Old 05-20-2013, 08:06 PM   #743
Cudafish
Drives: 13' Brz Premium - SWP
Stupid double post....blasted iPad. My bad.
Cudafish is offline   Reply With Quote
Old 05-21-2013, 03:10 PM   #744
Unichip Jack
Unichip Jack's Avatar
Drives: E36 M3, Whiteout FR-S
Cudafish… thanks for the post.
I’m not sure if you mean “use” as in driving or installing? In either case, it’s pretty simple...
For LC you put the clutch in, push the accelerator to the floor, and modulate wheel spin with the clutch… a little practice and you can get very repeatable launches.
Same idea with flat foot shifting… at redline you leave the accelerator on the floor and as the clutch is engaged the Unichip limits the RPM until you disengage the clutch… again, there’s a little “learning” as it feels strange the first few times but there’s nothing especially challenging about it.
On the installation side, it’s a simple hardware attachment to the clutch switch.
Please let me know if I can answer any other questions.
Cheers
Unichip Jack is offline   Reply With Quote
Old 05-21-2013, 04:07 PM   #745
swift996
swift996's Avatar
Jack - Just curious if anyone is working with meth injection on this platform? If I remember correctly, the unichip can support auxiliary controls.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 05-21-2013, 04:11 PM   #746
bakerr6
Drives: 2013 raven black fr-s
Cheers
Jack,
I have launch control working right now on Tony's tune. Doy ou know if it incorporates flatfoot shifting also? I haven't tried it yet and do not want to burn out the clutch lol
bakerr6 is offline   Reply With Quote
Old 05-21-2013, 05:04 PM   #747
Unichip Jack
Thanks for the posts…
Swift996… contact Tony at Unichip Wholesale…I know he’s done nitrous and is planning on methanol but I don’t know where he is with it.
Bakerr6… flat foot away! That set up does both LC and FF shifting.
Cheers
Old 05-22-2013, 06:28 PM   #748
Lytheum
Drives: 2013 BRZ Premium 6MT
Cheers
any word on the fa20club cai map? i see the unichip is on sale this weekend and im really tempted to buy
2013 Subaru BRZ Premium 6MT -STOCK!
Lytheum is offline   Reply With Quote
Old 05-24-2013, 10:58 PM   #749
Cudafish
Do you know how simple it is to install it on the clutch switch? Also, do I have to alter any of the maps for it to work? Or use special maps?
Old 05-26-2013, 02:34 AM   #750
Sonolin
Any plans for a flex fuel add on? I'd be seriously interested in the unichip if you guys offered e85/flex fuel at an affordable price!
Sonolin is offline   Reply With Quote
Old 05-28-2013, 05:18 PM   #751
phloozy
phloozy's Avatar
Drives: Scion FR-S
Can anyone chime in on the effectiveness of the Unichip with headers? Is it even close to a custom Ecutek map? Also if the header throws a CEL can the Unichip clear it?
phloozy is offline   Reply With Quote
Old 05-28-2013, 05:36 PM   #752
jordanrw260
Drives: Dark Grey Metallic 2013 BRZ
Post from UniChip Jack earlier in the thread
Can this turn off a CEL for no cat? The Unichip doesn’t “turn off” fault lights because it doesn’t reflash the OE ECU. A reflash tells the ECU that something the OE programming says is a fault isn’t a fault; the condition (like removing the cats) still exists, but ECU just doesn’t thinks it’s a problem.
The Unichip creates a simulated condition to make the OE ECU believe everything is “normal” which means OE ECU never turns on the light in the first place… as with most things, you can get to the desired solution with either tuning approach. Perhaps the difference seems unimportant but it’s fundamental to the difference between the two approaches.
That said, “defeating” emissions system controls or cautions is a huge Federal legal issue with very steep penalties (like $100k for each violation) and banning the parts from future sale. That get’s our attention even if it doesn’t concern somebody else.
jordanrw260 is offline   Reply With Quote
Old 05-28-2013, 05:48 PM   #753
swift996
swift996's Avatar
Effective:
I have the catted version of the FA20Club headers so no CEL. The CEL only comes on when the secondary 02 sensor detects the cat (or where there is no cat) isn't doing it's job (what the factory ECU has it's thresholds set at). You can easily clear that CEL with torque or any OBDII reader. I don't have the Flux2 with the unichip so I'm not sure if you can clear codes via that device.
Old 05-28-2013, 06:03 PM   #754
phloozy
phloozy's Avatar
Drives: Scion FR-S
Looks like you are a happy customer! I think I will be going with Unichip since I am more focused on curing the torque than pumping as much money as I can getting every 1-3hp. The Unichip+headers seems to do that well
Old 05-29-2013, 05:23 AM   #755
HRTROB
HRTROB's Avatar
Drives: Toyota 86
Dynoed my car today...
Dynojet
34C Ambient temp
55% Humidity
runs done on the same day
Blue line: Milltek overpipe, resonated front pipe, resonated catback, Afe Takeda dry intake, Borla UEL header, stock ECU
Red line: same as above except with Unichip
[IMG]http://i374.photobucket.com/albums/oo184/mtech2/image_zpsac***fbe.jpg[/IMG]
13whp gain with the Unichip and yes, the runs were pretty consistent:
And here's today's best pull overlayed next to my bext pull last month. Blue line is with the same mods except for the header.
HRTROB is offline   Reply With Quote
The Following 10 Users Say Thank You to HRTROB For This Useful Post:
Asphalt~86 (05-30-2013), blkwrxwag (05-29-2013), BuBlake (06-04-2013), jdmasfcuk (05-29-2013), Jetscape (07-14-2013), rthaanum (06-03-2013), SpeedR (08-18-2013), swift996 (05-29-2013), Tye300 (05-30-2013), victorb (05-29-2013)
Old 05-29-2013, 10:19 AM   #756
victorb
Drives: Black 86
Nice robin! Big gain on the torque on headers. Ftw
victorb is offline   Reply With Quote
Let's get tuning! EcuTek tuning now available! carbonBLUE Southwest 6 06-29-2015 03:37 PM
Unichip EMS Unichip Jack Engine, Exhaust, Bolt-Ons 300 11-22-2014 04:13 AM
unichip 13 FR-S Veteran Engine, Exhaust, Transmission 9 02-04-2013 12:05 AM
unichip 13 FR-S Veteran CANADA 0 12-03-2012 06:31 PM
