Old 05-09-2013, 04:53 PM   #15
CBR600RR
Drives: Raven Black
Relax, I fucking got stickers, lots of'em
The Following User Says Thank You to CBR600RR For This Useful Post:
frsvr4 (07-01-2013)
Old 05-09-2013, 05:23 PM   #16
TylerLieberman
TylerLieberman's Avatar
Drives: '24 GR86
I have 250hp now too.
True story
Old 05-20-2013, 09:29 PM   #17
TylerLieberman
Drives: '24 GR86
Small teaser from the weekend
Had a blast! Once the rest of the pictures get sent to me, I'll post everything up
Old 05-20-2013, 10:07 PM   #18
TRD_07
TRD_07's Avatar
Drives: Firestorm 6MT
The car looks great man! I really wanted to go check out the event but unfortunitely I wasn't able to make it. I look forward to your pictures. Thanks.
TRD_07 is offline   Reply With Quote
Old 05-22-2013, 02:02 PM   #19
TylerLieberman
Drives: '24 GR86
So this past weekend there was an event in Mineral Wells. Had a lot of fun and learned a good amount about the car. I was also able to figure out what steps should be taken next in improving the car.
Threw the stock tires on the back to tear apart. The Michelin's are obviously not very good. The surface was a bit more harsh than I remember as well. After 5 runs, the tires already started chunking up a bit. The tires themselves are obviously not very grippy. Couple that with nearly -2 degrees of rear camber and the car's rear end doesn't feel very planted. It floats around a bit. So, before the next event, I'm going to roll out the rear fenders and pull out some of the camber so I have more contact and with better tires, more rear end grip. I'll end up going to somewhere between -1 and -0.5 degrees. Doing this will help in making the car feel more stable, more planted, and be a bit faster when the throttle is opened all the way.
Another thing to take into account is the steering angle-or lack of. It really doesn't have that much (compared to other car's I've drifted). Obviously, seeing how the steering components are stock, I can't expect crazy steering angle but some extra would be nice. Tie rods, rack spacers, and modified steering knuckles will help for sure. The front end felt great. I ran just under -4 degrees of camber and a tad bit of toe out. Turn-in and response was awesome. Just needs a little more steering angle in my opinion.
Next up is the big one: POWER. I came to the event with the assumption that the car was gonna get a beating just to keep the wheels spinning. I was definitely wrong! The car can be feathered on and off throttle through 2nd gear with ease. 3rd gear is where it get's interesting. My entry speeds were between 60-80mph and was running 3rd gear through the first corner. The problem is that the rpms were between 4-5k with the throttle hammered-which is where the torque dip is. I thought the car could easily use another 100hp from some type of forced induction, and sure, it could. It would be fun. But honestly, after driving it, I feel like an extra 30 or so hp and utilizing a new header and ecu setup to get that mid range torque back is what the car really needs. It would make the car 10x better and make it feel a lot more powerful.
There are a couple of small things I would like to change too eventually like thicker sway bars, a clutch type LSD over the torsen diff. The torsen diff works but the car would respond so much better with a proper 2 way diff. That's way down the road though. Other than that, I different bucket seat and deep dish steering wheel to make the driving position perfect for my liking.
The only real downside to the day was the passenger tire exploding and tearing a small hole in my cv boot. So, first thing to do is get that taken care of. Not a big deal, but it just goes to show and prove that if you wanna drift your new FR-S/BRZ (or any car). Be prepared for something to break or get damaged cause it WILL happen. Luckily, it isn't a big deal and is an easy fix.
To sum it all up, the car feels great. Great balance and great response. An alignment change, a bit more power and mid range torque will make the car even better. Can't wait to get back out there.
To do list:
CV Boot fix
Roll Fenders
Alignment
More Tires
Drive
More Tires
Drive
Down the road:
Header back exhaust
Drop In Filter
ECU Tune
Lightweight crank pulley
Bucket Seat
Steering Wheel
Sway Bars
2 Way Diff
The Following 3 Users Say Thank You to TylerLieberman For This Useful Post:
6-Shift (05-28-2013), Marrk (05-22-2013), _hollywood (06-03-2013)
Old 05-23-2013, 03:00 PM   #20
Touge Factory
Touge Factory's Avatar
Drives: ZN6
Send a message via AIM to Touge Factory
Ditch the Torsen!
We put Tomei 2-way in ours, and went out for some fun at D-Day!
Touge Factory is offline   Reply With Quote
The Following 2 Users Say Thank You to Touge Factory For This Useful Post:
FRSdrive (02-24-2014), TylerLieberman (05-23-2013)
Old 05-23-2013, 04:39 PM   #21
TylerLieberman
Drives: '24 GR86
Originally Posted by Touge Factory View Post
Ditch the Torsen!
That was the diff I was looking at. Hooke me up! Been buying stuff from you guys for years anyways lol
Old 05-23-2013, 04:44 PM   #22
TylerLieberman
Drives: '24 GR86
Pics from the photoshoot the other weekend
Stattic.net feature/photoshoot
The Following 9 Users Say Thank You to TylerLieberman For This Useful Post:
4Running Daily (07-03-2013), 6-Shift (05-28-2013), Aydhayeth (06-12-2013), Draco_PR23 (06-09-2013), finch1750 (06-24-2013), HATED1 (09-15-2013), karma003 (08-09-2013), Kaster (05-26-2013), supragoods (05-24-2013)
Old 05-24-2013, 06:33 PM   #23
TylerLieberman
Drives: '24 GR86
So axle cv boot is being fixed this week.
Working on getting a time to get my rear fenders rolled so I have the clearance to pull out the camber in the rear.
To do/to buy list:
Cv Boot Replacement
SPC LCAs
Roll Rear Fenders
Alignment
Red Out Tails
Toyota/GT86 badges
Tint
More Tires
All of this to get done by the event on August 11th. There is an event this Sunday and another one on July 28th but I don't wanna cut it that close with my finances so I'm just holding off for the one after. The car will be so much better once it gets the new alignment.
After that event, sway bars, strut bars, chassis bracing and then it's on to the motor.
Old 05-24-2013, 07:41 PM   #24
Marrk
Drives: Honda Fit
To do/to buy list:
Cv Boot Replacement
SPC LCAs
Roll Rear Fenders
Alignment
Red Out Tails
Toyota/GT86 badges
Tint
More Tires
Are you replacing just the boot (the rubber part) or the joint itself? Did the boot tear?
Marrk is offline   Reply With Quote
Old 05-24-2013, 08:27 PM   #25
TylerLieberman
Drives: '24 GR86
The boot tore when the tire popped. The car drove literally 15 feet then we jacked it up, cleaned it all up and got a universal cover boot from autozone put on it.
Does anybody know how much I can adjust rear camber with the stock arms and bolts? I'm just trying to get a bit less cause I'm about -2 right now.
Old 05-26-2013, 07:09 PM   #26
Drftfan
Drives: Argento FR-S
I am following this thread. Seems like exactly what I am trying to do with my frs as well.
Drftfan is offline   Reply With Quote
The Following User Says Thank You to Drftfan For This Useful Post:
TylerLieberman (05-26-2013)
Old 05-27-2013, 12:49 PM   #27
TylerLieberman
Drives: '24 GR86
Getting some work done today
Old 05-27-2013, 02:42 PM   #28
TylerLieberman
Drives: '24 GR86
Saw somebody on here with a Raven FR-S who dipped their stock wheels white. Decided to do the same to mine since they're just my drift spares and I think the white looks so much better than the silver/black that they come in.
Also did my tail lights red
JDM Toyota and GT86 badges, window visors, Personal steering wheel and hub next. Then stack up on some more tires.
Can't wait for the next event in August
KO's Raven FR-S Build: Name "Raven12s" KO Member's Car Journals 3 07-18-2013 03:09 AM
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 06:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 06:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 01:59 PM
Five Axis Spoiler - Painted "RAVEN" Black that_guy Canada Classifieds 29 12-18-2012 09:34 AM
