Old 12-09-2011, 05:08 AM   #15
Jeff Lange
Jeff Lange's Avatar
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Judging from the picture, the differential (case at least) looks to be the same, or similar to the 205mm F20TX differential from the '01-05 IS300. The 208mm differentials used in some of the larger RWD Toyota/Lexus models have a much wider front mounting, and the IS F's differential case has significant external cooling fins. The 208mm (and older larger differentials like the 220mm in the JZA80), use a 3-bolt dampened pinion flange as well, while the 86 seems to be using the smaller, more common non-dampened 4-bolt design.
The 205mm differential is the same as the older Toyota 8-inch rear end used in cars like the A70 Supra, etc., so aftermarket differentials will likely be relatively easy to get right off the bat. Not that the T2 (if that's what it is) will be bad, I love the T2 I've got in my IS250.
Here are a few pictures showing how similar this is to the F20 differential (both open and LSD) from the IS300/IS250:
IS250 factory F20SX / FD20A Semi-Limited Slip Differential:
IS300 F20TX / FD20AT Torsen T2 Limited Slip Differential:
Using this Toyota differential is a good thing, this will take more abuse than most any owner will ever throw at it.
Jeff
2011 Lexus IS350 F-Sport 6MT with LSD
1986 Toyota Corolla GT-S Supercharged
Jeff Lange is offline   Reply With Quote
Old 12-09-2011, 06:18 AM   #16
2fast4you
2fast4you's Avatar
Drives: 2006 Scion tC RS 2.0
I mentioned this in another thread, but Torsen only makes four models of differentials: T-1, T-2, T-2R (Racemaster), and T-3, and they are found in a wide variety of cars. The T-2 is found in the IS, LFA, Imprezza WRX STi, Genesis Coupe, the Mustang Boss 302, etc., and will be in the 86/BRZ/FR-S.
And for what it's worth: JTEKT Torsen is part of the Toyota Group.
Brake. Turn. Accelerate. Repeat as necessary.
2fast4you is offline   Reply With Quote
Old 12-09-2011, 09:12 AM   #17
Matador
hashiryu
Drives: Mk4 Supra
Originally Posted by Andy View Post
I'm happy about this!
http://www.facebook.com/Tune86com
"Good news! Toyota 86 will feature Torsen LSD and gearbox is from Toyota Altezza / Lexus IS (automatic from IS-F), so we already have tons of spare parts. Almost all suspension is the same as Impreza"
Anybody notice Tada commenting and saying with reference to the Impreza suspension;
All suspension fix points have been modified. This is the point for super performance!
Originally Posted by old greg View Post
And if the ring/pinion gears are as strong as those in the IS's, there shouldn't be any need to worry about it's strength.
Jeff
This right here, is truth.
Welcome to FT86club.com
The 'FT' stands for 'forgot topic'.
Matador is offline   Reply With Quote
Old 12-09-2011, 09:14 AM   #18
Matador
hashiryu
Drives: Mk4 Supra
Originally Posted by viking84 View Post
My first post here I actually just joined to ask what kind of diff this car will have - really good news about the Torsen! I assume this will be the same for both variants (BRZ and GT-86)?
I currently drive a BMW 1-series coupe (120d), and fitting a Quaife diff in it last year completely transformed the car! Made this vid right after the run-in period was over, hopefully the GT-86 will be at least as happy to powerslide
[U2b]fLFupcWTdAs[/U2b]
Did not click on that video expecting that musical intro. Good stuff.
Old 12-11-2011, 12:41 PM   #19
viking84
viking84's Avatar
Drives: BMW 120d M-Sport Coupe
Going to be hard to find a good tune for the GT86, strangely enough very few people make songs about Toyota's...!
Contemplating swapping my BMW for a Toyota...! Never thought that would happen
viking84 is offline   Reply With Quote
Old 12-11-2011, 04:10 PM   #20
LSxJunkie
LSxJunkie's Avatar
Drives: Car
Originally Posted by Ryephile View Post
Cool.
If it's an existing diff that gives more opportunity for aftermarket options like OS Giken, Quaife, or whatever you prefer.
Unless you're w2w racing, the Torsen is all the LSD you need.
LSxJunkie is offline   Reply With Quote
Old 12-11-2011, 05:30 PM   #21
Mr.Jay
Mr.Jay's Avatar
Drives: FRS :D
from the motoiq article the state that its from a is300
Out of the FRS game
Mr.Jay is offline   Reply With Quote
Old 12-11-2011, 05:48 PM   #22
JDLM
JDLM's Avatar
Drives: 2009 BMW 335i
So pricing on those (8XX-1XXX) not terrible
AWE90/ZSP/ZPP/2XA/NAV/HID/DPE////M/EAS/Disma
JDLM is offline   Reply With Quote
Old 12-11-2011, 08:33 PM   #23
fa5tco
fa5tco's Avatar
Drives: 2013 Firestorm FRS
Wasn't the is300 transmission made of wet toilet paper over about 300 whp?
fa5tco is offline   Reply With Quote
Old 12-11-2011, 09:12 PM   #24
Jeff Lange
Jeff Lange's Avatar
Even if it was, what does that have to with this thread?
Jeff
Old 12-11-2011, 09:18 PM   #25
Ryephile
Hot Dog
Ryephile's Avatar
Drives: quicker than arghx7
I disagree. Different LSD styles offer varying chassis control characteristics. An ATB needs both wheels to have some grip, otherwise it reverts to full-open. A clutch-pack style needs wheel speed delta between the driven wheels to start locking. In my experience, ATB's work best in the front axle, and clutch-packs work best in the rear axle. Of course, if you're racing, opinion is irrelevant and only lap times matter. On the street, however, perspective and chassis feel are the only relevant statistic. Nevertheless, in a rear-drive car, any LSD from the factory is usually better than an open-diff.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products.
Ryephile is offline   Reply With Quote
Old 12-11-2011, 09:43 PM   #26
WingsofWar
MODERATOR-SAMA
WingsofWar's Avatar
Drives: Swagtron Scooter
I personally loved Torsen overall, it had good performance and average usability. Much of my Torsen experience was from the FDrx7 and miata. But when it came to track days i found the clutch pack LSD in my FC was more suitable for the task.
WingsofWar is offline   Reply With Quote
Old 12-11-2011, 09:52 PM   #27
Jeff Lange
Jeff Lange's Avatar
It depends what kind of racing you're doing, IMO. I've driven quite a few of both types, in various cars and they all have their strong points. Road-racing with a Torsen is a delight though, which is why I put the T2 in my IS.
Torsens are great OEM LSD's, they're quiet and feature very smooth engagement. Especially for a Lexus, etc. they're perfect. I think most Toyota/Scion owners would appreciate that. Anyone else would likely want a differential with much more lockup, and would probably not care much for a smooth OEM-style clutch-type LSD anyway, and would look aftermarket anyways.
I've got a TRD 2-way for my AE86, it's going to depend on what you want to do with this car, but with it being an existing Toyota differential, options will be relatively plentiful. I'm sure the A70 Supra guys are liking the fact that new options may soon exist for their cars as well.
Jeff
Old 12-11-2011, 11:24 PM   #28
fa5tco
fa5tco's Avatar
Jeff
Well genius. The first page only has 5 posts that mention the transmission. Sorry if I strayed from the differential topicto discuss transmissions in the drivetrain portion of the forums.
Subaru 216A confirmed with 2.0L turbo, AWD, bigger and heavier than FT-86 Hachiroku BRZ First-Gen (2012+) — General Topics 118 11-16-2017 03:19 PM
Confirmed UK Release March!? Leeky Scion FR-S / Toyota 86 GT86 General Forum 17 09-19-2011 09:43 AM
AutoGuide.com FT-86 Technical Details "Confirmed" Exage Engine, Exhaust, Transmission 29 08-06-2011 01:44 AM
Subaru Version of Toyota FT-86 Confirmed...But Not Yet For U.S. Franisco BRZ First-Gen (2012+) — General Topics 66 12-15-2009 03:25 PM
