Drives: scion fr-s
long startup!!! HELP!
Guys today when i started my car it took me a second try to start the car, the first one i turned the key and wouldnt start then the second try it started right away. it happened twice today. im in tx and is about 75 degrees. help please
| The Following User Says Thank You to juanam0909 For This Useful Post: | Guff (05-05-2013) |
#2 |
Drives: ZC6, Junk of ALL sorts
Pump Fuel?
All stock?
# 1. Always know where your towel is.
ZC6-CBS, is home |
#3 |
Drives: scion fr-s
yes all stock
#4 |
Re-member
Drives: Toyota camry
You may want to read about an issue with the injectors, http://www.ft86club.com/forums/showthread.php?t=20930
Could be completely unrelated, but figured id point it out. Also, make sure the battery has enough juice.
Nothing decays like progress, and nothing preserves like neglect.
#5 |
DADA
Drives: 2013
Cold weather? Mine needed a second crank when it was cold.
#6 |
Drives: scion fr-s
guys i realized i was turning the key too fast and not letting the ignition start right. if that makes sence for yall....
#7 |
Keep Calm And Drift On~
Drives: Scion FR-S WhiteOut 6 Speed Manual
Try to allow the ignition on acc just before you try to turn it over for about 10sec. Thus allows the ECU to gather its data for engine management . Remember the starter is the biggest load and draws over 100 amps.
#8 |
Drives: FR-S 6MT
You should turn the car to ignition, just one click shy before starting.. Just for a second or two then start it.. This turns on the fuel pump and pressurizes the fuel system.
#9 |
Drives: Raven Manual FRS
Sit in the car, turn key to ACC, put on seatbelt, start car. Its a good way to give the car time to do its start up check.
#10 |
Drives: 2013 DGM BRZ, 2020 C8 Corvette
the only time i had that happen was when i immediately tried to start the car upon entering. now, i just wait until it stops beeping before i start it.
#11 |
Drives: 2013 Whiteout FR-S AT
Yep, pretty much what everyone else above has said. I had the same issue, so I started to be more patient, turning the key to ACC and letting the gauges come to life, before starting the engine. In fact, I even set my RPM limit at 7400 JUST so i can watch and wait for the tach sweep before I start the car.
#12 |
Drives: Subaru BRZ 6MT LTD
This has happened to me once or twice. I have the limited BRZ. I immediately start the engine when I plop down in the seat, and have no problems since. I would not worry about it unless it becomes a regular occurrence.
| Show your custom Navigation startup picture! | LeeMaster | BRZ Photos, Videos, Wallpapers, Gallery Forum | 24 | 11-14-2013 04:44 PM |
| Strange engine noise during startup (Video inside) | StOpNG0x | Issues | Warranty | Recalls / TSB | 2 | 01-29-2013 08:24 AM |
| NAV startup screen | brett_g | Electronics | Audio | NAV | Infotainment | 1 | 07-22-2012 08:16 AM |
| Help finding thread about startup rpm needle | Prava | Electronics | Audio | NAV | Infotainment | 2 | 07-01-2012 02:29 PM |
| 2013 FR-S (Auto) Cluster Startup Sequence | xravexboix | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 6 | 05-21-2012 07:36 PM |
