Old 03-05-2013, 02:33 AM   #57
Touge Monster
Touge Monster's Avatar
Drives: 85 AE86 Hatch, 92 SW20 , 13 GT86
Super clean nice work man!!
Living life one HPDE at a time
Touge Monster is offline   Reply With Quote
Old 03-05-2013, 09:40 AM   #58
sid325
Drives: Ultramarine FR-S 6MT
I used Weldbond. Dries clear and very strong, but removable if needed. I already re-did my emblem, 2nd time came out perfect.
sid325 is offline   Reply With Quote
Old 03-19-2013, 08:51 AM   #59
Kitty
Kitty's Avatar
Originally Posted by doggy View Post
Did what i wanted to do from the first day i got my FRS I aint wanted 86 airbag cuz its expensive - and to be honest - looks worse then FRS / SUbaru one - cuz logo is just pressed in instead of normal one...
Soooooooooo
I jumped to my local junkyard - and cut Toyota logo from Toyota Corolla airbab along with background. Got home - removed it from the plastic / rubber background - and found out that Scion logo is smaller then Toyota sign... Hmmmm
I removed Scion logo from airbag, and started cleaning place for the new logo background. Used my dremel with sanding head to clean out all the unesesary plastic, and to make surface clean and flat.
After sanding down scion logo background - it was time to trim down Toyota logo back cuz it was a bit too thick. So sanded it down as thin as posible to make new Toyota logo sit flush with the surface.
Sanded Toyota back as flat and thin as posible:
Once got everything even and flush - used some superglue to glue backround in place.
Once background is glued - i did the same with the Toyota logo Its sitting nice and flush now.
All the work took me like 30 min And its well worth it over buing 86 airbag
Will get better pics once i put back my interior:
Damn you should go into business
doing this..I so want this!
Kitty is offline   Reply With Quote
Old 03-19-2013, 11:20 AM   #60
DTN107
Drives: '08 Civic Si FG2
Not sure where people are getting the ideas how an airbad deploys...
But at junk yards I been too, I have only seen air bags that rip through "three" seams. They are located on the sides of the logo and on the top or bottom (Almost all times it has been on top). So in the end you get a single flap that opens either upward or downward.
If you are extremely worry, then use a little epoxy if you are too insecure or rather just don't mod at all.
Example:
http://en.wikipedia.org/wiki/File:Pe...s_deployed.jpg
DTN107 is offline   Reply With Quote
Old 03-29-2013, 05:21 PM   #61
Tim_Asphalt_FRS
Is it fast? No.
Tim_Asphalt_FRS's Avatar
Drives: 2013 Scion FR-S Manual-Asphalt
Done!
2013 (Rebadged) Toyota GT-86 {Perrin intake tube, aFe dry air filter, custom 2.5" exhaust, PLM overpipe, Kartboy crank pulley, Hotchkis springs, custom Flossy grip tape shorty, TRD shifter, Berk HFC, Whiteline Sway-bars}
[Wanted: Delicious Stg 2 tune, Bilstein struts]
Tim_Asphalt_FRS is offline   Reply With Quote
Old 03-30-2013, 12:03 AM   #62
charged86
charged86's Avatar
Originally Posted by Tim_Asphalt_FRS View Post
Attachment 32236
Done!
Awesome,! Can you buy the emblem new or did you salvage yard hunt
Old 03-30-2013, 01:30 AM   #63
Tim_Asphalt_FRS
Is it fast? No.
eBay
Old 04-03-2013, 02:29 PM   #64
kombatlion
Life to short to be slow!
kombatlion's Avatar
Drives: Toyota GT86
I want one but I am very bad with manual doing stuff,,, anyone have an extra one to buy it from you?
kombatlion is offline   Reply With Quote
Old 04-28-2013, 03:37 PM   #65
Mcdj18
Drives: Toyota FR-S
This thread covers everything except for taking off the steering wheel cover. Is it necessary to remove this piece before attempting to remove the scion emblem of can it be done without taking off the airbag??
Mcdj18 is offline   Reply With Quote
Old 04-29-2013, 03:45 PM   #66
Trojan_SC
Trojan_SC's Avatar
Drives: '14 Monogram FR-S(RIP)
Wow extremely clean install! I went with the 86 bag last year and very happy with it but this looks very impressive. Thanks for sharing for others to do the same.
Trojan_SC is offline   Reply With Quote
Old 04-29-2013, 03:46 PM   #67
Trojan_SC
Trojan_SC's Avatar
Search. There is a DIY thread on how to remove the airbag. It's actually fairly easy, only requires a flathead screwdriver and takes maybe 5 minutes max.
Old 04-18-2014, 12:31 AM   #68
Chad86
DrivinginDreams...Cloud86
Chad86's Avatar
Drives: Toyota GT86
Question
Where did you get the 86 airbag from, and how difficult was it to install
Did you get a shop to install it for you
Chad86 is offline   Reply With Quote
Old 04-18-2014, 12:33 AM   #69
Trojan_SC
Trojan_SC's Avatar
Ordered it from japan. Extremely easy to install. I posted a DIY on it in the DIY section.
Old 05-26-2014, 03:05 PM   #70
bryan767
bryan767's Avatar
Drives: 13' AVO Whiteout
Can you please measure the emblem?
I found a Toyota airbag emblem sticker on eBay that is 63mm X 41mm
http://www.auctiva.com/hostedimages/...0,0,0&format=0
Will have to cut the pegs off
bryan767 is offline   Reply With Quote
86 Airbag installed! Trojan_SC Cosmetic Modification (Interior/Exterior/Lighting) 218 02-09-2015 03:45 AM
WTB/Trade for GT 86 airbag Lawnik Interior Parts (Incl. Lighting) 0 09-30-2012 09:47 PM
How to fool airbag sensor? track_warrior Scion FR-S / Toyota 86 GT86 General Forum 3 07-12-2012 11:46 PM
Question about side airbag Nardi330 Scion FR-S / Toyota 86 GT86 General Forum 11 01-30-2012 07:02 PM
