| FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum All photos, videos and other media related to the Scion FR-S and Toyota 86 |
#211 | |
Drives: '23 CWP BRZ
So explain to me what's so "Honda Civic" about running beefy ass tires? |
#212 | |
I was referring to the stretched tire bullshit. I don't want to be anywhere near someone with stretched tires, that's unsafe as hell. |
#213 | |
It's all good though. To each his own and enjoy your "aggressive" fitment. Last edited by PRORICAN; 05-11-2013 at 04:56 PM. |
#214 | |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
![]() Also, current day f1 cars stretch their tires. You just don't notice it as much as the sidewalls are so tall.
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#215 |
Drives: Toyota 86
Can't believe people whinge when they see an 86/frs/brz with stretched tyres/low offset wheels, to be honest, most people buy this car because its cheap and decent looking, not because its a "track" monster... Why does it matter what people do. If you don't like it, keep your opinions to yourself.
#216 | |
Drives: '23 CWP BRZ
Edit: Actually, I'm gonna stop myself, don't respond. I don't want to turn this thread into more of a bitch fit than it already is, nor do I need to prove to everyone that I'm right. Just go look it up yourself. |
| The Following User Says Thank You to 636 For This Useful Post: | OmarGC (05-11-2013) |
#217 |
#218 | |
Go to that forum and "prove to everyone you're right" http://www.mazdaspeedforums.org/foru...ngerous-63938/ Or that one There is a reason a lot of shops won't do it. Your car handles like shit, it looks retarded etc. But the way you think you are right, you probably like the retarded shit. I never wanted to turn this into a "bitch fit". I stated something, and you had to act like a smartass and think you are right before actually researching yourself. I'm done. Don't bother. |
#219 | |
86DESU
Drives: 86 GTS, S13, CB9
Let's not over-state what is "needed", shall we? Anything over 2 degrees of negative camber is for looks, not performance. So anything that requires anything like that for fitment is definitely an aggressive fitment, and it only takes 8" at +35 to run flush besides. If you want "stanced", say "stanced". If you're after a look, spit it out, we're not mind readers. Nobody, and I repeat nobody, has enough power in one of these to warrant anything over 265s for grip. If you put 265s on one of these that's standard you are slowing it down badly-- rolling resistance goes up hugely with each 10mm of width-- Road and Track proved this when they slowed their car down putting an oversize width tyre on it. Suspension changes and minor brake upgrades won't require more than 10mm of extra tyre. Be real, dude.
Careful. It's contagious!
#220 | |
My FR-S has 5 gears
The post you quoted above had nothing to due with tires genius. I was speaking of the amount of camber here. If you think anything above 2 degrees of negative camber is "just for looks" you either 1) don't track your car(s). 2) dont track your car often, don't do well at technical courses and majority of track layouts, and probably produce shitty #'s. Stop being full of yourself, dude.
Omar GC
#221 | |
Drives: '87 Corolla GTS, '13 FR-S 6MT
Current F1 rules say wheels and tires can be up to 355 front and 380 rear. I seriously doubt teams would leave grip on the table just to "stretch" their tires. Sent from my Nexus 4 using Tapatalk 2 |
#222 | |
86DESU
Even up front you can use caster to reduce the amount of camber without reducing available grip (read; tread appication) in corners, to an extent, and that reduces roll off (and again, excessive tyre wear and uneven temperatures). We talking serious, street, or sprints? Because sprints are all well and good, and those setups work for Sprint or AutoX, but I was talking street. Where more than 2 degrees is pretty much pointless except for looks. Unless you hate tyres, of course, which is fine. Either way, I'm sure we can all agree demon camber -is- just for looks.
| The Following User Says Thank You to Nezz For This Useful Post: | OmarGC (05-11-2013) |
#223 | |
Drives: '23 CWP BRZ
Oh yeah, still waiting for real evidence. |
#224 |
Drives: Whiteout 6spd
Now kids, can we go back to pics..
| The Following User Says Thank You to KAR For This Useful Post: | SLICVIC (05-28-2013) |
| Tags |
| dontlike?dontlookmoveon |
| Post the Wheels You want On your FRS/BRZ!! | Zaku | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 1738 | 10-11-2017 05:29 PM |
| RPF1 and PF01 aggressive fitment size requests | Crossover Auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 12 | 10-22-2012 03:30 PM |
| post VIN with any problem thread? | fistpoint | Issues | Warranty | Recalls / TSB | 0 | 10-04-2012 11:11 PM |
| Do aggressive offsets cause more debris to kick up into the paint? | switchlanez | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 7 | 09-26-2012 11:03 PM |
| Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! | Hachiroku | Scion FR-S / Toyota 86 GT86 General Forum | 538 | 06-15-2011 03:20 AM |
