| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
Drives: 2012 Toyota GT86
WHEEL SPACERS WITH 1.6" DROP.
Hey guys, i am about to run Eibach Sportline springs. giving me aprox 1.5" drop.
I have 18x8.5 +45 all round, and want to put 10mm spacers on the rear. Dose anyone see any problems i might come up against ? My plans are just to enhance looks for the back. and close wheel gap. Thanks |
#2 |
Boosted
Drives: Not a supra....yet
instead of running spacers run a wider rim in the back, because if you are investing money into rims you should get them perfect and not need to add something to them.
#3 |
Drives: it has 4 wheels and a motor
make sure to get the spacers with stud replacement not the other kind.
then, you'll be perfectly fine. |
#4 |
Functionally Retarded
Drives: LinkECU V6 MR2 - MKVII Golf R
The reason people do this is so they can have that staggered look while retaining the ability to rotate the tires... Not necessarily because they're being cheap.
1991 MR2 - T-tops - Crimson Red - 1MZ-FE 3.0L - Other Stuff
![]() I'm not really an asshole, but I play one on the internet. |
#5 |
Drives: '13 White FR-S, 09 Triumph St.3 R
This is all well and good unless the OP wants to run a square setup, which would be my guess for the spacers. I for one would rather get a square setup with offsets as close to tolerance as possible then use a small spacer to finish with. I like to be able to rotate my tires front to back to get the most use out of them.
#6 |
Drives: 2013 FR-S, 2016 Miata Club
All a spacer really is... is a different offset wheel. Not literally speaking. If you had an 45mm offset wheel, you can get a 10mm spacer to make it a 35mm offset wheel. That's how wheels are manufactured. They form it with a thick back pad and grind that down to the correct offset. So an Enkei RPF1 with a 35mm offset and a RPF1 with a 45mm offset is the same wheel. It's just that the 35mm offset wheel has a thicker back pad and therefore weighs more. Hope that makes sense. But as others have suggested, if you are just going to use a spacer, be sure to get the extended lugs. Many people suggest ARP studs. Hope this helps.
| F/S BNIB H&R 15mm Wheel Spacers | jammz | Wheels and Tires | 1 | 04-27-2019 09:36 AM |
| Ichiba and H&R Wheel Spacers on Sale!! Check It Out!! | Mike@CZP | Wheels and Tires | 363 | 06-17-2018 04:38 AM |
| Lowered FR-S + Wheel Spacers = ♥ | Touge Factory | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 44 | 09-14-2015 12:29 AM |
| Longer wheel studs for those with spacers | 000 Racing | AUSTRALIA | 0 | 03-20-2013 07:41 AM |
| H&R Wheel Spacers! | vividracing | Wheels and Tires | 3 | 06-19-2012 06:11 PM |
