Old 05-16-2013, 08:20 PM   #57
White_Lightning
Stuck in the Midwest
White_Lightning's Avatar
Drives: Whiteout FR-S, F-150, 69 Catalina
You really don't like this sound???
That's certainly a well executed setup. The induction noises sound really great on your car. It's just the exhaust note that I don't love. Is boost pressure vented on your setup? I've always been under the impression that if venting after the MAF, you risk running too rich. Although, I believe you're running more than stock spring pressure (6 psi?) so does that mean that you've converted to a MAP sensor? If that's the case then venting to atmosphere before hand wouldn't have any affect on the A/F ratio, correct?
White_Lightning is offline   Reply With Quote
The Following User Says Thank You to White_Lightning For This Useful Post:
Sportsguy83 (05-16-2013)
Old 05-16-2013, 08:41 PM   #58
NorseLegend
A Very Annoying Person
Drives: Subaru Impreza :( Hopefully BRZ
Damn that sounds so good.
NorseLegend is offline   Reply With Quote
The Following User Says Thank You to NorseLegend For This Useful Post:
Old 05-16-2013, 09:22 PM   #59
coyote
coyote's Avatar
Drives: Slowly
Someone Call Chris Harris and Tiff Needell!
Fixed. Clarkson is a better match for the guy in this video.
coyote is offline   Reply With Quote
The Following User Says Thank You to coyote For This Useful Post:
kanundrum (05-16-2013)
Old 05-16-2013, 10:34 PM   #60
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
It does affect A/F, and I run a bit rich when shifting, but my BOV is 50/50, so its really not that bad, and it can be tuned out to be of minimal impact. I ave an upgrade MAP sensor, but not running by speed density.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
White_Lightning (05-17-2013)
Old 05-16-2013, 11:34 PM   #61
NickFRS
Drives: 2013 Asphalt FRS
Gets Farah to drive car, car runs poorly, puts up for sale on eBay for $60k. Looks good.
No no no. It goes: Boost BRZ, Gets hit/hits another car on track and calls it a "fender bender", Spins a rod, puts car on ebay for $60k, and then gets Farah to drive the car which he calls him out on how it was running poorly.
2013 Sion FRS
2014 Subaru WRX
2014 Subaru XV
NickFRS is offline   Reply With Quote
Old 05-16-2013, 11:41 PM   #62
NorseLegend
Does anyone know if any of the kits, turbo or sc, are seeing sub 5-second 0-60s on pump (preferably 91 oct) gas?
Anyone at all? It's all I want to know...
Old 05-16-2013, 11:42 PM   #63
SmsAlSuwaidi
Boosted
SmsAlSuwaidi's Avatar
Drives: Not a supra....yet
with sticky tires, a hard launch most turbo kits are going to do that.
The Following User Says Thank You to SmsAlSuwaidi For This Useful Post:
NorseLegend (05-16-2013)
Old 05-16-2013, 11:52 PM   #64
NorseLegend
Yeah, I would hope. But it would be great to hear some first hand.
Old 05-16-2013, 11:58 PM   #65
nix
nix's Avatar
Drives: AVO BRZ
Tough crowd. Would be nice to hear what was going on with the engine though.
nix is offline   Reply With Quote
The Following User Says Thank You to nix For This Useful Post:
Sportsguy83 (05-17-2013)
Old 05-17-2013, 04:52 AM   #66
cf6mech
Drives: FRS Silver LS1 swapped.
Very simple and a secret that none of the turbo kit manufactures and tuners are willing to admit or share as they all want to be first to solve the issue,....this car was designed to be a sports car that gets good gas mileage,..the fuel system/lines etc. was not intended to run the volume that is needed boosted,...yah you can up the pressure but it needs volume to run boost say 15psi and above (guesstimate +/- a few psi and if your using pump or E85,..every application is different) What your hearing with Mr. Farrah is a lean condition, and it comes and goes depending on foot position on peddle and where the engine revs are,....my car does the exact same thing running at 18psi boost,... but will be solved very soon with a new customized fuel system that allows this engine the volume it needs to be boosted using Full Blowns fuel rails pressure regulator and customized lines. It means more investment if you want to go big with this car,...stay at 10psi and below you should be fine stock. Also what should be noted is the Crawford car horsepower numbers are crank not whp....
cf6mech is offline   Reply With Quote
Old 05-17-2013, 05:38 AM   #67
ft_sjo
Drives: GT86
The only two things which are relevant:
1) How much fuel flow do you need through the rails?
2) How much fuel can flow through the OE rails?
Do you have answers to these two questions?
Old 05-17-2013, 02:36 PM   #68
cf6mech
NEED SUBARU BRZ -TAILLIGHT TEST FIT TYPEONE86 Southern California 5 04-11-2013 07:54 PM
Video: Comparison between Scion FR-S and a Modded version by Matt Farah carbonBLUE FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 41 12-31-2012 10:03 PM
FR-S Review by Matt Farah Mari0 FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 27 08-07-2012 02:42 AM
