Old 05-24-2013, 08:17 AM   #337
Marcoscrdo
Marcoscrdo's Avatar
Drives: 13' DGM Built FBM BRZ
Originally Posted by Darryljr11 View Post
Where'd you come from??? lol Are thinking about getting a SC kit?
Yeah remember? But wont happen for a really long time
Marcoscrdo is offline   Reply With Quote
Old 05-24-2013, 12:51 PM   #338
Darryljr11
Sideways and Smiling!
Darryljr11's Avatar
Drives: Scion FR-S
Oh right lol. Im hoping to install mine by the end of july.
Darryljr11 is offline   Reply With Quote
Old 05-24-2013, 02:02 PM   #339
Brian@Vortech
Brian@Vortech's Avatar
Drives: Vortech Supercharged M6 FR-S UM
Originally Posted by Dezoris View Post
Here are my questions for owners:
1. What problems or issues have you had post install?
2. Did you make any mistakes or should you have done anything different?
3. How do you feel about the performance, anything strange in terms of noises sounds you hear at low RPM and higher RPM?
4. Where do you mount or hide the stainless steel drain line? Nothing in manual about it.
General Questions:
1. Is there a guide to changing SC oil?
2. What are problems or signs of problems to be looking out for?
3. Extra belts is it Gates Model: K060975? What about using Gates Green Stripe Micro-V Belt
4. Manual mentions you can't drive in temps below 25 degrees is that true, never heard that you cant drive it in winter before?
1. What problems or issues have you had post install? None here in house. Might be a good idea to check clearances after the first post-install drive, and again a day or two after initial install, but that would hold true with any kit. Other than that, you should be good to go.
2. Did you make any mistakes or should you have done anything different? What others have said about the drill portion of the intercooler install comes to mind. You'll need a powerful drill and good bits, or it can be a difficult task indeed.
3. How do you feel about the performance, anything strange in terms of noises sounds you hear at low RPM and higher RPM? Very linear, and quite exhilarating performance. The compressor can be heard at idle to some extent, and (of course) the bypass valve can be heard between shifts.
4. Where do you mount or hide the stainless steel drain line? Nothing in manual about it. Can either be left coiled and zip tied, or can be zip tied off to framerail or any other non-obstructive location.
General Questions:
1. Is there a guide to changing SC oil? This:
Originally Posted by draggin_az View Post
Unscrew dip stick and pull out slightly, undo nut at the end of drain hose, place water bottle as far down into the engine bay as possible, place drain hose into bottle, and allow to drain. Place nut back on hose, zip tie off somewhere, according to Jamie (tech at Vortech) fill until the oil is in the middle of the "cross grid" on dip stick, screw dip stick back in, and enjoy.
2. What are problems or signs of problems to be looking out for? If oil can be seen coming out through the vent plug, the unit may be overfilled. If this is the case, check the oil level to ensure proper oil level on dipstick.
3. Extra belts is it Gates Model: K060975? What about using Gates Green Stripe Micro-V Belt As long as the belt is a good quality belt in the correct length and size, any belt of your preference may be used.
4. Manual mentions you can't drive in temps below 25 degrees is that true, never heard that you cant drive it in winter before? It is a mechanical piece cooled by oil, just like any other similar device. Viscosity in temperature extremes would be a concern with any and all engine components, not just a Supercharger. We place the warning on the Supercharger because that is the part that we manufacture. Similarly to how steps must be taken in any turbo application to prevent the oil from getting too hot, leading to oil coking issues, steps must be taken to avoid the Supercharger oil from being too cold at the instant of initial startup. However, the warning relates only to initial startup in below 25 degree weather. Once the vehicle has been brought up to normal operating temperatures, everything will operate exactly as any other day. The same tolerances inside the unit that allow it to be quiet and super efficient, also have to be tight in order to be quiet and super efficient. Before initial startup (if the vehicle has been sitting for hours) in under 25 degree conditions, a block heater, heating blanket, or even a shop light on under the hood for enough time to raise the underhood temp above freezing is sufficient. Once the vehicle is at normal operating temperature, no other steps are required.
Brian@Vortech is offline   Reply With Quote
The Following 2 Users Say Thank You to Brian@Vortech For This Useful Post:
Dezoris (05-24-2013), Sniper2606 (05-24-2013)
Old 05-24-2013, 04:15 PM   #340
Darryljr11
Darryljr11's Avatar
Drives: Scion FR-S
Is there enough space in front of the vortech intercooler for a air cooler?
Old 05-26-2013, 02:07 PM   #341
Foobar
SLO NO MO
Foobar's Avatar
Noticed my boost not getting past 4.8 PSI. Checked for leaks and the coupler on the intercooler output side was partially popped off. I guess I didn't tighten it properly. Will work on it tonight or tomorrow.
Edit: All better now. Getting pushed back into my seat again, woot!
Sent from my Nexus 4 using Tapatalk 2
The Following User Says Thank You to Foobar For This Useful Post:
ngabdala (05-28-2013)
Old 05-28-2013, 02:59 AM   #342
pheoxs
Hold my beer n watch this
Drives: '14 Fiesta ST / '91 240sx
Uh oh, I was planning on running this in my year round frs (typically down to negative 40C/ negative 40F during winter ) hmm... this could be interesting...
Nolan
pheoxs is offline   Reply With Quote
Old 05-28-2013, 11:47 AM   #343
Dezoris
Dezoris's Avatar
Yeah there is certainly some issues with the kit that you have to ask the right questions to get answers.
Old 05-28-2013, 12:18 PM   #344
djdnz
1337
Drives: 2013 BRZ WRB S/C
It's not anywhere as cold here in Ontario as it is for you in Edmonton, but I am definitely going to be below -4C for most of the winter. Block heater is an option when I'm at home, but not parked at work, it would be annoying to have to use it when the car wouldn't need it otherwise though.
djdnz is offline   Reply With Quote
Old 05-28-2013, 02:12 PM   #345
pheoxs
I'll take it to pm and post after if we can figure something out. I don't understand certain things about this temperature issue... don't want to clutter the thread with misinformation
Nolan
Old 05-30-2013, 08:54 PM   #346
DJCarbine
Thupercharged
DJCarbine's Avatar
For anyone else looking to replace the plastic bypass valve with something a little more robust/louder, I found a bolt in replcement.
http://www.turbosmartusa.com/product...-universal-fit
You want the 25mm version.
It is a dual port, so you can retain the K&N filter on the dump port. Both ports are the same 1" as the plastic bosch unit. It simply replaces the bosch unit retaining the factory hose/K&N filter.
For those who will argue that this may suck in un-filtered air through the "horn" port, the supercharger produces more airflow than the engine can ingest even at idle. Also, this valve only fully opens to dump air out of the "noisy" horn at high intake manifold vacuum/positive pressure in the charge pipe. Otherwise it only vents to the dump port with your K&N filter.
This results in a valve that operates pretty much exactly like the included plastic bosch valve, however at moderate/high boost it produces a nice deep "whoosh" sound like a traditional BOV.
You can also block off the "horn" with the included blocking plate, then it will work exactly like the plastic bypass valve without any noise.
Unnecessary? Probably.
But it is fun, and I prefer aluminum over plastic.
Perhaps Vortech can chime in if this is a bad idea, but I'm familiar with boost and this seems solid in operating theory with no chance of unfiltered air entering the system(My main concern).
2013 FRS
Vortech V3 11psi
Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300
2019 Series.Grey STI - Stage1+ SF
DJCarbine is offline   Reply With Quote
The Following 3 Users Say Thank You to DJCarbine For This Useful Post:
Pete (05-30-2013), Sonolin (05-30-2013), Sportsguy83 (05-30-2013)
Old 05-30-2013, 09:57 PM   #347
draggin_az
Small penis big dreams
draggin_az's Avatar
Drives: '13 Scion FR-S
$200!?!?!?!?!?!?!?!?!
with all due respect, fuck that
v3 -> v2 Vortech SC / 2.87 pulley
Fuel pump, FIC 770 injectors, custom header back, perrin resonated CBE
277hp 93 octane
370hp on E-85
draggin_az is offline   Reply With Quote
Old 05-30-2013, 10:01 PM   #348
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
Good BOV's typically run 200-250. From DJCarbine's perspective, he just spent around 5K on a kit, what are 200 more to make it sound like he wants?
The Following User Says Thank You to Sportsguy83 For This Useful Post:
draggin_az (05-30-2013)
Old 05-30-2013, 10:04 PM   #349
draggin_az
draggin_az's Avatar
i guess but $200 just to change the way it sounds when you let off the gas or push in the clutch......i'll pass
277hp 93 octane
370hp on E-85
The Following User Says Thank You to draggin_az For This Useful Post:
Old 05-30-2013, 10:17 PM   #350
JordanInnovations
Drives: Forced Induction and LSx Swaps!
The last kits we've gotten have all had the new aluminum BOV's. I'll see if I have a pic, they're really nice - machined look, black finish, looks a lot like that Turbosmart one but with no branding on it. Certainly no need to buy a replacement.
JordanInnovations is offline   Reply With Quote
Vortech Supercharger denverizzles Forced Induction 176 10-19-2013 07:48 PM
New Vortech Supercharging System Information... Brian@Vortech Forced Induction 306 11-08-2012 06:49 PM
Supercharging the GT86 Billy2224 Engine, Exhaust, Transmission 13 06-05-2012 04:58 PM
Turbo/Supercharging Your FRS BoostJunkie Engine, Exhaust, Transmission 123 05-18-2012 07:26 PM
Supercharging: the forgotten form of FI madfast Engine, Exhaust, Transmission 76 03-02-2012 06:06 PM
