Old 05-18-2013, 12:26 PM   #57
mrk1
Drives: Sterling BRZ Ltd
Are you guys on stock struts? I just reinstalled my warranty set along with Koni's and these are making noise again. I installed these with a wall mounted spring compressor.
I really want these to work I really like the idea of the parts. It seems putting a conical washer in would give a bit more clearance but it doesn't look like the Koni's have enought thread to make that safe.
The Build Thread
GT28RS - eBoost2 - 3.91 Final Drive - Supra LSD
mrk1 is offline   Reply With Quote
The Following User Says Thank You to mrk1 For This Useful Post:
Calum (05-18-2013)
Old 05-19-2013, 10:34 PM   #58
Calum
That Guy
Drives: 2013 asphalt FRS MT
I noticed, while installing mine, that it was easy for the strut rod to move to the side and to end up torquing the nut onto the bearing instead of the race. I had my hand tight and noticed that the bearing was just starting to bind. I loosened the nut, re-centered and tried again. This time there was no binding. I only have a few miles on mine, but so far so good.
Can you feel the noise in the steering wheel?
Old 05-19-2013, 10:41 PM   #59
mrk1
Not in the wheel but thought the rest of the car yes. I'm going to pull them apart tomorrow and try again.
I use a wall mount spring compressor so I'm going to try really pulling the spring down to get everything up top snug.
The Build Thread
Old 05-20-2013, 12:16 AM   #60
Calum
That Guy
That was my problem aswell, I didn't compress the spring far enough and wasn't able to center everything during assembly. You could check it by lifting off the dust caps and checking to see if the nut is centered.
Old 05-20-2013, 01:36 PM   #61
mrk1
everything looks centered. I cant find my stupid wheel lock key had to order another, going to have to live with the noise till that comes in.
The Build Thread
Old 05-20-2013, 02:43 PM   #62
Calum
That Guy
http://www.princessauto.com/pal/en/P...vers/8320954.p
Old 05-20-2013, 10:35 PM   #63
mrk1
Thought about getting removers but a new key is cheaper, and if the remover doesn't work it leaves a mangled mess and then I would really be in a jam
The Build Thread
Calum (05-20-2013)
Old 05-26-2013, 10:37 AM   #64
enjoyminutemaid
enjoyminutemaid's Avatar
Drives: Subaru BRZ Limited WRB Manual
UPDATE: Yesterday, I swapped the OEM tophats back on my Koni/RCE Yellows and the noise went away. I also noticed that the bearings on the Koyo-bearing COM-Cs will spin, but not smoothly, and they definitely don't spin nicely like the bearings on the OEM tophats. The clunking I had is also gone. I had the COM-Cs professionally installed a month or so ago, then reinstalled the OEM tophats yesterday using a spring compressor.
enjoyminutemaid is offline   Reply With Quote
Old 05-29-2013, 12:19 PM   #65
feldy
feldy's Avatar
Drives: 2013 FRS Asphalt
so much for sending me a new set tomorrow. They were out of stock I guess still waiting on more to come in this week.
2013 Scion FR-S AT Picked up 5/30/2012
feldy is offline   Reply With Quote
Old 05-29-2013, 04:35 PM   #66
Calum
That Guy
Yup, mine are making the noise to. I'm gonna contact Whiteline when I get them off, hopefully this weekend.
Old 05-29-2013, 05:31 PM   #67
feldy
feldy's Avatar
Contact Jan at @Whiteline they just got replacement sets in today. They sent me a email this morning letting me know a set is on the way.
Old 05-29-2013, 06:07 PM   #68
enjoyminutemaid
That's good to hear, though I'm not convinced the next set won't do the same. What is her contact information?
Old 05-29-2013, 08:11 PM   #69
whataboutbob
AutoX-10/10ths every run
Jan is a guy.
http://www.whiteline.com.au/contact.php
909 476 2860
Build thread:Here
The Following User Says Thank You to whataboutbob For This Useful Post:
enjoyminutemaid (05-30-2013)
Old 05-29-2013, 08:53 PM   #70
Draco-REX
Corner Junkie
Draco-REX's Avatar
Drives: 13 BRZ, 11 STI, 99 RS
Originally Posted by onefasazn View Post
What way are you assembling the spring and strut assembly with the top hat? Are you using a spring compressor? I had a buddy who installed his using the "drop the car on the strut" method and he ended up with the same type of clunking noise. Re-did the suspension with a spring compressor properly and it was gone.
REALLY???
You can do it all by hand. Subaru uses only enough preload to keep the springs seated. It's even easier if you have a buddy. Get everything aligned, then one person pushes down on the tophat and the other gets the nut started. From there you can use hand tools. Hell, I'm 250lbs so I was able to do it myself. There's no need to do something silly like lowering a car onto a disassembled strut.
The Following 2 Users Say Thank You to Draco-REX For This Useful Post:
ATL BRZ (05-29-2013), mikalem (06-01-2013)
upgraded mounts? 7thgear Engine, Exhaust, Transmission 19 01-12-2013 12:31 AM
Buyer Beware: Motor Mounts cobrabyte Engine, Exhaust, Transmission 5 01-04-2013 09:14 PM
Autocross Camera Mounts? fritzy BRZ First-Gen (2012+) — General Topics 7 08-03-2012 11:48 PM
SEAT BRACKETS / SIDE MOUNTS - Planted Technology - Font Motorsports Font Motorsports Interior Parts (Incl. Lighting) 2 07-03-2012 07:43 PM
Dash Mounts for gadgets smbrm Cosmetic Modification (Interior/Exterior/Lighting) 0 06-28-2012 08:07 PM
