Go Back   Toyota GR86, 86, FR-S and Subaru BRZ Forum & Owners Community - FT86CLUB > FT86CLUB Shared Forum > Regional Forums > ASIA
Old 05-24-2013, 08:57 AM   #897
Booch
Booch's Avatar
Drives: Red 86
sir Pauland, mine was removed by installer, went to Banawe and ask the owner of the shop to look for an expert, i dont want their installer to remove my bumper. they have on call technician, just add extra tip, atleast you have peace of mind, it might deform your bumper if not removed
Booch is offline   Reply With Quote
The Following User Says Thank You to Booch For This Useful Post:
pauland (05-24-2013)
Old 05-24-2013, 10:06 AM   #898
Margovincent_22x
Margovincent_22x's Avatar
Drives: Lightning Red BRZ MT Limited
Need mo remove ung bumper tapos pakabit mo ung horns sa may screws ng radiator.. fabricate ka nalang ng Stainless steel para sa brackets.
Margovincent_22x is offline   Reply With Quote
The Following User Says Thank You to Margovincent_22x For This Useful Post:
Old 05-24-2013, 12:19 PM   #899
NIKDENG
Drives: RED BRZ
Originally Posted by pauland View Post
Brothers, para sa mga nagpalit na ng horns, is there a way to install an aftermarket horn without dismantling the front bumper? I was in a shop recently and they told me they can install the horn without pulling out the bumper. I'm a bit apprehensive lang for both methods. Kapag kalas bumper, this should be done by a very reputable shop. If hindi aalisin, it will be harder to properly install the horns. How did you install yours?
Pauland,
Just bring it to Mike of Autokozmetix. They have changed horns on several 86 and BRZ already. Removing the front bumper takes Mark just 15 minutes to do.
NIKDENG is offline   Reply With Quote
The Following User Says Thank You to NIKDENG For This Useful Post:
Old 05-24-2013, 04:30 PM   #900
Alabang BRZ
Hi All,
I redid my computation for 98 RON by combining XCS (95 RON) and Blaze (100 RON).
Assuming XCS is P49.60/L and Blaze is P51.50/L to get 98 RON I should put 0.994897959L of XCS for every 1L of Blaze. The above mentioned rates was what I got from my refuel yesterday evening.
Solution A
P958.1929859 of XCS at 19.31840697L
P1,000.0000 of Blaze at 19.41747573L
But to simplify my life I'd put in P950 of XCS and P1,000 of Blaze. It should result in a comfortable 98+ RON. Putting 1L XCS & 1L Blaze would result in 97.5 RON. Putting P960 of XCXS and P1,000 of Blaze would put the mix at a little less than 98 RON.
Solution B
Or if you want to pay P2,000 up front you tell the gas boy to put in P1,022 Blaze and P978 XCS. I'd probably do this as well. That's about 39.56L of fuel.
Our car's tank capacity is 50L. I do not think any one of us will ever run our car until fuel runs out.
Solution C
But if you are so inclined to tap up the fuel tank to 50L all you need to do is 25.07L Blaze and 24.93L XCS at the above prevailing prices. That's about P2,527.62.
Last night I put in P500 XCS and P750 Blaze.
Saw a silver 86 at ATC parking lot at 9PM and a red 86/BRZ at Petron Filinvest Alabang at 1040PM last night.
Alabang BRZ is offline   Reply With Quote
Old 05-24-2013, 04:53 PM   #901
pauland
pauland's Avatar
Drives: Subaru BRZ
I guess its better to remove na nga
Sir Booch, wow good service by the shop! Is this the same shop you had your rear fog lights installed? I think i remember you told me before that it was in banawe. The shop with the airconditioned tinting room? Thanks for the tip!
Will definitely look for those spots. Thanks!
Originally Posted by NIKDENG View Post
Pauland,
Sir Nikdeng, Mark of Autokozmetix was the one who installed my rear fog lamps. Will contact Mike to check their installation rates. Thank you!
pauland is offline   Reply With Quote
Old 05-24-2013, 05:43 PM   #902
rockers_kitoy
rockers_kitoy's Avatar
Drives: Toyota T86
peeps, any suggestion for my head-unit for my 86 red? it's too innova... if you know what i mean. my preference is kinda vintage (just like old Pioneer knobs, sort of and yet updated on the features (bluetooth, etc)
appreciate your help
rockers_kitoy is offline   Reply With Quote
Old 05-24-2013, 05:58 PM   #903
Alabang BRZ
I'm inclined to go with the Kenwood DDX630WBT. It has been installed on numerous 86/BRZ/FR-S/GT86 all over the web with no complaints so far.
But what I want to know with the Kenwood is if I can use Waze/Google Maps/Apple Maps.
I have yet to see the Kenwood use these apps as it appears to depend on the GPS module that is sold seperately. The good thing is the GPS module is made by Garmin but... I dont know if they update it as often as Waze/Google Maps/Apple Maps.
Not to mention it allows for rear camera when putting the car in reverse.
What I dislike about it is the inclusion of CD/DVD. I havent used either in almost a decade. Also the screen isn't 720p.
The Following User Says Thank You to Alabang BRZ For This Useful Post:
rockers_kitoy (05-24-2013)
Old 05-24-2013, 06:22 PM   #904
Alabang BRZ
With how tight the trunk is I wish Toyota/Subaru made a shooting break version of our car.
BTW have your tires checked if you havent done so. I checked last night and the tire pressure varies from 30psi to 40psi. It should be a uniform 35psi.
Old 05-24-2013, 10:07 PM   #905
NIKDENG
Drives: RED BRZ
Originally Posted by Alabang BRZ View Post
Hi All,
Solution A
Solution B
Solution C
There's no need to go through all the trouble of mixing fuels just to achieve an exact 98 RON. Just go straight Blaze with 100 RON. Your car will run so much better not to mention mixing different fuel types is not advisable because of the differences in additive properties.
Manual states:
Fuel Type:
Unleaded gasoline (93 AKI [Research Octane Number 98] or higher)
If unleaded gasoline with an octane rating of 93 AKI (98 RON) is not available,
unleaded gasoline with an octane rating of 91 AKI (95 RON) may be
used with no detriment to engine durability or driveability.
Please note the words "or higher". Even 95 RON is OK if you can live with the cricket sounds.
Hope this helps
Old 05-24-2013, 11:13 PM   #906
NIKDENG
Drives: RED BRZ
rockers_kitoy,
You might also want to consider FlyAudio which has OEM size and connections. Plug and play won't void electrical warranty and has built in GPS. Very good value for money.
Feautures:
*HD TFT LCD SCREEN
*GPS NavigationSystem
*DVD-Video/CD/MP3 Play
*Bluetooth Handsfree
*Dual Zone Screen
*Full Steering Wheel Control
*FM/AM Radio
*Touch Panel Operation
*DVD-R/-RW,CD-R/-RW Compatible
*Advanced Surround System
*TPMS( Optional)
*CD Changer Optional
*AUX in
*Support iPod/iPhone
*Backing Camera Ready
Sample pics on an 86 for your reference:
The Following 2 Users Say Thank You to NIKDENG For This Useful Post:
melon (05-25-2013), rockers_kitoy (05-25-2013)
Old 05-25-2013, 01:41 AM   #907
grannyshifter25
Drives: Subaru BRZ
i'll go to autokozmetics tomorrow am. is there anyone i should look for and should i have it schedulede or ok na walk in lang?
grannyshifter25 is offline   Reply With Quote
Old 05-25-2013, 01:52 AM   #908
NIKDENG
Drives: RED BRZ
Look for Mike the owner. Ok lang na walk in.
Old 05-25-2013, 02:25 AM   #909
Alabang BRZ
Anyone using this?
[ame="http://www.youtube.com/watch?feature=player_embedded&v=_AyXNeRbpRk"]Automatic — Your Smart Driving Assistant - YouTube[/ame]
Old 05-25-2013, 02:26 AM   #910
HRTROB
HRTROB's Avatar
Drives: Toyota 86
You can use Waze with any head unit that has an Aux input, but you will have to navigate using the phone. With the Pioneer head units, you can use the head unit's touchscreen to navigate. I prefer Waze over any other nav program because it gives you real-time traffic updates and warnings
By they way guys if you're installing an aftermarket head unit, use a Toyota wiring harness adaptor and Lexus antenna adaptor so that everything will be plug and play - no wire splicing whatsoever
HRTROB is offline   Reply With Quote
The Following 2 Users Say Thank You to HRTROB For This Useful Post:
NIKDENG (05-25-2013), rockers_kitoy (05-25-2013)
