Old 09-05-2012, 11:53 AM   #15
truenosan
truenosan's Avatar
Drives: 13 Firestorm FRS
If that airbag light is the same as Imprezas, you can buy a test plug from Subaru, which clicks in properly, and will cancel out the light.
I've had my resistor pop out many times on my WRX, and the airbag didn't deploy. From what I know, if there is a break in the airbag circuit, the airbags wont work.
truenosan is offline   Reply With Quote
Old 09-05-2012, 11:57 AM   #16
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
How did you secure the resistor? Also do have a link for the plug?
Sent from my Galaxy Nexus using Tapatalk 2
Ricepuddin is offline   Reply With Quote
Old 09-05-2012, 04:54 PM   #17
truenosan
truenosan's Avatar
hope this helps
Old 09-25-2012, 12:50 PM   #18
Hanakuso
hope this helps
Do these work for our FRS/BRZ? I believe this is the OEM Subaru resistors right?
Hanakuso is offline   Reply With Quote
Old 09-25-2012, 05:32 PM   #19
truenosan
truenosan's Avatar
I'm not sure if they work for the FRS/BRZ. They are OEM Subaru resistors, so it's possible that they may work. However, I haven't tested them, nor am I responsible for the outcome.
Old 02-05-2013, 07:13 PM   #20
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
I know this is an old post, but how do you unplug the yellow airbag plug under the seat? I need to remove the passenger seat and can't get it. I pushed on the whit button part and it slid forward but is there a secondary lock mechanism? Help.
Cade01 is offline   Reply With Quote
Old 02-05-2013, 07:59 PM   #21
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
It was awhile ago but I all i remember doing was pushing down and pulling out. I'll try to check my passenger seat tomorrow, and if I cant' get to it I can check the seat that is out this weekend.
Old 02-05-2013, 08:05 PM   #22
Cade01
Cade01's Avatar
I got it figured out, i just wasn't pushing the button in quite far enough to release completely, poked it with a small screwdriver and it came right out. Thanks though.
Old 03-14-2013, 01:57 AM   #23
BRZ NA
Drives: WR blue
Warnings:
1)Always disconnect the battery when dealing with Airbags.
2) I am not responsible if you damage your car or yourself during this install
I am assuming if your doing this DIY you have already figured out how to remove the seats and disconnected the the battery and the wires connected to the seat.
First thing you need is a Resister with a resistance of 3.3 Ohms.
Amazon.com: 3.3 Ohm 1W Flameproof Resistor 10 Pcs.: Electronics
Locate the yellow harness .
You will notice that there are only 2 wires connected to the harness but are 4 holes (sorry the picture doesn't really show it, i'll try to get a better one before Install the seat tomorrow morning), you want to plug the resistor into the bottom two holes.
No it does not matter which side of the resistor you plug into which hole.
See no light
Please let me know if I am unclear on anything as I may have had a few beers before writing this :happy0180:, though this is pretty self explanatory and hard to screw up.
Also I am just going to use electrical tape to secure it for now, later I will find the other end of the connector and solder the resistor to that, and insulate it with shrink wrap.
so did you find the connector yet? and do you have to disconnect the battery before you plug in the 3.3 ohms resistor?
BRZ NA is offline   Reply With Quote
Old 03-14-2013, 04:34 PM   #24
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Just the JDM TRD one that's priced ridiculously. I did, and I would suggest it.
Old 03-17-2013, 07:56 PM   #25
BRZ NA
Drives: WR blue
Cool thx
Old 05-09-2013, 08:54 PM   #26
TouchMyHonda
Vtec Jesus
TouchMyHonda's Avatar
http://www.rallysportdirect.com/Spla...aru-Mitsubishi
Should this work?
TouchMyHonda is offline   Reply With Quote
Old 05-10-2013, 10:14 AM   #27
jadewbj
jadewbj's Avatar
Just keep in mind that will work for the drivers seat but not 100% for the passenger. We ran into this when we put my seats in.
The passenger seat has the seat senor in it and the car wants it to be plugged in. When we did the resistor in the passenger airbag the car took a few seconds and threw the airbag light and the passenger airbag was set to off. You can not put a resistor in the seat sensor, does not work.
The only way we were able to fix it was to remove the little seat sensor out from under the seat cover. We thought about putting it inside the Evo seat but taking the cover off the evo seat is a lot harder. So we just took it, folded it up and tucked it under the carpet. Now the car throws no lights and the passenger airbag is always on.
I have to keep the seatbelt plugged in to stop the nanny warning so I ordered the techstream software because they said you can shut that off with it.
If I ever get the seats recovered I will have the sensor put in it.
My blog explains it all:
http://www.jadecrew.com/custom-recar...seats-in-fr-s/
jadewbj is offline   Reply With Quote
Old 05-10-2013, 11:45 AM   #28
Ricepuddin
Get a Bowl
Ricepuddin's Avatar
Drives: 2017 BRZ PP
Originally Posted by TouchMyHonda View Post
no idea, in theory it should as the ohms are correct but I don't want to miss lead you
Thank you.
@dpgdave here you go good sir
Sent from my SCH-I605 using Tapatalk 2
Light Weight Seats sw20kosh Tracking / Autocross / HPDE / Drifting 23 11-06-2012 11:15 PM
Aftermarket Seats sets off SRS light? Hanakuso Cosmetic Modification (Interior/Exterior/Lighting) 1 08-25-2012 05:09 PM
Risk Racing Light Mine Professional Magneti - Magnetic mini light fixture! DjDATZ Off-Topic Lounge [WARNING: NO POLITICS] 0 06-28-2012 11:21 AM
FR-S / BR-Z Racing Seats!!! vividracing Interior Parts (Incl. Lighting) 8 06-19-2012 08:07 PM
