Old 04-27-2013, 01:31 PM   #1
ft_sjo
Drives: GT86
Question Front hub/knuckle/flange shared with any other model?
Does anyone know if the front knuckle/hub and associated parts are shared with any other Subaru/Toyota model?
Looking to mock up a big brake conversion but need a cheap assembled package I can use rather than an actual car.
Old 04-27-2013, 08:37 PM   #2
wparsons
wparsons's Avatar
Pretty sure the knuckle and wheel side of the hub is identical to a WRX. The other side of the hub is different because there's no splines for an axle, but that won't effect brakes.
flickr
Old 04-28-2013, 02:19 AM   #3
ft_sjo
Drives: GT86
Which WRX though? The late 2008- ones have a different PCD, no?
Old 04-28-2013, 03:45 PM   #4
jamal
jamal's Avatar
Drives: Legacy GT
It is definitely not the same part. However, the brake caliper mounting and spacing/offset of the rotor is the same between the brz/frs and every Subaru.
Only the STi has a different bolt pattern, but front brake mounting is still the same. Just different holes in the rotor.
jamal is offline   Reply With Quote
The Following User Says Thank You to jamal For This Useful Post:
ft_sjo (04-29-2013)
Old 04-28-2013, 05:08 PM   #5
OrbitalEllipses
Drives: Attitude
No. As Jamal said, only the STI is different. Well, the SVX is 5x114.3 too and so is the Tribeca...but those are rarely talked about.
What kind of brake solution are you looking for? A common GR WRX upgrade was Legacy GT front brakes which are 316x30mm.
Old 04-29-2013, 12:16 AM   #6
ft_sjo
Drives: GT86
I'm looking at throwing together a 32mm wide kit with AP products. Nobody else uses the same parts I intend to, so I have to do it myself!
Old 05-19-2013, 12:45 AM   #7
ft_sjo
Drives: GT86
So what year WRX are we talking about chaps?
Old 05-19-2013, 02:57 AM   #8
jamal
jamal's Avatar
Drives: Legacy GT
Doesn't matter. Front brakes mount the same on all of them.
Old 05-19-2013, 03:03 AM   #9
ft_sjo
Drives: GT86
So anything from a 96-present?
Borla UEL flange, more in common with a pretzel then a flange. Adeets Engine, Exhaust, Transmission 13 04-12-2013 05:38 PM
Stock exhaust flange RWD-boxer Engine, Exhaust, Transmission 4 03-05-2013 08:27 PM
FS: gold brass knuckle shift knob 86design Interior Parts (Incl. Lighting) 11 01-28-2013 05:30 AM
Header flange Silverdub Engine, Exhaust, Transmission 0 08-09-2012 07:43 PM
Hi-res pics & list of BRZ JDM model grades from stripped down base model to STI(?) switchlanez BRZ First-Gen (2012+) — General Topics 68 02-14-2012 07:16 AM
