boundary layer during the detonation event over heats the seals and causes them to melt is the root cause) is it possible your situation was not the same mode of failure the fix was designed to prevent?
Either way, to replace the seals you should also get the special tool so you don't damage the seals during installation. SST 09260-39020 is the scion / toyota tool number. I am attaching the manual section that details replacement.
I plan on picking up a full replacement kit soon to have on hand, but I suspect toyobaru will revise the seal part number to a higher temp tolerant part. I figure I will change them all out the first time i pull the manifold.
The Following 2 Users Say Thank You to mad_sb For This Useful Post:
ATL BRZ (05-29-2013), GeeTee86 (05-29-2013)
Old 05-26-2013, 11:06 AM   #82
Jesse
wheel gap
Jesse's Avatar
Drives: whiteout frs, 04 xrs
Fa20club sent an email saying they will be sending out updated maps soon.
Jesse is offline   Reply With Quote
Old 05-26-2013, 11:09 AM   #83
xjohnx
Grip>Slip
xjohnx's Avatar
was this a mass email? or a one off? I spoke with Toni earlier this weekend and he also said the same. I just want to make sure i'm not missing some mailing list i should be on.
Old 05-26-2013, 11:31 AM   #84
Jesse
wheel gap
Jesse's Avatar
Was a mass email I believe
Driver's side window seal/door seal KAB-FRS Issues | Warranty | Recalls / TSB 255 01-01-2021 07:09 PM
FRS-BRZ Port Fuel Injector (interesting) Element Tuning Engine, Exhaust, Transmission 50 04-21-2016 05:26 PM
Need Help - 2 codes thrown jpit Issues | Warranty | Recalls / TSB 3 04-20-2013 01:41 AM
Bulb codes JDMenrique Cosmetic Modification (Interior/Exterior/Lighting) 1 02-17-2013 04:25 PM
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! Dustin@Dynosty Engine, Exhaust, Bolt-Ons 0 08-21-2012 06:03 PM
