| Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
#57 | ||
A friend of mine is coming by in the next couple of days to do a photoshoot I'll post up everything in a new thread most likely. |
#58 |
Drives: 2jz
good choice on wheels, compliments the white
| The Following User Says Thank You to os86 For This Useful Post: | FreedE (08-01-2012) |
#59 |
Update. Low and a little bit of camber and wheels fit great. No rub... no fender mods etc. still DD
#60 |
OG <FR-S'less> Member
Drives: yes
someone has to say it. Pics or it didn't happen. Kidding, you know we all just want to see more of the car
#61 |
#62 |
Drives: yes
Oh, haha. I didn't realize you updated the original post. My bad. Drop looks good.
#63 |
How is the inner clearance in the front? Still got lots of room? Like oh lets say, 5 - 8 mm more? lol
#64 |
#65 |
#66 |
#67 |
Drives: Whiteout Scion FR-S
I am planning on getting the esm 004 wheels for my fr-s which are the same specs as these at 18x9 +38mm. I'm also dropping the car 1" on the eibach pro kit springs. My question is whether or not I should buy the 16mm whiteline camber bolts for this set up or if the drop would make the front wheels flush enough. What do you guys think? Is it necessary? I don't mind a slight poke.
#68 |
Drives: Raven Scion FR-S
so with the tires and wheels you have without the drop and camber, theres no rubbing or issues? bc i was thinking about getting 255/40/18 with a 18x9
HELPPPP im in desperate need before i order these haha and btw im getting winter tires to put on the stock rims for the winter only out here in NY bc i have to drive to school and what not... what size tire do you recommend ? http://www.wheeldude.com/catalog/pro...oducts_id=6330 |
#69 |
Shift Down
Drives: Toyota 86, Mazda RX7 RaceCar (FC3S)
off topic but what exhaust do you have sir?
#70 |
Drives: Toyota GT86
How do you feel the car with those wheels? It is slowly or is the same?
| Wheel Directory: Work VS-XX 18x9.0 +34/18x9.5 +39 | mav1178 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 09-13-2014 05:09 AM |
| Wheel Directory: ESM 004 18x9.0 +38 | beebo | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 37 | 06-13-2014 02:34 AM |
| Wheel Directory: Work Meister S1 3-Pc 18x9.5 +29 / 18x9.5 +24 | PradiG | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 48 | 12-12-2013 04:15 AM |
| Wheel Directory: XXR 531 18x9.5 +35 | DarrenDriven | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 07-10-2013 03:41 PM |
| Wheel Directory: SSR Professor SP3 18x9.0 +24 / 18x9.0 +20 | RZ86 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 23 | 05-18-2013 05:14 AM |
