Old 04-29-2013, 01:06 PM   #1
euroshowoff
euroshowoff's Avatar
Drives: 2015 Tacoma
Blind spot?
So I've been driving my new FRS for two days now, how do you deal with the terrible blind spot on the drivers side?
euroshowoff is offline   Reply With Quote
Old 04-29-2013, 01:09 PM   #2
lbroskee
lbroskee's Avatar
Drives: 2023 WRB BRZ (MT)
i hated it at 1st, but after a while you naturally adjust to it and it goes away (dont ask me how). i have more of an issue with the passenger side, makin lefts out of a plaza is a PITA and the other day i cut off a corvette and didnt even know it until i looked back after merging
lbroskee is offline   Reply With Quote
Old 04-29-2013, 01:11 PM   #3
Gen
Drives: Scion FR-S
I always accelerate before changing lanes to ensure I can see anything that may have been hiding in my blind spot. Properly adjusting your mirrors helps quite a bit as well.
Gen is offline   Reply With Quote
Old 04-29-2013, 01:14 PM   #4
Kelbyat07
Poor College Kid
Kelbyat07's Avatar
Drives: ~.~
The right side is easier. But when I want to make a left I have to put my face close to the window to make sure or just pay attention when your'e driving and always look back to see cars behind you so you know their not close to you.
Kelbyat07 is offline   Reply With Quote
The Following User Says Thank You to Kelbyat07 For This Useful Post:
racecat (12-27-2013)
Old 04-29-2013, 01:15 PM   #5
CBR600RR
Drives: Raven Black
if your mirrors are properly adjusted you will not have a blind spot
The Following 19 Users Say Thank You to CBR600RR For This Useful Post:
BanzaiZee (04-30-2013), CrazyWookiee (04-29-2013), dem00n (04-29-2013), Demandred7 (04-30-2013), frosty86 (04-30-2013), jmaryt (04-29-2013), kthxbai (04-29-2013), Linseal (04-29-2013), Luis_GT (12-25-2013), Marchy (04-29-2013), Mitch (04-29-2013), mottor (04-29-2013), Ocala FR-S (04-29-2013), OjiGeorge (04-29-2013), Sigh-on-Rice (04-29-2013), Slysdexia (11-25-2014), subwaynm (12-25-2013), uEih (12-25-2013), Wo6M (12-25-2013)
Old 04-29-2013, 01:16 PM   #6
coastertrav
Drives: Whiteout FRS
Just properly adjust your mirrors. Just picked up the car Saturday and one of the things I noticed immediately is that this car has amazing mirrors and no blind spot when they are adjusted properly. I'd say that most people have their mirrors adjusted to all look directly down the side of their car, but that is WRONG. If you can see any part of your car in your side mirrors they need to be adjusted much further out to see into your blind spot.
coastertrav is offline   Reply With Quote
The Following 4 Users Say Thank You to coastertrav For This Useful Post:
Demandred7 (04-30-2013), jmaryt (04-29-2013), kajun (05-01-2013), racecat (12-27-2013)
Old 04-29-2013, 01:37 PM   #7
whaap
whaap's Avatar
Drives: '13 FR-S firestorm, 6 mt - '11 CR-V
This is the most common mistake made by drivers. If you fan out your side view mirrors enough you will be able to see the car approaching you from behind. As he starts to pass you (on either side) you will see him in your side view mirror before he leaves the rear view mirror. Before he leaves the side view mirror you should see him with your peripheral vision, if not a slight head check. It will seem strange at first but try it for awhile and you will wonder why it took you so long to figure it out.
whaap is offline   Reply With Quote
The Following 6 Users Say Thank You to whaap For This Useful Post:
coastertrav (04-29-2013), Demandred7 (04-30-2013), jmaryt (04-29-2013), Marchy (04-29-2013), red_comet (07-19-2013), StRacngtC06 (12-25-2013)
Old 04-29-2013, 01:42 PM   #8
Ben_G
Drives: Blue BRZ
I've been able to do this for all my previous cars, but I still haven't found the sweet spot for the BRZ/FRS.... no matter where I set my mirrors, there's always this one spot that I can't quite get rid of....I may have to resort to one of those stick on convex mini mirror dealies..... =(
Ben_G is offline   Reply With Quote
Old 04-29-2013, 01:44 PM   #9
carbonBLUE
Reverse Burnouts
Drives: 2013 Argento FRS
Just go faster than everyone else... lamboghinis believe in this... thats why the rear view mirror is useless
2000 Carbon Blue Toyota Celica GTS 152000 miles
(wont forget you)
2013 Argento Scion FR-S
2011 Infiniti G37x
carbonBLUE is offline   Reply With Quote
Old 04-29-2013, 01:46 PM   #10
suaveflooder
They have a slightly convex polarized mirror on eBay pretty cheap. Goes right over the stock ones and i hear they work GREAT! I was playing with the idea of picking some up
suaveflooder is offline   Reply With Quote
Old 04-29-2013, 01:48 PM   #11
jstans84
Drives: Scion FR-S
I picked up a set of convex mirrors from @FT-86 SpeedFactory they basically eliminate the blind spot completely.
jstans84 is offline   Reply With Quote
Old 04-29-2013, 01:48 PM   #12
CaptainSlow
CaptainSlow's Avatar
Rexspeed convex mirrors (order from FT-86 SpeedFactory) with proper adjustment completely eliminates any blind spot. Obviously you'll still have to turn your head slightly to check, but you really should be doing that anyway.
Ultramarine 2013 Scion FR-S 6MT
CaptainSlow is offline   Reply With Quote
The Following User Says Thank You to CaptainSlow For This Useful Post:
Old 04-29-2013, 01:54 PM   #13
CrazyWookiee
Drives: Whiteout FR-S
Like a lot have said above, the mirrors adjusted properly will eliminate the blind spots. Your mirrors should be set up to have a "panoramic" view of everything behind you.
http://www.caranddriver.com/features...id-blind-spots
You shouldn't see your own car in your side view mirrors. Cars on either side of you if they are further away should be in your center rear view. As they move closer to the left and right, when they "leave" the view of your center rear view they should transition straight to one of the side mirrors. As they are traveling in your side view mirrors view, when they start "leaving" that mirror they are now right beside you out of the corner of your eye. No blind spots.
If you insist on seeing a fraction of your car in your side views, you may want to invest in some aftermarket convex mirrors, but if you set up the panoramic rear view mirrors, you shouldn't have a problem.
"I'm the real Peter Lau" - Peter Lau
CrazyWookiee is offline   Reply With Quote
The Following 3 Users Say Thank You to CrazyWookiee For This Useful Post:
red_comet (07-19-2013), Sigh-on-Rice (04-29-2013), subwaynm (12-27-2013)
Old 04-29-2013, 02:08 PM   #14
Ben_G
Drives: Blue BRZ
Thanks...thought about the replacement mirror options, but then I would lose my heated mirrors (first world problems, right).... I'm still testing different mirror locations and if for some reason I can't figure it out, I'll look at those again...
Sent from my Galaxy Nexus using Tapatalk 2
New Parking Spot raul Scion FR-S / Toyota 86 GT86 General Forum 7 09-05-2012 01:42 AM
Blind spot mirrors? enjoi23 Cosmetic Modification (Interior/Exterior/Lighting) 1 08-11-2012 03:29 AM
spot cleaning jarviz Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) 3 07-26-2012 07:12 PM
People having a hard time with the FR-S blind spot driver01 Scion FR-S / Toyota 86 GT86 General Forum 28 06-16-2012 04:27 PM
Blind Spots? Buggy51 Scion FR-S / Toyota 86 GT86 General Forum 35 10-04-2011 04:17 PM
