Drives: SWP Subaru BRZ Sport-Tech 6AT
Borla UEL Header and Stock Exhaust CEL
Hey guys,
There's plenty of you guys out there with the Borla UEL headers and aftermarket exhaust systems, how'd you guys get around the CEL without a tune? I ordered the Borla UEL headers and planning to run it with stock everything else for now, without a tune until my wallet agrees to pay for a tune. |
#2 |
Boosted
Drives: Not a supra....yet
well you should've searched, but considering you already created this thread.
You should add a defouler / O2 sensor spacer that ends up tricking the sensor.
#3 |
Thupercharged
Just let the CEL be on until you get a tune. Only downside is no cruise control.
Its not worth removing the underpanel and doing defoulers if you are getting a tune. |
#4 |
Boosted
considering his doing the headers, removing the under panel could be done with it
#5 |
Drives: Whiteout FR-S
I bought a Weapon-R o2 sensors
! 55 bucks.
#6 |
Budget a tune with the headers if possible.
#7 |
next summer , I'll get a tune :P
#8 |
Just drive it
Drives: 13' FR-S
So.. no cruise control with catless header?
#9 |
Drives: 07 scion tc 06 Evo 9 mr 10 4runner
eBay o2sensor spacer.
5 bucks. Check the ECS motorsports borla header group buy |
#10 |
Drives: Passat
I see no reason for a CEL as long as the secondary cat is left intact. The CEL is only triggered when the post-secondary cat O2 sensor reads too much oxygen because there are no upstream cats. If for some odd reason you do get a CEL for reduced catalyst efficiency a simple anti-fouler/CEL eliminator on the secondary O2 sensor should eliminate the CEL.
Do consider that the cheap anti-foulers are zinc plated mild steel that will rust very quickly and be impossible to remove later on should you need to replace the sensor, etc. IMO it's worth a few dollars to get one in 304ss. Also the angled versions seem to work better than straight ones. |
#11 |
Drives: GT86
There is no 'post secondary cat o2 sensor'.
#12 |
Drives: Passat
So where is the secondary (narrow band) O2 sensor installed? Is it after the primary cat but before the secondary cat? If so, a CEL eliminator should still work. Just remember that whatever you do, NEVER PLACE A ANTI-FOULER ON THE PRIMARY (WIDE BAND) O2 SENSOR!!! |
#13 |
Drives: GT86
#14 |
I'm new to the whole header/cats game...would something like this on the Borla UEL trick the sensor?
http://www.ebay.com/itm/STAINLESS-ST...13a128&vxp=mtr |
| Borla Header with test pipe and ISIS exhaust | post_break | Engine, Exhaust, Transmission | 12 | 05-24-2015 10:43 PM |
| Borla UEL Header, Full Catless exhaust, Stock Midpipe, Berk Muffler Delete | evilconcarne999 | Engine, Exhaust, Transmission | 34 | 03-24-2014 01:39 PM |
| quick vids borla uel header custom exhaust 1 1/4 inch piping | HI | Engine, Exhaust, Transmission | 12 | 04-19-2013 07:06 AM |
| BORLA UNEQUAL LENGTH HEADER NOW IN STOCK @ NINJA AUTOSPORTS!!! | NJA | Announcements, Contests, Giveaways | 6 | 04-03-2013 05:47 PM |
| In Stock: Borla FR-S/BRZ Lightweight Cat Back Exhaust! | 10k Redline | Engine, Exhaust, Bolt-Ons | 8 | 10-23-2012 03:11 AM |
