Old 05-21-2013, 03:31 PM   #323
Opposed
Drives: 2013 Asphalt FR-S
Beautiful build you have there. I just read this whole thread and your build thread and enjoyed every post. Only questions I have cause I must have missed it, are you still running the stock clutch? And are you still running the 4.7 rear diff with the supercharger? Or did you go back to stock?
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline   Reply With Quote
Old 05-21-2013, 03:52 PM   #324
robispec
Drives: Black frs project
Not much still running the 4.7.
The car with the four tan stock gearing is geared to go 165 miles an hour I'm not gonna see that on any of the tracks we're running. Lol
robispec is offline   Reply With Quote
Old 05-21-2013, 03:55 PM   #325
swift996
swift996's Avatar
Has anyone thought about running a methanol injection with this kit? I know it's not available yet, but ptuning has had great results with meth injection on their turbo kit.
2010 Cadillac CTS-V Sedan M6 w/550whp (Build Thread)
swift996 is offline   Reply With Quote
Old 05-21-2013, 03:57 PM   #326
CSG Mike
CSG Mike's Avatar
Originally Posted by robispec View Post
We are testing the reliability and efficiency of E 85 with the standard kit and a 75 mm pulley. NONintercooled... Only other upgrade associated with this kit is the teach works 65 pump. And for those people are concerned about their oil temps and water temps the robispec huge radiator with the oil heat exchanger inside...
Robi's car with the supercharger certainly survived me driving it... which is more than I can say about the stock engine.
Certainly has my seal of approval the way with the way it's running on Robi's car.
The Following 4 Users Say Thank You to CSG Mike For This Useful Post:
mines13 (05-22-2013), robispec (05-21-2013), sw20kosh (05-21-2013), wparsons (05-22-2013)
Old 05-21-2013, 04:17 PM   #327
mad_sb
That's going to be tough because you need to spray AFTER the rotors so the nozzles would need to be located in the intake manifold and unless you do individual port nozzles it's going to be very difficult to get even distribution.
Old 05-21-2013, 04:19 PM   #328
swift996
swift996's Avatar
I thought it was safe to spray in the rotors? I'm not a meth expert but have seen a few people running it.
Old 05-21-2013, 04:23 PM   #329
mad_sb
water / meth is in-compressible and over time i believe it will cause wear to the rotors... same reason people don't spray at the turbo inlet.... It can have a major impact if you do spray a very low volume of water at the turbo inlet, it basically bumps the compressor map up to a larger wheel, but it also causes a lot of wear on the compressor... at least that is what i have read anyway could be 100% BS.
Much like the turbo example... it might make a very nice improvement if it is safe to spray before the rotors..... Guess we need to ask sprintex.
The Following User Says Thank You to mad_sb For This Useful Post:
swift996 (05-21-2013)
Old 05-21-2013, 04:26 PM   #330
robispec
Meth cools great but very corosive... Also add one more layer of complexity simple is fast and safe in a race car.
Old 05-21-2013, 04:35 PM   #331
swift996
swift996's Avatar
Agreed and the simplicity is what keeps this kit very interesting to me. I'm just thinking of ways to increase power as I'm sure the numbers aren't going to be game changing.
Old 05-21-2013, 04:41 PM   #332
sw20kosh
Drives: 2013 Black FR-S
I am down for nozzles in every runner. No problem with that. Water/meth injection + 91 octane would be nice but it wont reach what you can get with E85.
I don't think water/meth injection boosts power on E85 cars does it?
Old 05-21-2013, 05:03 PM   #333
s2d4
s2d4's Avatar
May as well just add a fuel injector precharger.
Old 05-21-2013, 05:15 PM   #334
Calum
That Guy
Drives: 2013 asphalt FRS MT
If you went with the stage one system it might be easier to fit a nozzle into the plenum. The question is, would the WMI make up for the intercooler?
Old 05-21-2013, 05:27 PM   #335
AZFA20
Automotive Connoisseur
AZFA20's Avatar
Drives: too many cars
You can inject water/meth on a screw or roots. If the rotor and screw surface coating is graphite then you may not want to but if it is teflon you can. I have never had any issues with corrosion over the years with methanol or rotor/screw deterioration. Turbos are a little different situation because of the compressor wheel speeds if injecting pre-turbo. The atomized water droplets will literally chip away at the leading edge of the impeller vanes from pure speed almost like a sand blaster. This eventually deteriorates the compressors ability to flow as it should over a considerable amount of time.
Personally I wouldn't be afraid to use water/meth at all. It was when I first started playing with PDs that I became such a water/meth supporter.
LSx Powered 86/ASE Master Certified Automotive Technician
AZFA20 is offline   Reply With Quote
The Following 2 Users Say Thank You to AZFA20 For This Useful Post:
Fast_Freddy (05-23-2013), mad_sb (05-21-2013)
Old 05-21-2013, 05:27 PM   #336
mad_sb
I agree 100% and with E85 i don't see any need... thankfully i have several stations near me now
Bullet/Sprintex/Innovate on the bullet website JoeBoxer Forced Induction 333 04-18-2013 11:07 AM
Still searching for an FR-S? 2 available in Little Rock Moshpit37 Southwest 9 01-02-2013 11:32 AM
Bullet SC 86 Loki556 AUSTRALIA 9 08-08-2012 02:39 AM
Searching Inventory in the SE Erroneous Southeast 40 07-23-2012 05:40 PM
