Old 05-21-2013, 09:15 PM   #1
Faceless
Drives: 2013 Raven Fr-s
Wheel Directory: Enkei RPF1 17x8.0 +35
I have a set of rpf1's on the way and was wanting to stretch the stock 215's to fit on 17x8's. Question is, does anyone have a picture of how bad the tires will look?
Another question is, should I go with a 225/45 or a 245/40? I'm not really looking for a stretched look, but I don't want to add to much width to the tire. My ideal size would be a 235/40 but there are so few options.
Edit:
Pictures posted further down! Thanks everyone for the input
Last edited by DarrenDriven; 03-17-2014 at 01:57 PM. Reason: additional information
Faceless is offline   Reply With Quote
Old 05-21-2013, 09:31 PM   #2
FR-S Matt
I'd probably go with 225's and a sportier tire than stock. If I can fit a 245 on 9.5 with really good fitment, I think 225 on 17X8 will fit nicely. Test a bit with the tire tools that are stickied and the tire calc that miata.net has. That's how I decided on 245/35/18 for my wheels as they don't rub and my speedometer is accurate.
Old 05-21-2013, 09:32 PM   #3
CSG Mike
CSG Mike's Avatar
215 will be fine on a 17x8
HachirocksU (09-11-2019)
Old 05-21-2013, 09:43 PM   #4
Faceless
I've been using that tool on miata.net and the closest I've come to keeping it accurate was the 235/40. The 225/45 was about 1.4% off on the speedometer rating while the 235 was only .9%.
I have seen that the kumho xs have a a tread with of 7.9 in on their 215's so I'm almost thinking that may be the way to go as well.
Old 05-21-2013, 10:26 PM   #5
GTM_Challenge
GTM_Challenge's Avatar
Drives: On track
What he said.
GTM_Challenge is offline   Reply With Quote
Old 05-21-2013, 10:43 PM   #6
Mitch
form follows function
Drives: RIP '13 BRZ
They'll fit fine, but I wouldn't waste the mounting and balancing charges. Those tires are worth more left on the stock wheel. I've definitely made use of my stockers as a backup set for when I'm getting tires flipped or going on road trips.
Mitch is offline   Reply With Quote
Old 05-21-2013, 10:59 PM   #7
wparsons
wparsons's Avatar
I'm running 225/45's on 17x8's, they fit great. My speed still reads dead on compared to GPS.
flickr
Old 05-21-2013, 11:12 PM   #8
ParangWala
ParangWala's Avatar
Drives: 2013 SCION FR-S
The 225 will fit fine, depends entirely on the tire but 225 is good also the more tire the more money you will spend.... BTW Dunlop Direzza Z2s come in 235/40...I have the RPF1s 17x8 on Z2s square setup.
I don't think the stretch is that bad if you're using 215 but that's just my opinion so long as its just regular driving you are good to go and the thing about wider tires is that they over hang a bit to cover the lip of my wheels in case I ever rub against something. Other than that so long as the manufacturer says it fits then it fits and the less rubber the cheaper it is too
Just do some more researching, most companies publish acceptable rim width measurements for their tires on their sites like Falken (http://falkentire.com/tires/car-tires/azenis-fk453) just click view sizes and specs then you can see all the accepted widths of the tire.
Hope this helps.
ParangWala is offline   Reply With Quote
Old 05-21-2013, 11:16 PM   #9
ParangWala
ParangWala's Avatar
This is true, in real world applications those 1-2% differences are only really noticeable when going roughly 100km (estimate) and even then 1-2% of 100 is only 1-2kms +/- so....realistically it doesn't make much of a difference.
Old 05-22-2013, 12:15 AM   #10
Faceless
Thanks for all the input, looks like I'm probably going to be running 225/45's.
Old 05-22-2013, 12:32 AM   #11
Rabble
Drives: Asphalt FR-S
will 225s fit on rpf1 17x7s??
Rabble is offline   Reply With Quote
Old 05-22-2013, 01:55 AM   #12
Faceless
Another quick question. I've got muteki closed end lugs, will those work with the rpf1's?
Old 05-22-2013, 09:30 AM   #13
wparsons
wparsons's Avatar
I'm running the stock lugs on mine, the locking lug is a tight squeeze to get the key onto it, but they fit.
flickr
Old 05-22-2013, 09:33 AM   #14
wparsons
wparsons's Avatar
Any 225 should be fine on a 7" wheel, tirerack gives the full specs of any tires they sell so you can see what rim sizes will work.
http://www.tirerack.com/tires/tires....R7Z2&tab=Specs
flickr
Wheel Directory: Enkei RPF1 17x9.0 +35 D1cker Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 801 06-18-2024 07:31 AM
Wheel Directory: Enkei RPF1 17x8.0 +45 track_warrior Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 163 03-17-2022 03:00 AM
Wheel Directory: Enkei RPF1 18x9.5 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 297 02-15-2018 04:50 PM
Wheel Directory: Enkei RSM9 17x8.0 +48 AsianStyle Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 13 02-17-2014 07:50 AM
Wheel Directory: Enkei RS+M 17x8.0 +35 FT-86 SpeedFactory Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 37 02-12-2014 05:26 PM
