alpine, ATL BRZ, ftc~brz, jamesm, King Tut, OrbitalEllipses, sklimo, SmsAlSuwaidi, Sportsguy83, whitefrs
Old 05-12-2013, 02:29 AM   #477
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
I think you don't understand what Duty Cycle means. Duty Cycle is a value that tells you the amount of time the injector is open when compared the amount of time it takes the engine to complete a revolution. That time will vary with each RPM. A lower duty cycle only tells you that the injector is opening very little time, which is a good thing. So to paraphrase your statement, To lower the duty cycle, you need bigger injectors.
With that in mind, from your statement, what that means is, to be at 80% duty cycle you need 640 cc injectors and to be at 65% duty cycle, you need 787 cc injectors. And again, those numbers do not apply to us because the DI system injects fuel at a high pressure, and takes the bulk of work off of the port injectors.
so basically all these calculators are useless for us. because the data each gives me is so far off from what makes sense. i think that may be whats throwing me off at least i know im on the right track even tho i didnt realize it lol. now if only i could find a way to incorporate DI into these dam equations
lbroskee is offline   Reply With Quote
Old 05-12-2013, 02:32 AM   #478
Sportsguy83
I Love custom Turbo kits
Sportsguy83's Avatar
Drives: Limited BRZ
The info you find on the internet in pages that say "injector calculator" do not apply to our cars because they consider a car that has ONLY port injectors.
I am showing you with hard data (my duty cycle), how far off are those calculators from our car. The DI pump is a Godsend
Old 05-12-2013, 02:35 AM   #479
lbroskee
lbroskee's Avatar
i see that. i know ur getting at least 300HP and only on 500CC. the difference is just too good to b true honestly
The Following User Says Thank You to lbroskee For This Useful Post:
Sportsguy83 (05-12-2013)
Old 05-12-2013, 02:42 AM   #480
killerkid08
Cool Stuff
killerkid08's Avatar
Drives: Cool Car
Using the calc,
70% at 8 psi - 7000 rpm
60% at 8 psi - 4600 rpm
All stock
killerkid08 is offline   Reply With Quote
The Following 2 Users Say Thank You to killerkid08 For This Useful Post:
lbroskee (05-12-2013), Sportsguy83 (05-12-2013)
Old 05-12-2013, 02:45 AM   #481
lbroskee
lbroskee's Avatar
Originally Posted by killerkid08 View Post
Using the calc,
All stock
thats on 550cc?
Old 05-12-2013, 02:46 AM   #482
Sportsguy83
Drives: Limited BRZ
thats on 550cc?
I believe All stock.
Sent from my HTC One X using Tapatalk 2
Old 05-12-2013, 02:48 AM   #483
lbroskee
lbroskee's Avatar
thats not bad at all. all this info makes me want to go buy an ECUTek cable and just sit in the car for hours reading data
Old 05-12-2013, 02:49 AM   #484
killerkid08
Cool Stuff
Drives: Cool Car
Lol., drive it and log it. Then study it. Double the pleasure, double the fun.
And yes, all stock.
The Following User Says Thank You to killerkid08 For This Useful Post:
Old 05-12-2013, 02:55 AM   #485
lbroskee
lbroskee's Avatar
And yes, all stock.
with FA20Club office literally 4 minutes from my house it's not very cost effective to buy it just for that tho lol
Old 05-12-2013, 02:56 AM   #486
killerkid08
Cool Stuff
Drives: Cool Car
Alright, enough thread jacking from me tonight. I'm gonna patiently wait for a new map with OB set to 12 psi and see where 9 and 10 consistently put the fueling % at. I will base that off what I have at 8, and that should give a decent gradient for fueling needs as boost pressure increases. (Kinda)
Old 05-12-2013, 09:56 AM   #487
Sportsguy83
Drives: Limited BRZ
Going 9-10 on stock fueling, man you got some balls. If it were my car, no chance in hell I risk it. Remember duty Cycle is not the only variable to look at for fueling needs, volume of gas injected is critical too.
IMHO.
Old 05-12-2013, 10:07 AM   #488
killerkid08
Cool Stuff
Drives: Cool Car
IMHO.
You may be right about that but if the ports have an additional flow of 10-15 safe range, why not tax them and see where they go? The gas here in GA is good, so I really don't have to worry about blowing up from crap gas. What's 1-2 more psi? Must push the bleeding edge for the masses. lol
Old 05-12-2013, 10:16 AM   #489
Sportsguy83
Drives: Limited BRZ
You may be tight about that but if the ports have an additional flow of 10-15 safe range, why not tax them and see where they go? The had here in GA is good, so I really don't have to worry about blowing up from crap gas. What's 1-2 more psi? Must push the bleeding edge for the masses. lol
Good points, very interested in your results.
The Following User Says Thank You to Sportsguy83 For This Useful Post:
killerkid08 (05-12-2013)
Old 05-12-2013, 10:21 AM   #490
killerkid08
Cool Stuff
Drives: Cool Car
Just waiting on J-V for the new map.
alpinewuzhere, better than sti, custom turbo kit ftw, epic brz build, ftc~brz, gtx30 goodness, its certainly a car, king tut, nocornnocare, sportsguy83, superior orbital fellow, thewheelsonthebusgo
Volk Racing TE37SL - Mag Blue/ Hyper Blue/ Flat Black/ Red/ Gold IN STOCK!!! Speed Element Wheels and Tires 151 09-26-2013 05:56 PM
Dream Mod For FR-S/BRZ JPxM0Dz Other Vehicles & General Automotive Discussions 22 03-08-2013 11:35 PM
Have You Had A Dream About Your Car? chanomatik Scion FR-S / Toyota 86 GT86 General Forum 7 01-29-2013 03:38 AM
Sonic Blue 86, Galaxy Blue deleted? 450hp/tonne AUSTRALIA 14 09-01-2012 08:10 PM
I had a dream... ashtray Off-Topic Lounge [WARNING: NO POLITICS] 1 03-13-2012 12:35 AM
