Old 04-28-2013, 08:50 PM   #57
ayilar
Drives: BRZ, MB C350
Just plugged mine ( LHD US version ). "Nylon Hole Plugs 7/8 inch" ( in case the picture goes way eventually ).
When I got the plugs at the hardware store last night I ran right out and tried to install this intricate mod, but it was dark and I failed to find it.
Took a break at lunch today, dug around a little more and discovered what I think is the proper location in a bit more accessible place, just below and right of the lower center plenum bolt.
It's obscured by the top edge of the carpet and sound blanket.
The plug fits in the indicated hole, so I think I've got it for the time being. No test drive yet.
Thanks a lot for the pics and the information -- sounds (no pun intended) like a great idea, as the noise gets tiring at high rpms after a while.
Question: The hole plugs discussed here all seem to be "locking" types -- has anyone double-checked that they can be easily removed? In other words, has any of you tried to undo this simple mod (if only for a moment)?
2013 BRZ Premium MT (lightning red)
2008 MB C350 PII (steel grey)
ayilar is offline   Reply With Quote
Old 04-28-2013, 09:24 PM   #58
Laika
When In Doubt...
Laika's Avatar
Drives: Slowww
I just did this and checked how hard it was to pull back out. It's true, takes all of 10 seconds max. This is fantastic.
Join the Galaxy Blue Silica BRZ registry below:
https://docs.google.com/spreadsheet/...2c&usp=sharing
Laika is offline   Reply With Quote
The Following User Says Thank You to Laika For This Useful Post:
ayilar (05-01-2013)
Old 04-28-2013, 10:42 PM   #59
Clembo
'Senior' Junior Member
Clembo's Avatar
Drives: 13 FR-S,08 Mustang Bullitt,06 MX-5
Did it the day this was first posted, hardest part was finding the right drawer at Lowes!
Been a happy driver ever since...
"You'll never know if you don't try" - Shinroko Momose
Clembo is offline   Reply With Quote
The Following User Says Thank You to Clembo For This Useful Post:
Ben_G (05-01-2013)
Old 04-29-2013, 09:51 AM   #60
Bringiton
Bringiton's Avatar
Drives: WRB BRZ
Originally Posted by enouf View Post
I just used the plug/cover for the cigarette lighter in the glovebox - fits perfectly and spent $0. Packed the hollow end of the plug with a bit of cloth+tape to increase the sound deadening effect and now it no longer sounds like a wailing banshee.
I gave this a try and it worked beautifully.
Bringiton is offline   Reply With Quote
The Following User Says Thank You to Bringiton For This Useful Post:
enouf (04-29-2013)
Old 04-29-2013, 11:15 AM   #61
edj
edj's Avatar
Drives: 2022 Toyota GR86
The cap is easy to put on/take off. I had to remove it to put some foam
rubber in the center hole.
The threaded plug solution would be more difficult to remove. I would take
it easy removing it as the end of the sound tube is soft rubber and I am
not sure how securely it is fastened. I might be possible to tear something.
Eric
2022 Toyota GR86 Steel
edj is offline   Reply With Quote
The Following User Says Thank You to edj For This Useful Post:
ayilar (05-01-2013)
Old 04-29-2013, 11:52 AM   #62
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Drives: 2013 Asphalt FRS
Subbed for run to lowes!
tuckdaddy is offline   Reply With Quote
Old 04-29-2013, 06:32 PM   #63
BRZNutt
BRZNutt's Avatar
Drives: 2014 DGM Subaru Impreza 2.0i 5 Door
Thanks for the tip. I had removed that plug to install a JDM negative ion air cleaner in my glove box and now I have a place to stow it. I think my wife will appreciate it when she calls me in the car now. (Not sure if the air cleaner actually works, but it has an LED as well to help light up the glove box at night. Here's a pic of a similar one to mine:
2016 World Rally Blue Subaru WRX Limited
2013 Satin White Pearl Subaru BRZ Limited 6 MT (Sold)
BRZNutt is offline   Reply With Quote
The Following 3 Users Say Thank You to BRZNutt For This Useful Post:
enouf (04-29-2013), HotLeopardMama (04-29-2013), SirBrass (01-27-2014)
Old 04-29-2013, 11:17 PM   #64
Minovsky
Minovsky's Avatar
Drives: Fr-s 2013 white out
Originally Posted by P5yk0t1c View Post
Thanks to the OP for this simple fix...I can't believe the difference in somthing so simple!
I found some that fit perfectly at Canadian Tire. They were in the car section under "Panel Trim Fasteners" DORMAN is the name brand and the part number was 45092 and says "GM" in a yellow package.
I got the exact same one fits perfectly i dont know about the sound difference but HEY the hole is plugged xD
Minovsky is offline   Reply With Quote
Old 04-30-2013, 12:19 AM   #65
tuckdaddy
Because Racecar
tuckdaddy's Avatar
Got the locking one today from Home Depot. 7/8ths locking hole plug.
Found in these drawers,
Installed
I hear a noticeable difference in the higher rpm's and am happy I can hear my music better and that talking on the phone is slightly easier!
All in all best 2 bucks and 10 seconds I have spent on this car!
Old 05-02-2013, 01:19 AM   #66
AUmarvin
Anyone in Australia having trouble finding the plug. I walked around Bunnings for about an hour. Ended up finding a plug in the garden irrigation section. Its a 19mm Pope brand irrigation pipe end plug. Fits in very well, easy to pull out. Cost all of $0.50.
And as everyone has said, works well. And easily reversible.
AUmarvin is offline   Reply With Quote
The Following 2 Users Say Thank You to AUmarvin For This Useful Post:
kajun (05-16-2013), RJ_ (08-20-2013)
Old 05-06-2013, 02:36 PM   #67
ptmfr
Drives: WRB Premium
For Canadians:
I had trouble finding the Canadian Tire part or the locking plastic cap at Home Depot so I used this from Home Depot instead: http://m.homedepot.ca/product/produc...957078&lang=EN
I placed a cotton ball inside the sound tube and a ball of paper tissue inside the cap. The cap fits snugly within the soft rubber ring that surrounds the sound tube. It eliminated the fake induction sound and but there's still a fair bit of road and wind noise. It's definitely an improvement but won't suddenly make your car a Lexus.
ptmfr is offline   Reply With Quote
The Following User Says Thank You to ptmfr For This Useful Post:
val_lixembeau (11-13-2013)
Old 05-06-2013, 10:46 PM   #68
ayilar
Originally Posted by edj View Post
The cap is easy to put on/take off. (...)
Thank you! I did not realize that the Hillman plug would go around (i.e., on top of) the sound pipe hole -- I had thought that both types of plugs (Hillman and threaded) would go inside the tube, hence my worry. I like the Hillman much better -- Lowe's had them as pairs for $1.70, but the sales guys who found the drawer for me managed to find a bag that had one missing and I got it, all done, for half that price.
Evaluation: easy to put on and take off. The sound reduction is amazing -- my passenger could not believe the difference that such a small mod made. IMHO, for someone who commutes, this may well be a no-brainer. As for me, after driving my BRZ spiritedly for half an hour with the cap on, I started missing the "shrieking" of the engine above 4-5k rpm. When I go on a cross-country tour this summer, I may well put it on for days when I'll be driving a lot; for the shorter drives until then, though, I'll keep the cap off and the sound pipe unhindered.
Old 05-06-2013, 10:53 PM   #69
Burrcold
Drives: Subaru BRZ Limited
Finally found this in stock. Perfect fit, thanks!!
Old 05-07-2013, 06:06 AM   #70
notout86
Drives: GTS 86 auto
Is there anything wrong with stuffing a lump of BluTac in the hole? Can it get sucked back up the tube and cause a problem?
enouf is a damned genious, plug, sound tube, toyoburu kazoo banned.
WORK KIWAMI 18" x 9.5" + 18" x 8.5" +38 Offset GC GTS Aero Kit Australia Classifieds 16 03-22-2013 05:49 AM
Which Markets have "GT86" and "Toyota" badges on trunk? Tanuki Scion FR-S / Toyota 86 GT86 General Forum 20 02-10-2013 05:23 PM
Anyone else try running "square" tires on "staggered" wheels? hamlet Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 21 12-19-2012 12:59 PM
Switching stereo from TC to "FR-S" mode frsinpa Electronics | Audio | NAV | Infotainment 8 06-21-2012 10:48 PM
*NSFW* "Check Out My Subaru" on You Tube Axel Other Vehicles & General Automotive Discussions 4 01-17-2010 05:56 PM
