Old 05-16-2013, 09:25 AM   #29
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
Originally Posted by Tim_Asphalt_FRS View Post
I can't even get past the registration window. I put in the number for North America from the .txt file and the window just pops up again.
You replaced the executable file with the one included to bypass activation?
If so, just put the registration number in and press ok. After I did that I got a 3000 hr "license". Still useless with the cable drivers but I'm looking into sourcing a Windows XP laptop just for this.
No build thread. I don't want to be reminded of how much money I spent.
[insert profound quote here]
ecko04 is offline   Reply With Quote
Old 05-16-2013, 09:50 AM   #30
Trap63
Trap63's Avatar
Drives: Brz WRB - Europe LHD
Originally Posted by kmbkk View Post
So, will any OBD2 USB cable work?
This one fits and works very well.....
http://www.ebay.it/itm/121099762897?...84.m1497.l2649
Trap63 is offline   Reply With Quote
Old 05-16-2013, 10:58 AM   #31
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
I do have a really old laptop w/ Windows XP. I may have to just use it instead.
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 05-16-2013, 11:24 AM   #32
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
With what drivers?
Old 05-16-2013, 09:07 PM   #33
Gunman
Drives: 2019 Mazda Miata RF
Seems everyone is using the cable from China...I gotta say, I'd rather not order from China. Any US sources for the cable?
Would this cable work?
[ame="http://www.amazon.com/OBD2-Diagnostic-Cable-KKL409-1-VAG-COM/dp/B002WIN8VQ"]OBD2 OBD II Diagnostic USB Cable For KKL409.1 VAG-COM 409 : Amazon.com : Automotive[/ame]
Apologies, but I'm a noob when it comes to OBD2 stuff.
Old 05-18-2013, 02:07 AM   #34
michaelahess
michaelahess's Avatar
Drives: '13 GBS BRZ Lim, 2006 Dodge RAM MC
Cheap ebay cable works fine. I've been using this nearly since I got the car last July. All my laptops are win7 64bit so I just run xp mode and install the software in the vm. You can use any vm software, and then just find a copy of win xp if you don't already have one.
michaelahess is offline   Reply With Quote
The Following User Says Thank You to michaelahess For This Useful Post:
DoomsdayJesus (09-10-2013)
Old 05-18-2013, 02:09 AM   #35
michaelahess
Has to be a mini-vci j2534 cable.
Old 05-18-2013, 02:20 AM   #36
Sensisnow
Drives: 05 TSX & 13 BRZ
Mind posting a link to a compatible cable?
Sent from my Galaxy Nexus using Tapatalk 2
2013 DGM BRZ
Visconti STG2 FlexFuel Tune - aFe intake - Perrin resonated catback - P&L header, front pipe, & overpipe - Kartboy short shifter - Eibach prokit springs - Smoked sidemarkers - Full LED interior/exterior - Kenwood cmos-210 backup camera - Hardwired Valentine V1
Sensisnow is offline   Reply With Quote
Old 05-18-2013, 12:12 PM   #37
michaelahess
Ebay search for the above.
Old 05-19-2013, 10:51 PM   #38
Zagmeister
Zagmeister's Avatar
Drives: 2013 FR-S Ultrmarine MT
The ARM Processor is 32 bits on the MINI VCI 16Pin J2534 Cable
With what drivers?
If I understand it correctly, no software fix will make the J2534\USB cable connector work on 64 bit. The hardware processor (the big central black chip welded onto the J2534 board) is 32 bit.
So, I doubt that there will be a 64 bit drivers for that hardware. Please correct me if my understanding is inaccurate - thanks.
Zagmeister is offline   Reply With Quote
The Following User Says Thank You to Zagmeister For This Useful Post:
Trap63 (06-02-2013)
Old 05-20-2013, 12:18 AM   #39
Sensisnow
I would imagine that you could run 32-bit Windows XP in a virtual machine to make it work, or maybe even run the program in XP compatibility mode. I haven't tried either method though, so this is only a guess.
Old 05-20-2013, 03:53 PM   #40
Zagmeister
Zagmeister's Avatar
Yes of course, the VM option works.
My point was that waiting for a 64 bit software to work on the 32 bit ARM processor that is embedded onto the hardware is very doubtful.
The hurdle is the 32 bit hardware not the lack of a 64 bit software.
Old 05-20-2013, 04:22 PM   #41
ecko04
Seems Legit
ecko04's Avatar
Drives: Toyota
I don't believe the hardware is at all the hurdle as most 32 bit software will run fine on a 64 bit OS. The software will not run on a 32 bit version of Windows 7. So once again it's a fault of the mini vci drivers not being compatible with a modern OS (32 bit or 64 bit). There hasn't been an update for the antiquated drivers even though the Techstream software has been updated to work with modern operating systems.
This goes to show the mini vci was just a workaround from the beginning. As the actual hardware required to run the software, that the dealers use, is several thousand dollars.
So yes, a VM running XP will work but that wasn't the reason this thread was created as it ran on XP using older versions.
Old 05-26-2013, 10:24 AM   #42
Brett
First 86
Brett's Avatar
Drives: Whiteout MT FR-S
That's not how it works. The size of the processor's bus will not impact the ability of the two of them to talk to each other. Your mouse, for example, probably has an 8-bit micro, and it works with your 64-bit computer just fine. A 64-bit driver just means a driver that's designed to work on a 64-bit platform.
Brett
Don't shop, adopt!
Brett is offline   Reply With Quote
TPMS Tools developer Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 27 10-04-2021 02:28 PM
anyone with a shop or tools Tylub Southern California 0 05-14-2013 12:03 PM
Tools? Gost Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 35 04-03-2013 04:46 PM
Tools for DIY maintenance? F1point4 Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) 19 08-08-2012 08:47 PM
