go_a_way1
Old 05-11-2013, 12:15 AM   #211
636
636's Avatar
Drives: '23 CWP BRZ
Originally Posted by Logical View Post
I just don't understand why people want "aggressive wheel fitment" on a FR-S/BRZ. It's a sports car, not some Honda Civic or anything. I especially laugh at the ones that make a damn 4x4 Subaru STI into something with "aggressive wheel fitment".
But to each their own..... I guess?
Aggressive wheel fitment can be both stanced with stretched wheels, etc. Or something with really wide wheels, and tires to match.
So explain to me what's so "Honda Civic" about running beefy ass tires?
636 is offline   Reply With Quote
Old 05-11-2013, 12:19 AM   #212
Brndn704
Brndn704's Avatar
I wasn't referring to the wide wheels with tires to match, that's understandable if you have the power to throw down with it.
I was referring to the stretched tire bullshit. I don't want to be anywhere near someone with stretched tires, that's unsafe as hell.
Brndn704 is offline   Reply With Quote
Old 05-11-2013, 12:25 AM   #213
PRORICAN
PRORICAN's Avatar
Originally Posted by OmarGC View Post
@PRORICAN, @Shit Luck Nobody is saying excessive amounts of camber or stretched tires... Are they? Just saying 9.5 +40 isn't aggressive, flush when below -2 camber ya... But anyone that is using this car for it's "intended purpose" is going to be needing and using a lot more then that.
You can fit a 18x10 SQUARED +30-40 with decent sized rubber on this car. You just gotta be competent enough and anal to know how to make your setup fit. You probably never seen my prior vehicles though, I'll just say everyone tells me I make my car fit my wheels/tire and not the other way around.
I consider a wide ass crappy, not grippy on a rim a little ridiculous. You yourself have stated you have those shitty 265's on your wheels because you like the look, correct @PRORICAN? To be fair that's just as dumb as the guys running mild stretches on their wheels because they think it looks cool... Just sayin'
They may not be the greatest summer tires but they're still summer tires. Cheap or not they still out grip the stockers I replaced and any all season tire. I don't run this set up on the track so ultimately it doesn't matter if I have super grippy r compounds or some high priced low thread wear rating tire. It's a daily!
It's all good though. To each his own and enjoy your "aggressive" fitment.
PRORICAN is offline   Reply With Quote
Old 05-11-2013, 12:41 AM   #214
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
Totally unsafe
Also, current day f1 cars stretch their tires. You just don't notice it as much as the sidewalls are so tall.
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 05-11-2013, 12:46 AM   #215
blags
Drives: Toyota 86
Can't believe people whinge when they see an 86/frs/brz with stretched tyres/low offset wheels, to be honest, most people buy this car because its cheap and decent looking, not because its a "track" monster... Why does it matter what people do. If you don't like it, keep your opinions to yourself.
blags is offline   Reply With Quote
Old 05-11-2013, 01:05 AM   #216
636
636's Avatar
Drives: '23 CWP BRZ
Lost my shit at you saying stretching tires is unsafe. Where's this SOLID EVIDENCE that running a stretched tire is any more unsafe than a non-stretched?
Edit: Actually, I'm gonna stop myself, don't respond.
I don't want to turn this thread into more of a bitch fit than it already is, nor do I need to prove to everyone that I'm right. Just go look it up yourself.
The Following User Says Thank You to 636 For This Useful Post:
OmarGC (05-11-2013)
Old 05-11-2013, 06:35 AM   #217
Brndn704
Brndn704's Avatar
This right here.
Old 05-11-2013, 06:43 AM   #218
Brndn704
Brndn704's Avatar
http://tl.acurazine.com/forums/showthread.php?t=718800
Go to that forum and "prove to everyone you're right"
http://www.mazdaspeedforums.org/foru...ngerous-63938/
Or that one
There is a reason a lot of shops won't do it. Your car handles like shit, it looks retarded etc. But the way you think you are right, you probably like the retarded shit.
I never wanted to turn this into a "bitch fit". I stated something, and you had to act like a smartass and think you are right before actually researching yourself.
I'm done. Don't bother.
Old 05-11-2013, 07:20 AM   #219
Nezz
86DESU
Nezz's Avatar
Drives: 86 GTS, S13, CB9
@PRORICAN, @Shit Luck Nobody is saying excessive amounts of camber or stretched tires... Are they? Just saying 9.5 +40 isn't aggressive, flush when below -2 camber ya... But anyone that is using this car for it's "intended purpose" is going to be needing and using a lot more then that.'
Err, I'm going to go ahead and disagree with you there. 225 is more than enough for spirited driving with this car as standard, modified to sticky rubber of course-- If you've turbocharged it and you're running highly aggressive brakes I still see no need to go over 245.
Let's not over-state what is "needed", shall we? Anything over 2 degrees of negative camber is for looks, not performance. So anything that requires anything like that for fitment is definitely an aggressive fitment, and it only takes 8" at +35 to run flush besides. If you want "stanced", say "stanced". If you're after a look, spit it out, we're not mind readers.
Nobody, and I repeat nobody, has enough power in one of these to warrant anything over 265s for grip. If you put 265s on one of these that's standard you are slowing it down badly-- rolling resistance goes up hugely with each 10mm of width-- Road and Track proved this when they slowed their car down putting an oversize width tyre on it. Suspension changes and minor brake upgrades won't require more than 10mm of extra tyre.
Be real, dude.
Careful. It's contagious!
Nezz is offline   Reply With Quote
Old 05-11-2013, 07:31 AM   #220
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Be real, dude.
The post you quoted above had nothing to due with tires genius.
I was speaking of the amount of camber here. If you think anything above 2 degrees of negative camber is "just for looks" you either 1) don't track your car(s). 2) dont track your car often, don't do well at technical courses and majority of track layouts, and probably produce shitty #'s.
Stop being full of yourself, dude.
Omar GC
Instagram: 2jzus
Old 05-11-2013, 09:24 AM   #221
RiskyTrousers
RiskyTrousers's Avatar
Drives: '87 Corolla GTS, '13 FR-S 6MT
Totally unsafe
Really?
Current F1 rules say wheels and tires can be up to 355 front and 380 rear. I seriously doubt teams would leave grip on the table just to "stretch" their tires.
Sent from my Nexus 4 using Tapatalk 2
RiskyTrousers is offline   Reply With Quote
Old 05-11-2013, 09:40 AM   #222
Nezz
86DESU
Nezz's Avatar
Up front, sure, I'd run more than two degrees to get good times (The Silvia runs 2.25 from memory) Anything more than that out back (Silvia's 1.25) and I'd see excessive and uneven tyre temperatures (cracking, delaminating), accelerated tyre wear and difficulty with grip (Not much point in having 200+mm of contact patch if there's only weight on 100mm of it).
Even up front you can use caster to reduce the amount of camber without reducing available grip (read; tread appication) in corners, to an extent, and that reduces roll off (and again, excessive tyre wear and uneven temperatures).
We talking serious, street, or sprints? Because sprints are all well and good, and those setups work for Sprint or AutoX, but I was talking street. Where more than 2 degrees is pretty much pointless except for looks. Unless you hate tyres, of course, which is fine.
Either way, I'm sure we can all agree demon camber -is- just for looks.
The Following User Says Thank You to Nezz For This Useful Post:
OmarGC (05-11-2013)
Old 05-11-2013, 10:18 AM   #223
636
636's Avatar
Drives: '23 CWP BRZ
Or that one
Oh, because there's so much clear evidence supporting why stretching tires(even slightly) is dangerous. Those two posts proved absolutely nothing at all. Nothing. And all the people claiming curb damage and such, unless you're retarded, or just don't pay attention to the road, you're not gonna curb.
Oh yeah, still waiting for real evidence.
Old 05-11-2013, 10:46 AM   #224
KAR
Drives: Whiteout 6spd
Now kids, can we go back to pics..
KAR is offline   Reply With Quote
The Following User Says Thank You to KAR For This Useful Post:
SLICVIC (05-28-2013)
dontlike?dontlookmoveon
Post the Wheels You want On your FRS/BRZ!! Zaku Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 1738 10-11-2017 05:29 PM
RPF1 and PF01 aggressive fitment size requests Crossover Auto Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 10-22-2012 03:30 PM
post VIN with any problem thread? fistpoint Issues | Warranty | Recalls / TSB 0 10-04-2012 11:11 PM
Do aggressive offsets cause more debris to kick up into the paint? switchlanez Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 7 09-26-2012 11:03 PM
Scion FR-S / Toyota FT-86 / Subaru with Aggressive Body & High Wing! + VIDEO! Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 538 06-15-2011 03:20 AM
