Old 05-07-2013, 08:18 PM   #1947
mike_ekim1024
mike_ekim1024's Avatar
Drives: Argento Scion FR-S
Added a Hotchkis front brace and Rexspeed hood dampers last week. Took off the Hotchkis sticker because I'm going for a "stock+" look. Not so thrilled with the hood dampers - the brackets need to be at an angle or else the dampers touch the inside of the fender. Also, the sticky tape looks a bit tacky (no pun intended). Will probably go for Grimspeeds instead.
mike_ekim1024 is offline   Reply With Quote
The Following User Says Thank You to mike_ekim1024 For This Useful Post:
WRXGuy1 (05-08-2013)
Old 05-07-2013, 08:26 PM   #1948
sklimo
Installed front diffuser!
RazBRZ (05-07-2013)
Old 05-07-2013, 08:32 PM   #1949
2point0
2point0's Avatar
Drives: '13 BRZ Ltd WRB
Today I installed a set of wheels in the back of my BRZ...does that count? If it helps, they were just done getting powdercoated!
Originally Posted by mike_ekim1024 View Post
Not so thrilled with the hood dampers...Will probably go for Grimspeeds instead.
You will NOT be disappointed with the GS dampers. They're quality and the brackets are well thought out.
Which one is that? Doesn't look pointy enough to be the HTAutos one.
2013 BRZ Limited - SOLD
2008 Forester XT Sports
1967 Mustang Coupe - 289 V8
2point0 is offline   Reply With Quote
Old 05-07-2013, 08:39 PM   #1950
sklimo
Got it from @JonMotoring on forum
2point0 (05-07-2013)
Old 05-07-2013, 09:02 PM   #1951
sklimo
@2point0 The fitting is damn near perfect for a $135 mod. You gotta drill and remove some hardware to access top of inside of bumper to attach with the included nuts and bolts. But nothing too crazy. May want to get extra washers as I needed! All in all very very happy with the way it looks.
Old 05-07-2013, 09:04 PM   #1952
Wonderbar
Driveway labs.
Wonderbar's Avatar
Drives: '13 BRZ Limited, 6sp, SWP
Attachment 36492
Attachment 36493
That looks great! I'm saving up for either the chargespeed or the vis.
-'13 Subaru BRZ Limited, SWP. (Mods: Driveway Labs full aero, MCA, etc)
-'06 Mitsubishi Eclipse 3.8L, UV blue. (Mods: turbocharged, full suspension, too much to list)
-'13 Town and Country Limited (Mods: too many kids)
Wonderbar is offline   Reply With Quote
The Following User Says Thank You to Wonderbar For This Useful Post:
sklimo (05-07-2013)
Old 05-07-2013, 09:09 PM   #1953
Scooby South
Conedancer
Scooby South's Avatar
Drives: 2013 Subaru BRZ SWP
Plasti-dipped my rear emblems.. Meh.. apparently I suck at all things that require patience..:/ ..looks like ass for the most part.. will retry and do it again I guess.. 5 coats and let it dry fully.. How do you get rid of the rough edges??? :/
Scooby South is offline   Reply With Quote
The Following User Says Thank You to Scooby South For This Useful Post:
RazBRZ (05-07-2013)
Old 05-07-2013, 09:39 PM   #1954
Bones36
Bones36's Avatar
Drives: 13 Brz Jrsc
Bayson r lip
Bones36 is offline   Reply With Quote
The Following User Says Thank You to Bones36 For This Useful Post:
sklimo (05-07-2013)
Old 05-07-2013, 09:53 PM   #1955
spdfreak
spdfreak's Avatar
Drives: GBS BRZ Limited
Put in those damn grommets found in the glove compartment. WTF Subaru. Had I not signed up here I would have had no idea.
spdfreak is offline   Reply With Quote
Old 05-07-2013, 10:04 PM   #1956
sklimo
Sorry but what grommets? None were in mine when i got her
Old 05-07-2013, 10:10 PM   #1957
spdfreak
spdfreak's Avatar
http://www.ft86club.com/forums/showp...3&postcount=42
Next time you're under your car just check for two oval seals just in front of the rear tires. The dealer is supposed to install them prior to delivery. Yours might already be installed.
The Following User Says Thank You to spdfreak For This Useful Post:
sklimo (05-07-2013)
Old 05-07-2013, 10:27 PM   #1958
Rinzler
Rinzler's Avatar
Drives: BRZ Limited
yuppo.. I had those and the rim locks in my glove compartment, both already opened and installed by the dealer.
Rinzler is offline   Reply With Quote
Old 05-07-2013, 10:28 PM   #1959
sklimo
Thanks bud! Just crawled under. They are in.
Old 05-07-2013, 10:54 PM   #1960
RazBRZ
Cones are bad
RazBRZ's Avatar
Drives: 2013 BRZ Premium
I did a lot.
RazBRZ is offline   Reply With Quote
The Following 2 Users Say Thank You to RazBRZ For This Useful Post:
Scooby South (05-08-2013), sklimo (05-07-2013)
