Member of the year - 2016
Drives: Scion FRS
Drill a hole in the taillights?
Anyone do this yet?
Worked well? I know its universally known to work well but I've seen a few times it hasn't done anything. YES, to fix the condensation problem. Thanks.
#2 |
Drives: TRD Ultramarine '13
| The Following 18 Users Say Thank You to kALMIGHTY For This Useful Post: | @Art_Mighty (05-03-2013), Anthonytpt (05-02-2013), AZOOZ_95 (05-27-2013), B L U E S L A T E (05-13-2013), BlaineWasHere (05-02-2013), CaptainSlow (05-03-2013), Deepseadiver (05-03-2013), dem00n (05-02-2013), deucethemoose (05-03-2013), ericmpena (01-24-2014), flippy (07-23-2013), Guillaume (05-03-2013), jbsali (05-03-2013), Jesse (05-04-2013), LeeMaster (05-03-2013), microbionic (05-03-2013), NickFRS (05-03-2013), Tylub (05-03-2013) |
#3 |
Drives: FR-S MT & FJ Cruiser
To fix the condensation problem?
Some will fall in love with life and drink it from a fountain That is pouring like an avalanche comin' down the mountain |
#4 |
Drives: Scion FRS
No, to let the magical butterflies free.
Why else would you drill a hole in your taillights? Extra 25HP?
#5 |
Drives: 2013 Subaru BRZ Limited SWP
To lower the drag? But can't the dealer just replace the taillights if you have a condensation problem, on a side note my old ae86 use to get water in the tail light and I drilled a tiny hole in the bottom and problem was fixed, but I mean with a 2013 frs/brz I would expect the warranty to cover the issue.
#6 | |
Drives: Scion FRS
Ha, i even changed it to thicker gaskets, didn't work.
#7 |
#8 | |
Drives: Scion FRS
The only problem besides the door rattling is the taillights. The best part is that this has cost me money. The gaskets and adhesive cost money (I'm not blaming the person who made the DIY of the gaskets, i do thank them for trying, it might also be my fault.), also the third time i went to the dealership they changed my Oil when i had only 1,000 miles of brand spanking new Motul and Oil Filter. When i clearly asked them to not touch anything and not to change my oil. Also lets not forget that it takes an hour of waiting every time to change taillights. I've never gotten mad at a car part before. For now, its only the driver side, but I've seen in the morning the passenger side get a small hint of water.
#9 |
Grip>Drift
Drives: FRS
Wouldn't drilling into the taillights cause a condensation problem?
#10 | |
Drives: Scion FRS
I don't know, i'm just afraid i'll fuck it up, taillights aren't cheap....
#11 |
Drives: 2013 FRS/01 Tacoma
I would say don't drill only because it will void the warranty on that light and who knows they may just come out with the right fix one day and if you drill holes they won't replace it.
#12 | |
| The Following User Says Thank You to sho220 For This Useful Post: | CodyFRS (05-19-2013) |
#13 |
Toyota Freak
Drives: Whiteout FRS
get aftermarket ones..
#14 |
It isn't a permanent solution, but a quick fix is to go to your local drug store and ask for some silica packets (they get a bunch of them with shipments of meds). Then just glue or tape one to a string (or use a needle to thread it through and back up on itself)...remove one of the bulbs, slide the silica packet in the hole and leave it in there overnight. I had to do that with the headlight on my GTO a couple of times, and it works like a champ! Like I said, not a root-cause fix, but it gets rid of the condensation that's in there.
Ultramarine 2013 Scion FR-S 6MT
| Crystal Eye tailights are in! | deedz | Cosmetic Modification (Interior/Exterior/Lighting) | 79 | 06-07-2013 03:32 PM |
| Tinted Tailights | IceCreamMan | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 27 | 05-20-2013 06:39 PM |
| Tailights tinting? | imravenit | Cosmetic Modification (Interior/Exterior/Lighting) | 17 | 04-23-2013 09:54 PM |
| Toronto FR-S orders- Drill or no Drill on bumper | Dragon86 | CANADA | 35 | 10-12-2012 02:35 PM |
| Mysterious microscopic hole | Aznek | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 2 | 07-09-2012 09:22 PM |
