Old 05-12-2013, 07:29 PM   #71
Simmons
Simmons's Avatar
Drives: 2024 GR86/ 2015 FRS
Originally Posted by apexaddict View Post
More work done to the car yesterday.
Mostly, it was maintenance - fresh oil, new RS3s, a fluid change for the gearbox and diff, and corner-weighting the car. But I also threw in the Whiteline rear diff inserts and the positive shift bushing, which so far has been a huge mistake.
Not sure who else is running this combination (Simmons? Bill? George?), but I'm really irritated at all the noise and clunks created by these. I expected some noise, but not nearly as much as I got. The "shift feel" wasn't substantially improved, and definitely not enough to warrant all the noise and clunks.
The weirdest thing is that Sam put the same bushings in his car, and his car isn't anywhere near as annoying as mine is. The ONLY difference between our cars is that I have a muffler delete and he has a Perrin exhaust. Thinking that because the front pipe bolts to the trans mount, and I likely have more resonance in my exhaust in comparison to Sam, I put a little 1/4" rubber spacer where the trans mount bolts to the exhaust to try to dampen some of the resonance. This didn't help, so it's back to square one.
Has anyone else experienced this? I can't believe how much noise there is - there is enough that it has made the car very un-fun to drive around town. I was hoping that these bushings would help curb some of the wheelhop I was getting at the NJ Pro, but at this point, I'm not sure it's worth the awful drivability penalty. I'm probably going to pull the shifter bushing at the least, as soon as I have the time to.
I have the same noise, I thought it was the trans mount insert. I removed it the other day and the noise is still there.
Simmons
2024 GR86 71 STR/ 2015 FRS 71 STX
Sponsors Xero-Limit//Karcepts
Simmons is offline   Reply With Quote
Old 05-12-2013, 09:19 PM   #72
blkwrxwag
Drives: DS FRS
Are you guys talking about this thing?
http://www.rallysportdirect.com/Whit...rce=GoogleBase
blkwrxwag is offline   Reply With Quote
Old 05-12-2013, 09:21 PM   #73
blkwrxwag
Drives: DS FRS
Or this?
http://www2.kartboy.com/x4/product.p...6&bestseller=Y
Old 05-12-2013, 09:31 PM   #74
Simmons
Simmons's Avatar
I was talking about that, but like I said the noise is still there without it.
Simmons
Old 05-12-2013, 10:11 PM   #75
GTB/ZR-1
GTB/ZR-1's Avatar
Drives: '13 BRZ in WRB--let's mod!!!
I've not changed any of those pieces--so no noises here.
GTB/ZR-1 is offline   Reply With Quote
Old 05-12-2013, 10:53 PM   #76
apexaddict
Simmons
So it seems like the majority of the sound seems to be coming from the diff inserts, then. gah.
Andrew P.
#14 STX Scion FR-S - powered by Stranoparts and Moto-East
apexaddict is offline   Reply With Quote
Old 05-13-2013, 08:07 PM   #77
apexaddict
Originally Posted by dwx View Post
That's the first I've heard of excessive noise with them, but I'm not running them myself.
You guys do not have any clearance issues running the +45 RPF1s with 245/255? I thought Simmons was using a small spacer with his.
I'm debating on STX for next year right now and trying to figure out whether to do +35 or +45. In the end I'm not sure it matters a huge amount.
I missed this earlier. It doesn't really matter a huge amount, it depends on what you want. Scrub radius and tire fitment are better with the +45s, but they will rub the front sway bar slightly at absolute full lock with 245/40/17s and almost surely with 255s. +45s probably also won't clear the stock struts with any sort of camber at the knuckle.
+35s should fix all of those things but 255s are going to be a tight squeeze unless you run a lot of camber. They should clear big brakes, too. But they aren't as readily available as the +45s.
Personally, I think the answer is somewhere in the middle: +45s with some sort of spacer.
Andrew P.
Old 05-14-2013, 04:32 PM   #78
Sam Strano
Sam Strano's Avatar
Drives: 2013 FR-S Asphalt
I had the trans bushing and it wasn't an issue. I put my diff bushings in last week, before we did Andrew's car and it helped a lot with wheelhop, but it is much louder.
In fact I might play around with removing some of the diff bushings, maybe the top inserts on the rear to see how things change.
Sam Strano is offline   Reply With Quote
Old 05-20-2013, 08:17 PM   #79
Sam Strano
Sam Strano's Avatar
Andrew Pallotta and I got together yesterday at a Steel Cities SCCA Event to do a little tire testing and such. For now here are two runs from my car on Dunlop Z2's:
Me, 41.1:
[ame="http://www.youtube.com/watch?feature=player_embedded&v=6p5ZHKeqdz8"]2013 SCR #2 Strano - YouTube[/ame]
Andrew, 41.5 (though it was his first run in my car did run a non-recorded 41.0 later:
[ame="http://www.youtube.com/watch?feature=player_embedded&v=d--w48LlmvQ"]Andrew 20130519 - YouTube[/ame]
Andrew has other video from his car on the Hankooks, he ran a bunch of 40.9's and I ran a 40.89 something in his car.
Old 05-20-2013, 08:24 PM   #80
GTB/ZR-1
GTB/ZR-1's Avatar
You jokers are fast!
Nicely done...
Andrew is obviously more loose--did he get that squared away for his quickest?
My car seems to now have that under control w/o increasing push. VERY nice balance.
Old 05-21-2013, 11:26 AM   #81
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
No noises here..and I have everything but control arm done..congrats on you and Sams developement..
Bill
Scooby South is offline   Reply With Quote
Old 05-21-2013, 01:20 PM   #82
Simmons
Simmons's Avatar
I was thinking about doing the same thing, the noise just drives me crazy.
The Z2's get a lot better after the first event, I know Andrew didn't like them over the RS3's.
I am curios how they work in Lincoln, I know the RS3's work good out there.
Good luck to both of you in Lincoln.
Simmons
Old 05-21-2013, 02:07 PM   #83
jdrxb9
jdrxb9's Avatar
Drives: ND2, formerly BRZ (MT/CBS)
Andrew Pallotta and I got together yesterday at a Steel Cities SCCA Event to do a little tire testing and such. <snip>
Since I appear in these videos, I feel the need to reply and post slightly OT
For additional video posts (two more 86's and others), results link, etc from this event, see this thread: http://www.racepa.com/content/index.php?topic=9891.40
jdrxb9 is offline   Reply With Quote
Old 05-21-2013, 02:18 PM   #84
apexaddict
Nicely done...
That being my first run in Sam's car, I drove it the same way I drive my own, and the difference in power-down was immediately obvious. After some pressure tweaks and just getting more used to the balance of the car, I was able to do the 41.0. But that still couldn't match my own car on the Hankooks, which I know had more time in it.
My video from driving my own car:
[ame="http://www.youtube.com/watch?v=XG7s-MAut04"]SCR 5/19/13 - STX FR-S - Andrew - YouTube[/ame]
I have Sam's video and will post it up later once I edit it down.
Andrew P.
Ricepuddin's Build thread Ricepuddin Member's Car Journals 71 11-23-2019 11:22 PM
PC Build Thread WingsofWar Off-Topic Lounge [WARNING: NO POLITICS] 126 01-22-2017 10:59 PM
EOJ (Not much of a Build) Thread jonbatz01 Member's Car Journals 41 07-31-2013 08:34 PM
JoeBoxer FR-S build thread JoeBoxer Member's Car Journals 112 04-08-2013 02:19 AM
My Whiteout 6MT build thread... jadewbj Member's Car Journals 10 01-04-2013 05:10 PM
