Old 04-28-2013, 02:45 AM   #15
robispec
Drives: Black frs project
yeah for 3 days prior to failure I thought the brake rotor/pad combo was clicking who'd a thought? I me we drive it HARD but I'm pretty smooth...don't speed shift etc... started taking off "normal" and bang!
robispec is offline   Reply With Quote
Old 04-28-2013, 09:10 AM   #16
Fallen51
Drives: 2013 Scion FRS
Originally Posted by ben15r View Post
I'm running ventus rs3 245
@Fallen51 u snapped the shaft its self??
Haha yes which I cant believe.. I forgot to grab a pic before the tow truck came. It broke on the diff side right at the boot. I can grab about 2 inches of the axle before the joint.
Fallen51 is offline   Reply With Quote
Old 04-28-2013, 10:40 AM   #17
jdzumwalt
Motor Sports slut
Drives: 13 FRS, 2011 f150eco boost,
I looks to my that you may have had some grease failure. Robi did you change out the grease to something a little more high performance? How did the grease look? runny like eggs?
jdzumwalt is offline   Reply With Quote
Old 04-28-2013, 05:44 PM   #18
robispec
Grease still slick and sticky...not paste like thick...but not runny eithr...
Old 04-28-2013, 08:24 PM   #19
jdzumwalt
Motor Sports slut
Usually when that happens in the buggie stuff it's cause the grease is done. It's not looking to good for the longevity of some of the parts on these cars.
we use this it's the best.
http://www.kartek.com/Product/250/NE...se-Grease.aspx
Old 04-30-2013, 09:08 PM   #20
Shit Luck
Drives: red frs
I have yet to truely beat on my car yet, no track days or burn outs, and I have a noise occasionally when I back up then go forward. It sounded like a junk cv but I figured I was imagining it. Guess I better check it out.
Shit Luck is offline   Reply With Quote
Old 05-05-2013, 06:00 AM   #21
Xauterus
Drives: GTS 86 Galaxy Blue
Looks like the driveshaft angle is a bit severe. How much is the car lowered?
You might have to raise the diff centre.
Xauterus is offline   Reply With Quote
Old 05-07-2013, 08:04 AM   #22
ben15r
ben15r's Avatar
Drives: FBM stage 1 rebadged FRS
I am not slammed by any means, but it is about 1 1/2 inches
My brother said the car squats really hard on launch amd when I shift so I am going to stiffen the coils up and see if it does it again but DSS axles will be happening
ben15r is offline   Reply With Quote
The Following User Says Thank You to ben15r For This Useful Post:
usptwins (05-09-2013)
Old 07-22-2013, 05:15 AM   #23
JordanWho
JordanWho's Avatar
Drives: Ford Focus RS & Toyota 86 GTS
Can you share any info/threads about anyone doing this?
My 86 is set up for drifting which is also slammed with a lot of camber and I also just broke a bearing casing like in the OP.
I'm looking at the 600HP rated DSS axles but want to try and lower the diff to reduce any additional strain.
JordanWho is offline   Reply With Quote
Old 07-23-2013, 12:53 AM   #24
Xauterus
Usually it requires cutting the subframe and floor enough to raise the centre , then reinforcing and replating it all. You also have to ensure you have clearance for your tailshaft.
Why does your car need to be slammed for drifting? It is about driving isnt it? Not hard parking?
The Following User Says Thank You to Xauterus For This Useful Post:
ATL BRZ (07-24-2013)
Old 07-23-2013, 01:02 AM   #25
Dipstik-sportech
Dipstik-sportech's Avatar
This has me nervous about my track trip next weekend. I wish we had $150 used stock axles up here
Sent from my iPhone using Tapatalk 2
The Following User Says Thank You to Dipstik-sportech For This Useful Post:
JordanWho (07-23-2013)
Old 07-23-2013, 06:09 AM   #26
JordanWho
JordanWho's Avatar
Amen
Old 07-23-2013, 06:01 PM   #27
ben15r
ben15r's Avatar
I got my used axles off eBay, and have not had a problem since I put it back in all I did was stiffened the coilovers when I drag race to keep it from squatting. This axle has at least 20 passes on it
Old 07-23-2013, 06:20 PM   #28
OrbitalEllipses
Drives: Attitude
axle, broke, cv joint, drag, turbo
Toyobaru joint project, but who's manufacturing / designing what? VisciousGXR Scion FR-S / Toyota 86 GT86 General Forum 78 08-31-2014 04:28 PM
What if...Honda and Mazda joint together to come up something to compete with 86? 86BRZ FR-S / BRZ vs.... 77 02-11-2013 05:51 PM
Toyota and GM Joint Venture Dragonitti Other Vehicles & General Automotive Discussions 19 03-31-2011 03:34 PM
