#183 |
Troll Feeder
Drives: boosted scion tc.
that cat is the size of a 28R
#184 |
Drives: 2009 BMW 335i
Hate the STS idea already
![]() AWE90/ZSP/ZPP/2XA/NAV/HID/DPE////M/EAS/Disma |
#185 |
Troll Feeder
i've always thought the STS is a bad idea due to the exposure to the elements. i think we all know the possible dangers that could cause.
#186 |
MODERATOR-SAMA
Drives: Swagtron Scooter
Apologies accepted, thanks Driftster for the response and explanation of your thoughts. I agree with you, there are going to be some challenges in locating a turbo. And the challenge is gives even more pressure to OEM because it must be reliable too. And thermal efficiency has plagued performance boxer engines for a long time (ej turbos specifically). Stupid uppipes, and locating a turbo so close to intercoolers. Stupid heat soak. Intake manifolds getting retardly hot. Thanks for bringing up remote turbos too, iv only heard bad things about those systems. So thats out the window.
So a Turbo BRZ, possible and likely?....yes. Easy with its current configuration?...no
#187 | |
Supra Owner
Drives: 1995 Toyota Supra UK Spec
Also, why do you say it wouldn't be very "safe"? Safe as in a crash? Safe as in melting the accessory belts, etc.? Or safe in some other way? Safe as in a crash - don't know how you would have come up with that one, so it's unlikely that would cause problems any more than any other car. Safe as in melting accessory belts - I'm sure it wouldn't be hard to make a heat shield to protect these. Also, once again, I've seen quite a few people mounting turbo's in V8's (one example I can think of is a Supra with 2UZ/Twin Turbo) with no apparent problems with melting belts or any other components. "Safe" in some other way - please explain? Agreed on the wouldn't be as efficient, but you're not adding too much header pipe, much less so than a remote mount turbo. I see no reason it wouldn't be doable, especially for the amazing minds at Toyota and Subaru.
#188 |
Drives: Slowly
Not only will it be doable, it will be relatively easy.
#189 |
Delights in pure handling
Drives: Zoom Zoom
#190 | |
MODERATOR-SAMA
EJ20 and EJ25 N/A guys know what im talking about.
#191 | |
MODERATOR-SAMA
at the expense of everyone else? hmm interesting im trying to understand what you mean. I really see where Toyota and Subaru are heading with the philosophy in this car. I mean if we are thinking of building a car specifically for the general population of tuners..this car would be completely different...and probably not even use a boxer engine. They really disliked the idea of turbos, and AWD, and all sorts of gadgets that could make power. They wanted to throw away the common sense items of a modern sports car and really go back to basics. Seeing it this way for the demographics of tuners..they threw away ALL modern tuners away..and wanted to flip the idea of sports car on its head. N/A tuning sounds to be the intent and focus for the best experience philosophically. AE86 did fall into this category.
#192 | |||||||
Supra Owner
I think this is where extra (enough) room would come in to mount a turbo. Quote:
I'm sure Subie/Toyota would come up with something more elaborate than that, but it shows it's easily fixable. Another option would be ceramic coating, which is also suppsoed to keep temps down, though I've never seen it myself. Quote:
#193 | |
Drives: gti, nsx, integra type r,porsche911
Yes i agree. Its like how porn has alot of botox, and surgeries and make up done now. Also photo shops and video editing. We should go back to the basics where its all natural baby:happy0180: and most people just can't stand it when its not artificial.
#194 |
Supra Owner
Firstly, a few points needs to be made about the compression ratio of this engine.
You imply you wanted it to be for "everyone", so people could choose what they wanted to do with the engine. You come across as though you're making this argument in a way that implies EVERYONE wants to turbo this motor. That is doing the exact opposite you want of this car. Making this car able to be turbo'd easily would require lowering the compression ratio, doing this would then mean the people that want to keep the car NA are shafted. If you then still wanted a decent power level (200hp NA) at that lower compression, Toyota/Subaru would have had to put a lot more time/money into developing a high-power low-compression NA engine, raising the cost of the car itself which then takes away the market of the car. Point 2 about DI - BECAUSE of the Direct injector cooling the cylinder + air/fuel mixture, you can have a higher CR without detonation. A good example of this is the IS-F, which I believe has a 13.5:1 static compression ratio? If 13.5:1 is the "limit" of an NA engine w/ DI before detonation, then this means this engine (4U-GSE/FA20) would be much more suited to a turbo than a port-injected engine running a 12.5:1 CR. It certainly isn't impossible to add a turbo at that compression ratio, it just means you can't run as much boost. Finally - IF someone plans to change the rods, in most cases I have seen, they also change the pistons - meaning your points about the shape of the piston are likely next to moot. With every new car that comes out there have been problems with modifications - In Lexus/Toyota's case, it's the ECU, with Nissan's GTR it was the gearbox and warranty. This car will be no different, and it will also be no different in the way tuners and modifiers come up with solutions to these problems. If the Direct Injection really does turn out to be a problem - block off the supply to the DI fuel rail... If the ECU doesn't cope with this well, replace it... If the piston causes problems when changing the rods, then swap the pistons out for flat ones, and swap the headgasket to lower the compression. I think you get my point. People will mod this car no matter what it takes, they wil continue to mod as they have done for a long, long time. And if it's all too much of a headache for you to be on the cutting-edge of modding, then find a different car!
#195 |
ლ(ಠ益ಠ)ლ
Drives: E36 5.7 V8
So swap an Ej207. I dont see the problem here.
I wish I was cool enough to have an FR-S
#196 | ||||||||
Drives: car
If this car never comes with a factory turbo engine then don't expect the platform to go anywhere in terms of power. Buy it for what it is, not for what you can make it. |
| New FR-S BRZ Technology Info! Engine specs, CoG, Drag Coefficient, Dimensions, etc. | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 584 | 08-28-2023 08:53 PM |
| Engine build | Maxim | Engine, Exhaust, Transmission | 41 | 10-03-2011 09:22 PM |
| Geneva Preview: Techart to debut 911 Turbo, Turbo S | vh_supra26 | Other Vehicles & General Automotive Discussions | 1 | 02-22-2010 06:20 PM |
| Super Bowl! | Midship Runabout | Off-Topic Lounge [WARNING: NO POLITICS] | 13 | 01-29-2010 04:02 PM |
| Super Lap Battle | S2KtoFT86 | Other Vehicles & General Automotive Discussions | 0 | 12-10-2009 09:46 PM |
