Old 04-29-2013, 06:44 PM   #43
Panman
Panman's Avatar
Drives: 86 GTS
Two reasons, one is the increase in track (So Offset+Width plays a role), the other is that in Australia the wheel cannot protrude beyond the body work (So effectively no "poke" if you define that as beyond the bodywork).
The reasons are mechanical safety (increased track increases the risk of component failure), and Pedestrian safety (Poke increases the risk of pedestrian injury).
This is Australia so we'd rather prevent you from doing something stupid, than allow you to do it then sue somebody.
Panman is offline   Reply With Quote
The Following User Says Thank You to Panman For This Useful Post:
coyote (04-29-2013)
Old 04-29-2013, 07:17 PM   #44
merlin2111
merlin2111's Avatar
Drives: Widebody '94 Miata R-Package
This is exactly what I wanted to see and it looks great. Do you have anymore pics?
I <3 my Miata.
But I <3 my new BRZ even more!
merlin2111 is offline   Reply With Quote
Old 04-29-2013, 10:51 PM   #45
Cade01
Cade01's Avatar
Drives: '13 White FR-S, 09 Triumph St.3 R
So if you were to run wide and put wider arches/flares on your car to cover the tire/wheel would it still be a no go due to insurance as well? And you have it backwards people wait for you to something stupid they they sue you..
Cade01 is offline   Reply With Quote
Old 04-30-2013, 02:45 AM   #46
WR BRZ
WR BRZ's Avatar
Drives: WRB Brz
Found some more
WR BRZ is offline   Reply With Quote
Old 04-30-2013, 06:58 AM   #47
Panman
Panman's Avatar
Drives: 86 GTS
We both know what we mean - you can't prevent stupidity.
You'd have to get the car inspected and certified before it would be legal to register it. Then you'd have to declare it to your insurance company who could still refuse to cover you.
Old 04-30-2013, 02:53 PM   #48
Cade01
Cade01's Avatar
Either way the car looks absolutely beautiful as is, thanks for humoring my questions
Old 05-01-2013, 04:27 PM   #49
Frsexxxy
Drives: White Virgin frs
Beutiful, I wish my girlfriend looked like that
Frsexxxy is offline   Reply With Quote
Old 05-03-2013, 10:19 PM   #50
merlin2111
merlin2111's Avatar
Moar!
I <3 my Miata.
Old 05-04-2013, 10:25 PM   #51
empower-auto
Kouki-Monster
empower-auto's Avatar
10's do not fit on the front anyways without a stupid hella flush setup.
I am running 18x9.5 +38 fronts with 235's and this is as aggressive as you can go without adding more negative camber (I am at -1.5) and messing with your fenders / fender liner as well
Rich Anderson
EMPOWER AUTO
empower-auto is offline   Reply With Quote
Old 05-04-2013, 10:43 PM   #52
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Drives: FRS/280z/Tundra
And you're completely uncorrect without testing it 1st hand!
Omar GC
2JZ - 6870 - stock block - 1000whp?
Instagram: 2jzus
OmarGC is offline   Reply With Quote
Old 05-06-2013, 04:30 PM   #53
empower-auto
Kouki-Monster
"incorrect" and go ahead with your counter..
a 12mm socket doesn't fit over a 20mm nut. you don't need to try it to know it
Rich Anderson
EMPOWER AUTO
Old 05-06-2013, 07:24 PM   #54
OmarGC
My FR-S has 5 gears
OmarGC's Avatar
Typo... lol ever notice your "U" and "I" key are right next to each other?
Also, I'll have pics of a square 18x10 setup that CAN be used on track days when I'm back in the country without the stupid amount of camber you have embedded in your mind.
Omar GC
Instagram: 2jzus
Old 05-06-2013, 11:44 PM   #55
Floggin Tires
Floggin Tires's Avatar
Drives: ZC6, Junk of ALL sorts
Originally Posted by WR BRZ View Post
What's your thoughts?
White Work Emotion XD9's 18X9+38 -18x10 +38
Work Center Caps
Work Racing [RC] Blue Wheel Nuts
Moar!
What they said.
# 1. Always know where your towel is.
ZC6-CBS, is home
Floggin Tires is offline   Reply With Quote
Old 05-07-2013, 12:04 AM   #56
RavenFR-S
I have to agree with you. I don't see why you could not run 10" in the front. Many people run 9.5" wide wheels and it looks fine. With the correct offset and camber settings, it should be able to be done.
On topic, the WRB and white looks gorgeous. Nice job.
RavenFR-S is offline   Reply With Quote
brz, work, wrb, xd9
Wheel Directory: Work Emotion XD9 18x9.0 +38 / 18x10.0 +38 RavSpec Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 53 05-26-2015 12:39 PM
Wheel Directory: Work Emotion XD9 18x10.0 +38 FRS8SIX Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 34 05-23-2015 12:54 AM
Wheel Directory: Work VS-XX 18x9.0 +33 / 18x10.0 +33 brunofrs Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 29 11-08-2013 01:26 AM
Wheel Directory: Work Emotion 11R 18x8.5 +45 / 18x9.5 +38 DR1FT Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 12 01-04-2013 02:16 PM
Wheel Directory: Work Emotion 11R 18x9.5 +30 autofashionfred Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 24 08-11-2012 02:39 AM
