#15 |
Drives: 1986 AE86 GT-S, 2011 Lexus IS250 6M
Judging from the picture, the differential (case at least) looks to be the same, or similar to the 205mm F20TX differential from the '01-05 IS300. The 208mm differentials used in some of the larger RWD Toyota/Lexus models have a much wider front mounting, and the IS F's differential case has significant external cooling fins. The 208mm (and older larger differentials like the 220mm in the JZA80), use a 3-bolt dampened pinion flange as well, while the 86 seems to be using the smaller, more common non-dampened 4-bolt design.
The 205mm differential is the same as the older Toyota 8-inch rear end used in cars like the A70 Supra, etc., so aftermarket differentials will likely be relatively easy to get right off the bat. Not that the T2 (if that's what it is) will be bad, I love the T2 I've got in my IS250. Here are a few pictures showing how similar this is to the F20 differential (both open and LSD) from the IS300/IS250: IS250 factory F20SX / FD20A Semi-Limited Slip Differential: ![]() IS300 F20TX / FD20AT Torsen T2 Limited Slip Differential: ![]() ![]() ![]() Using this Toyota differential is a good thing, this will take more abuse than most any owner will ever throw at it. Jeff
![]() 2011 Lexus IS350 F-Sport 6MT with LSD 1986 Toyota Corolla GT-S Supercharged Last edited by Jeff Lange; 04-21-2016 at 12:49 AM. |
#16 |
Drives: 2006 Scion tC RS 2.0
I mentioned this in another thread, but Torsen only makes four models of differentials: T-1, T-2, T-2R (Racemaster), and T-3, and they are found in a wide variety of cars. The T-2 is found in the IS, LFA, Imprezza WRX STi, Genesis Coupe, the Mustang Boss 302, etc., and will be in the 86/BRZ/FR-S.
And for what it's worth: JTEKT Torsen is part of the Toyota Group.
Brake. Turn. Accelerate. Repeat as necessary.
#17 | |||
hashiryu
Drives: Mk4 Supra
#18 | |
hashiryu
Drives: Mk4 Supra
Good stuff.
#19 |
Drives: BMW 120d M-Sport Coupe
Going to be hard to find a good tune for the GT86, strangely enough very few people make songs about Toyota's...!
Contemplating swapping my BMW for a Toyota...! Never thought that would happen
#20 |
Drives: Car
#21 |
Drives: FRS :D
from the motoiq article the state that its from a is300
Out of the FRS game
#22 |
Drives: 2009 BMW 335i
So pricing on those (8XX-1XXX) not terrible
![]() AWE90/ZSP/ZPP/2XA/NAV/HID/DPE////M/EAS/Disma |
#23 |
Drives: 2013 Firestorm FRS
Wasn't the is300 transmission made of wet toilet paper over about 300 whp?
#24 |
Even if it was, what does that have to with this thread?
Jeff
![]() 2011 Lexus IS350 F-Sport 6MT with LSD 1986 Toyota Corolla GT-S Supercharged |
#25 |
Hot Dog
Drives: quicker than arghx7
I disagree. Different LSD styles offer varying chassis control characteristics. An ATB needs both wheels to have some grip, otherwise it reverts to full-open. A clutch-pack style needs wheel speed delta between the driven wheels to start locking. In my experience, ATB's work best in the front axle, and clutch-packs work best in the rear axle. Of course, if you're racing, opinion is irrelevant and only lap times matter. On the street, however, perspective and chassis feel are the only relevant statistic. Nevertheless, in a rear-drive car, any LSD from the factory is usually better than an open-diff.
"Wisdom is a not a function of age, but a function of experience."
Just Say No to unqualified aftermarket products. |
#26 |
MODERATOR-SAMA
Drives: Swagtron Scooter
I personally loved Torsen overall, it had good performance and average usability. Much of my Torsen experience was from the FDrx7 and miata. But when it came to track days i found the clutch pack LSD in my FC was more suitable for the task.
#27 |
It depends what kind of racing you're doing, IMO. I've driven quite a few of both types, in various cars and they all have their strong points. Road-racing with a Torsen is a delight though, which is why I put the T2 in my IS.
Torsens are great OEM LSD's, they're quiet and feature very smooth engagement. Especially for a Lexus, etc. they're perfect. I think most Toyota/Scion owners would appreciate that. Anyone else would likely want a differential with much more lockup, and would probably not care much for a smooth OEM-style clutch-type LSD anyway, and would look aftermarket anyways. I've got a TRD 2-way for my AE86, it's going to depend on what you want to do with this car, but with it being an existing Toyota differential, options will be relatively plentiful. I'm sure the A70 Supra guys are liking the fact that new options may soon exist for their cars as well. Jeff
#28 |
| Subaru 216A confirmed with 2.0L turbo, AWD, bigger and heavier than FT-86 | Hachiroku | BRZ First-Gen (2012+) — General Topics | 118 | 11-16-2017 02:19 PM |
| Confirmed UK Release March!? | Leeky | Scion FR-S / Toyota 86 GT86 General Forum | 17 | 09-19-2011 08:43 AM |
| AutoGuide.com FT-86 Technical Details "Confirmed" | Exage | Engine, Exhaust, Transmission | 29 | 08-06-2011 12:44 AM |
| Subaru Version of Toyota FT-86 Confirmed...But Not Yet For U.S. | Franisco | BRZ First-Gen (2012+) — General Topics | 66 | 12-15-2009 02:25 PM |
