#29 | |
Seems Legit
Drives: Toyota
If so, just put the registration number in and press ok. After I did that I got a 3000 hr "license". Still useless with the cable drivers but I'm looking into sourcing a Windows XP laptop just for this.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here] |
#30 |
Drives: Brz WRB - Europe LHD
This one fits and works very well.....
http://www.ebay.it/itm/121099762897?...84.m1497.l2649
#31 | |
Is it fast? No.
Drives: 2013 Scion FR-S Manual-Asphalt
![]() 2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars} [Wanted: Delicious Stg 2 tune, Bilstein struts] |
#32 | |
Seems Legit
Drives: Toyota
#33 |
Drives: 2019 Mazda Miata RF
Seems everyone is using the cable from China...I gotta say, I'd rather not order from China. Any US sources for the cable?
Would this cable work? [ame="http://www.amazon.com/OBD2-Diagnostic-Cable-KKL409-1-VAG-COM/dp/B002WIN8VQ"]OBD2 OBD II Diagnostic USB Cable For KKL409.1 VAG-COM 409 : Amazon.com : Automotive[/ame] Apologies, but I'm a noob when it comes to OBD2 stuff. |
#34 |
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Cheap ebay cable works fine. I've been using this nearly since I got the car last July. All my laptops are win7 64bit so I just run xp mode and install the software in the vm. You can use any vm software, and then just find a copy of win xp if you don't already have one.
| The Following User Says Thank You to michaelahess For This Useful Post: | DoomsdayJesus (09-10-2013) |
#35 | |
#36 |
Drives: 05 TSX & 13 BRZ
Mind posting a link to a compatible cable?
Sent from my Galaxy Nexus using Tapatalk 2
2013 DGM BRZ
Visconti STG2 FlexFuel Tune - aFe intake - Perrin resonated catback - P&L header, front pipe, & overpipe - Kartboy short shifter - Eibach prokit springs - Smoked sidemarkers - Full LED interior/exterior - Kenwood cmos-210 backup camera - Hardwired Valentine V1 |
#37 |
Ebay search for the above.
#38 |
Drives: 2013 FR-S Ultrmarine MT
The ARM Processor is 32 bits on the MINI VCI 16Pin J2534 Cable
If I understand it correctly, no software fix will make the J2534\USB cable connector work on 64 bit. The hardware processor (the big central black chip welded onto the J2534 board) is 32 bit.
![]() So, I doubt that there will be a 64 bit drivers for that hardware. Please correct me if my understanding is inaccurate - thanks.
| The Following User Says Thank You to Zagmeister For This Useful Post: | Trap63 (06-02-2013) |
#39 | |
#40 | |
My point was that waiting for a 64 bit software to work on the 32 bit ARM processor that is embedded onto the hardware is very doubtful. The hurdle is the 32 bit hardware not the lack of a 64 bit software. |
#41 | |
Seems Legit
Drives: Toyota
This goes to show the mini vci was just a workaround from the beginning. As the actual hardware required to run the software, that the dealers use, is several thousand dollars. So yes, a VM running XP will work but that wasn't the reason this thread was created as it ran on XP using older versions.
#42 | |
First 86
Drives: Whiteout MT FR-S
Brett
Don't shop, adopt!
| TPMS Tools | developer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 10-04-2021 02:28 PM |
| anyone with a shop or tools | Tylub | Southern California | 0 | 05-14-2013 12:03 PM |
| Tools? | Gost | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 35 | 04-03-2013 04:46 PM |
| Tools for DIY maintenance? | F1point4 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 08-08-2012 08:47 PM |
