Tuloy po kayo!
Drives: 2019 Toyota 86 TRD SE
Toyota Techstream on BRZ?
Has anyone tried to use the Toyota Techstream on a BRZ? I mean not on Generic OBD II, but in full use of the software?
I.G. @mytoy86
#2 |
Grip>Slip
Yes. Everything that worked on the FRS worked on the BRZ, although I didn't mess with the DRL settings at all.
#3 |
What he said. Techstream automatically recognizes the car as an FRS. There are some ECU versions that will not like DRL's being turned off (I think it kills the high beams). So far, other than looking at different engine parameters, I've only turned off the seatbelt chime for the drivers seat (for the times I wear a harness while autocrossing).
#4 | |
Drives: Firestorm FR-S
Check out my YouTube channel with Autocross videos: http://www.youtube.com/user/MrAreddi
#5 |
Red wine
Drives: Subaru BRZ(R.I.P)
I'm not familiar with it, but are you able to turn on airbags using techstream if you are using aftermarket seats?
#6 |
Grip>Slip
Usually you have to put a resistor in the stock seat harness so that the car thinks those airbags are operational. Haven't seen the details for doing it in this car though.
#7 |
Tuloy po kayo!
Wow, working at a Toyota dealer, I thought Having the Techstream would be one advantage of owning an FR-S, I guess not. Mechanical parts would also be the same, so the only thing that would push me away from the BRZ Limited is the outrageous mark-ups that I hope would be gone when it's time to buy on december.
I.G. @mytoy86
| Toyota TechStream Ver GTS_10.10.018 - Diagnostic Tools for FR-S/GT86/BRZ | Trap63 | Scion FR-S / Toyota 86 GT86 General Forum | 225 | 03-09-2024 03:53 AM |
| Toyota Techstream | xjohnx | Engine, Exhaust, Transmission | 206 | 08-20-2023 04:01 PM |
| TechStream TIS - No work | FRSFirestorm | Engine, Exhaust, Transmission | 19 | 07-10-2014 03:14 AM |
| Techstream ECU Options | mrjester | Electronics | Audio | NAV | Infotainment | 10 | 03-18-2013 10:24 AM |
