Old 05-08-2013, 05:39 PM   #29
zoomzoomers
zoomzoomers's Avatar
Will someone be kind enough to post on how to tell if it is or isn't activated and if it's not activated, how to do so?
Old 05-08-2013, 11:12 PM   #30
BRZnut
Drives: BRZ DGM Limited
sure....open with window/ get out/ lock the door with the key fob or handle/ walk away and put the key far away from the car so the car can not " see" it/ come back to the car in 2 mins/ reach through the open window and open the car door/ if you have the alarm activated, the horn and lights will flash! Then the crickets come out from under the hood and attack you!!
Old 05-09-2013, 01:25 AM   #31
Brzetto
Drives: 4 wheels
When the alarm is activated does it still do the beep thing or is that replaced with the horn?
Brzetto is offline   Reply With Quote
Old 05-09-2013, 05:01 PM   #32
zoomzoomers
So I tried the procedure and confirmed that mine is on. Single honk. But when I tried to trigger the alarm by putting my keys in a far place and open the door from the outside nothing happened. Am I missing something?
Old 05-09-2013, 10:35 PM   #33
BRZnut
Make sure you lock the car and wait a few mins before you open the door through the open window. If nothing happens your alarm is off (or you dont have it)
The Following User Says Thank You to BRZnut For This Useful Post:
zoomzoomers (05-09-2013)
Old 05-09-2013, 10:42 PM   #34
Jayde
Jayde's Avatar
Mine has always done the beep, with both the alarm activated and deactivated.
Jayde is offline   Reply With Quote
Old 05-09-2013, 11:05 PM   #35
zoomzoomers
I thought that all BRZ limited versions have the alarm?
Old 05-09-2013, 11:11 PM   #36
Jayde
Jayde's Avatar
They do, but you have to turn it on most of the time.
Old 05-10-2013, 04:02 PM   #37
Brzetto
Drives: 4 wheels
Mine beeps when I lock it so I don't know if the alarm is on or not.
Old 05-10-2013, 05:43 PM   #38
The359
X Rated
The359's Avatar
Drives: 2017 BRZ Series.Yellow
Another helpful hint for those with an automatic transmission trying to activate the alarm - the handbrake must be on!
NULLA TENACI INVIA EST VIA
My BRZ
The359 is offline   Reply With Quote
The Following User Says Thank You to The359 For This Useful Post:
zoomzoomers (05-10-2013)
Old 05-10-2013, 08:44 PM   #39
zoomzoomers
So even though I went through the entire process, it wouldn't have worked because I didn't have the handbrake on? WTF?!
Thanks I'll try it again with it on.
Old 05-10-2013, 09:06 PM   #40
The359
X Rated
The359's Avatar
Yeah, I tried maybe five or six times without success, then I thought that pulling the parking brake would help, since it's also required when using the Nav System. And it worked on the first try after that.
My BRZ
Old 05-10-2013, 09:54 PM   #41
BRZnut
Odd..my handbrake was off when I activated it
Old 04-05-2016, 05:39 PM   #42
wwilder9
Drives: 2016 BRZ
Had the car a month, Just turned on the alarm, Thanks for the information.
wwilder9 is offline   Reply With Quote
How to activate brz limited alarm Lee358 DIY (Do-It-Yourself) Guides 129 05-17-2024 08:21 AM
Activate your alarm!! engee NY / NJ / CT / PA 10 06-09-2015 12:45 PM
Forget Mercedes AMG...Here's Toyota with... davey90 AUSTRALIA 4 06-23-2012 10:46 AM
0-60 mph - forget handling ability for 5.9 seconds ahausheer Scion FR-S / Toyota 86 GT86 General Forum 227 04-04-2012 12:23 AM
Forget the NA vs Turbo debate!!!! Midship Runabout Engine, Exhaust, Transmission 69 04-05-2011 05:24 PM
