Old 05-11-2013, 10:31 PM   #5083
Deepseadiver
Drives: 2013 BRZ DMG manual Limited
Where do I find johns video?
Deepseadiver is offline
Old 05-11-2013, 11:23 PM   #5084
Deepseadiver
Originally Posted by Deepseadiver View Post
This may sound like a dumb question, but how do you switch between maps? About to flash my car for the first time . I did a search and checked out many threads, but 232 pages in one thread is a bit much.
Map 1 - Tune + Stock Rev Limiter
Map 2 - Tune + 8000RPM Rev Limiter in 2nd Gear + Launch Control + Flat Foot Shifting
Map 3 - Tune + 8000RPM Rev Limiter in 2nd Gear + Launch Control + Flat Foot Shifting + RaceRom Traction Control
Map 4 - Tune + 8000RPM Rev Limiter in 2nd Gear + Launch Control + Flat Foot Shifting + More Agreesive RaceRom Traction Control
Thanks!
Wow! Worked great, car has a bit more spunk now! Launch control worked great, not enough space to try FFS, better exhaust note, sad that I did no do this sooner! Next weekend Vortech kit will be installed if the plug and play harness arrives by then.
Thanks John and Rich!:happy0180:
The Following User Says Thank You to Deepseadiver For This Useful Post:
Sensisnow (05-12-2013)
Old 05-12-2013, 12:29 AM   #5085
Sensisnow
Drives: 05 TSX & 13 BRZ
I had quite a bit of fun with the new tune today as well, even with the pedal lag. I can't wait to get the flexfuel kit that I ordered!
You just got this tune and have a Vortech coming next weekend?!? I'm seething jealously right now! Have fun!
Sensisnow is offline
The Following 2 Users Say Thank You to Sensisnow For This Useful Post:
KamalT (05-12-2013), tripjammer (05-15-2013)
Old 05-12-2013, 01:17 AM   #5086
Mo707
Mo707's Avatar
I have a few questions on tunning. Its my first time and i plan on buy the stage 2 tune when i get back from LA next week.
1.) Do all these maps come with the tune?
2.) I heard you can only tune with windows xp, is this true?
3.) If I tune my car now with what i have on it and then I choose to get a new intake, exhaust or other performance part would i have to re-tune it?
Mo707 is offline
Old 05-12-2013, 09:14 AM   #5087
Opposed
Drives: 2013 Asphalt FR-S
Just go to Youtube and type in Visconti tuning. He has his own channel on there.
Asphalt FR-S: EcuTek Visconti STG2 tune, MAPerformance turbo kit, MAPerformance 3" exhaust, Hotchkis springs, Mach-V 17x9 Awesomes.
Build thread: http://www.ft86club.com/forums/showthread.php?t=30703
Opposed is offline
The Following User Says Thank You to Opposed For This Useful Post:
Deepseadiver (05-12-2013)
Old 05-12-2013, 02:08 PM   #5088
Sensisnow
This is his channel.
And this is the video you're looking for. The newest tune uses the tach instead of the check engine light though.
[ame="http://www.youtube.com/watch?v=nP4U7lmaUqc"]EcuTek RaceRom Map Switching V1 for BRZ/FRS - YouTube[/ame]
The Following User Says Thank You to Sensisnow For This Useful Post:
Old 05-15-2013, 12:26 PM   #5089
Visconti
Drives: 05 STi
Good news everyone..
Have a updated Pumpgas and ethanol tune for everyone
This new version of my tune just takes everything to the next level.
Please don't put in any tune request updates.
I hope to get caught up this weekend - if I do I'll announce the update on here and in my ticket system
I think everyone will be impressed.
-John
Visconti is offline
The Following 8 Users Say Thank You to Visconti For This Useful Post:
Cal3000 (05-16-2013), Calum (05-15-2013), CBR600RR (05-15-2013), cuddefred (05-15-2013), Opposed (05-16-2013), SkAsphalt (05-16-2013), tripjammer (05-15-2013), TyperRspec789 (05-16-2013)
Old 05-15-2013, 12:31 PM   #5090
xjohnx
Grip>Slip
xjohnx's Avatar
-John
John's been working on some very cool stuff. Can't wait to try out the latest update.
xjohnx is offline
Old 05-15-2013, 01:40 PM   #5091
djliquidsteele
Drives: Scion FR-S
Just so I have a better understanding of how this works, I have both Pump and E85 tunes. I have collected data a few times and received a final update for the pump gas. I have not done so for my E85 tune yet. 2 month old baby has and losing my job has put a huge damper on my drive time. So:
A) When I get the new pump gas tune, will I need to collect data again? Or is everything transferred over to the new tune.
B) I had planned on collecting some data on the E85 tune this weekend. Should I wait?
Thanks
djliquidsteele is offline
Old 05-15-2013, 02:35 PM   #5092
Foobar
SLO NO MO
Foobar's Avatar
Thanks
Whenever I get a new re-flash, I assume it's the base file for that particular configuration (local market, transmission, intake, fuel, FI/NA). So I give it a few days, run some logs, send it in, and see if I get any tweaks back. The last couple of times I sent in logs, no further tweaks were necessary. I suspect the tunes are getting refined enough that unless you change some in the equation like your intake, the latest flash files are pretty well-refined.
I'd wait on sending new logs until after you get the new file John's working on.
Foobar is offline
The Following User Says Thank You to Foobar For This Useful Post:
Visconti (05-16-2013)
Old 05-15-2013, 02:43 PM   #5093
tonystewart
tonystewart's Avatar
Drives: 2013 Scion FR-S Raven
Thanks John!
May'12 AT Raven, OFT V2, Perrin IntakeTube, Pulley & Overpipe,HKS Snorkel,FA20 EL Header,Nameless Frontpipe w/ Helmholtz, Crawford AOS, Cusco O2W Cooler, Grimmspeed Strut/MC Brace, Winjets w/D2S 3.0 HID by Illuminating Lighworkx, Fogs w/EU Stalk, LED's, JDM UnderPanels, Diffuser, Rigid Collars, Whiteline, HVT Camber Plates, Koni's, Swift Springs, GTSpec LCA, SPC Toearms, DBA 4K T-Slot Rotors, Ferodo DS2500, Vorshlag BrakeLines, MichelinPSS, 5Axis Wing, Raammat, Ensolite, JPM Coachworks, OEM+Ref400, 20mmspacers, TOMS
tonystewart is offline
Old 05-15-2013, 02:44 PM   #5094
CBR600RR
Drives: Raven Black
-John
Can you give us an idea as to what kind of changes we can expect?
Fuel Economy?
HP?
Torque dip?
CBR600RR is offline
Old 05-15-2013, 02:47 PM   #5095
CBR600RR
Drives: Raven Black
What kind of cool stuff?
CBR600RR is offline
Old 05-16-2013, 01:37 AM   #5096
Visconti
Drives: 05 STi
Everything lol
Visconti is offline
The Following 2 Users Say Thank You to Visconti For This Useful Post:
Sensisnow (05-16-2013), SkAsphalt (05-16-2013)
LED Front Signals with Resistor Flash Correctors DarrenDriven Cosmetic Modification (Interior/Exterior/Lighting) 38 09-20-2012 03:05 PM
Brz Info/Specs (helpful info for questions asked often) Gaen BRZ First-Gen (2012+) — General Topics 0 05-24-2012 11:09 PM
How to embed a flash gallery? DarrenDriven Site Announcements / Questions / Issues 2 04-24-2012 08:43 PM
Production Spec Subaru BRZ Previewed at National Conference & Latest Info/Rumors blur BRZ First-Gen (2012+) — General Topics 130 09-01-2011 02:42 PM
