#421 |
That Guy
Drives: 2013 asphalt FRS MT
I really like this kit, but I've got to be honest, the shape of that curve looks like it would be hellish to drive. I asked about this the last time we saw a curve with that shape and was told that tuning wasn't finished. Is the tuning in the area between 3200 and 5000 rpm still not finished? Or is that the finalized tune?
#422 |
Drives: 2013 Subaru BRZ
What are your thoughts on the stock header with catalytic converter? At what power level should we be concerned with failure of the catalytic converter causing damage to the turbo with this setup?
#423 |
Drives: LexusGS,Lotus Exige S240,LexusLX570
So what to expect from the basic kit (without WMI) and regular pump gas is 300whp? This kit consists of?
What is the hottest temperatures it has been tested in? Lastly when can we see some new on the road, in the car videos?
#424 | |
Drives: White FR-S
It should improve the low end somewhat, but will likely be at the cost of top end power.Keep in mind though that there is not really a torque dip, but rather a torque bump at 3.2K rpms. I want to say that there is no other forced induction system that can produce 200wtq at that rpm and still has the top end to crank out close to 300whp on pump gas at 6 psi on a DD Dyno. Funny thing is I was debating on removing the 3.2K torque "bump" through the tune before posting the pic LOL. BTW, here is another common viewing perspective on the dyno chart. Looks a lot smoother. ![]() ![]()
| The Following 4 Users Say Thank You to ptuning For This Useful Post: |
#425 | |
Drives: White FR-S
BTW, the header makes more power NA through most of the powerband with no loss anywhere, including the dip. |
| The Following User Says Thank You to ptuning For This Useful Post: | Calum (05-22-2013) |
#426 |
Drives: White FR-S
Here is a comparison to show that a properly designed turbo system can make big torque everywhere, even off idle.
BTW, this comparison is in no way designed to put down other manufacturer's work as that is not our style. It only puts into perspective what people deem "instant torque", "linear torque", "linear power", etc. with different forced induction systems. Blue - PTUNING Green - Stock BRZ Red - Centri-SC (raised rev limiter with no other mods) Pencil - Upcoming Blower (converted KW to WHP and WHP to WTQ) Note: We understand that these other numbers are preliminary, but we don't expect a sudden 40-90 WTQ gain throughout the powerband with future tweaks on pump gas in the near future. If need be, we'll make changes to the comparison if these numbers change. Either way though, take it with a grain of salt as it is just a quick and simple comparison of readily available data. :happy0180:
| The Following User Says Thank You to ptuning For This Useful Post: | cmss2000 (05-22-2013) |
#427 |
I think that dyno looks great. I'm not a fan of big turbos but 200wtq is plenty for around town driving. And when you ring it out it must get really crazy.
So... We'll say at least 470 flywheel horsepower, that's a 5.8 power to weight ratio with the stock curb weight! That's phenomenal. Personally I think 400whp is a little too much for stock internals with track driving, but I guess we won't know the answer to that for another year or two at least. |
| The Following User Says Thank You to Sonolin For This Useful Post: | ptuning (05-22-2013) |
#428 | |
#429 | |
Drives: White FR-S
Also, making sure that the tune is good (not too rich for instance), right off the bat, would be ideal. |
#430 |
Drives: White FR-S
We're not sure what you're talking about.
Just kidding. Honestly, we think the SC looks awesome and very design is very very clean. We look forward to installing one in the near future for customers. We're just not sure if people are anticipating tire shredding V8 torque at 2-3K rpms the INSTANT they jab the gas pedal, because this is not going to happen with ANY FI system for this engine, including ours. |
| The Following User Says Thank You to ptuning For This Useful Post: | FRSPirate (05-22-2013) |
#431 | |
Drives: White FR-S
We'll try to get some new on-road videos up soon. |
| The Following User Says Thank You to ptuning For This Useful Post: | mnsayer (05-23-2013) |
#432 | |
, easy to install, and good range of power for track use). I just hope it shows potential past the base 220whp dyno.Anyway, your guys kit looks awesome and I'd be buying it if its possible to get carb legal, but thinking more seriously the only way I could "get away" with a turbo is something small and concise like AVO. Idk though I've been trying to convince the (soon to be) wifey to move to FL, we do have 5ish years before we have to get this car smogged haha
#433 | |
Drives: White FR-S
Having lived in CA and FL, I have to say that CA weather is so much better (no humidity), but then again, owning a modded car there is definitely a nightmare. |
#434 | |
| Tags |
| over 9000, ptuning, turbo kit |
| FA20CLUB.com Turbo Kit Sneak Peek.... | FA20Club.com | Forced Induction | 98 | 12-14-2013 02:34 PM |
| Sneak peek at new 57Xtreme? | vividracing | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 11 | 02-07-2013 03:24 PM |
| Sneak Peek! P&L Motorsports Stg.1 BRZ/FRS Turbo Kit. | P&L Motorsports | Forced Induction | 179 | 01-31-2013 08:32 PM |
| AFE PROTOTYPE EXHAUST: SNEAK PEEK! | autofashionfred | Engine, Exhaust, Transmission | 20 | 08-13-2012 02:22 PM |
| Tsukuba Circuit BRZ/FRS showdown Sneak Peek | AVOturboworld | BRZ First-Gen (2012+) — General Topics | 19 | 06-23-2012 12:13 PM |
