Old 01-06-2013, 06:46 AM   #43
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Originally Posted by nix View Post
Anyone else fixed it yet? My dealership has given up on it, I might take the whole lot to pieces and see what I can try.
Mine is doing this too will get it mentioned to my dealer tomorrow.
along with the rear boot popping/ticking noise!
Wow not sure why i hadn't come to the recall section sooner!!
So many things i want fixed that ia m just putting up with :s
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 01-13-2013, 03:37 PM   #44
Ingen
Drives: Ultramarine FR-S 6MT
I have the same rattle.
4500 rpm and up, sounds like a nut rattling on a bolt that's loose. If I pinch the lockout mechanism (squeeze on the leather boot below the shift knob) then it stops but I have to squeeze fairly hard. I definitely considered a thin shim or something to take up the extra space.
If anyone has theirs out of the car, and has a set of feeler gauges, your input on the gap would be greatly appreciated!
Car Received: 10/18. Break in ended: 10/28
Goal: Openflash UEL headers, Stage II 93 oct, TRD intake, arm rest :P
Ingen is offline   Reply With Quote
Old 03-03-2013, 07:12 PM   #45
Ruckus
Ruckus's Avatar
Drives: Firestorm FR-S
Same rattle here... anyone come up with a fix yet?
Ruckus is offline   Reply With Quote
Old 04-22-2013, 10:32 AM   #46
theredtape
Drives: civic,vfr,BRZ
Crap. Mine is doing it now too. Took me a week to figure out what the noise was. Stupid shifter, the noise is barley noticeable but once its heard it cannot be unheard.
Every.
Damn.
Time.
I step on it and get about 3500ish rpm.
Its driving me crazy. I am going to have to take it apart on my next free day.
Because Racecar.
theredtape is offline   Reply With Quote
Old 04-23-2013, 10:19 PM   #47
ricky
Drives: Scion F-RS
Toyota has a fix for it . New shifter ... S-SB-0014-13
ricky is offline   Reply With Quote
The Following User Says Thank You to ricky For This Useful Post:
theredtape (04-24-2013)
Old 04-25-2013, 04:53 PM   #48
Fenrir
Drives: Mazdaspeed 3
Any more info on this? Can't find that TSB posted anywhere publicly, would be curious what the technical reason behind it is, as it might be something we can fix ourselves.
Fenrir is offline   Reply With Quote
Old 04-25-2013, 09:56 PM   #49
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
I have already performed this TSB on a customers car. It is a complete shifter assy. It looked no different than the one i pulled out, but sure as shit it fixed the problem and no more noise.
LavosTRD is offline   Reply With Quote
Old 04-25-2013, 10:17 PM   #50
Gords_zenith
Gords_zenith's Avatar
Drives: WRB BRZ Sport Tech
What is all included/needed for this issue? I have the shifter rattle as well. However I noticed there is a bit of play in the shifter now. Anyone else have this?
Gords_zenith is offline   Reply With Quote
Old 04-25-2013, 10:34 PM   #51
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
Go into your local dealership complaining of an audible rattle coming from the shifter above 4000 rpms.
The updated part number is SU003-04598.
the bulletin # is S-SB-0014-13.
The Following User Says Thank You to LavosTRD For This Useful Post:
nix (04-26-2013)
Old 04-25-2013, 11:15 PM   #52
Gords_zenith
Would like to, but I'm in Canada, so chances of them doing anything are slim to none. Might be something I have to do myself. Is there a way I can print of the actual American TSB for this?
Old 04-26-2013, 12:55 AM   #53
LavosTRD
Toyota Master Tech
Drives: Whiteout MT
Yeah I am not sure how things are done up there. If it doesn't seem like they are getting anyway, maybe ask them to call TAS (Technical Assistance) and have them reference the US TSB. I am honestly not even sure if Canada has this updated part either.
And if you did end up having to resort to buying it yourself, you are better off buying
This
It would probably be the same price.
The Following 3 Users Say Thank You to LavosTRD For This Useful Post:
Flasher (09-30-2013), Gords_zenith (04-27-2013), normancw (04-26-2013)
Old 04-29-2013, 12:47 PM   #54
grst1
grst1's Avatar
Drives: '94 Ford Aspire
I have exact same problem on BRZ. Drives me crazy! Hopefully there will be a TSB from Subaru soon too!
grst1 is offline   Reply With Quote
The Following User Says Thank You to grst1 For This Useful Post:
theredtape (05-01-2013)
Old 04-29-2013, 05:01 PM   #55
Fenrir
This
Had the rattle before/after the Kartboy shortshifter. Just FYI. Check here for more info.
Old 05-11-2013, 03:10 PM   #56
RevoG
RevoG's Avatar
Drives: Hot Lava 86 MT
Mine has now developed the same thing. 6500km run and now it starts. Will have to take it to the dealer for service in the next couple of weeks in any case.
JR Supercharger, JR RS Pulley, JR Oil cooler, JDL UEL header, Dual resonated 3" JDL Overpipe Front pipe, Perrin 3" resonated cat back exhaust, Upgraded Koyorad radiator, ECUTek tune, Enkei RS05RR 18x9.5, Bridgestone RE003 265/35/18, KW V3 Coilovers, Valenti sequential taillights, Kartboy short shifter kit
RevoG is offline   Reply With Quote
Flywheel Rattle? CB762 Issues | Warranty | Recalls / TSB 119 11-16-2016 10:09 PM
Vibrating shifter fix! Superhatch Issues | Warranty | Recalls / TSB 51 06-05-2016 10:56 PM
Flimsy shifter chessplaya2010 Issues | Warranty | Recalls / TSB 1 07-31-2012 01:21 PM
A/C Rattle? djliquidsteele Scion FR-S / Toyota 86 GT86 General Forum 2 06-17-2012 07:46 PM
FR-S Shifter Video xravexboix FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum 10 04-21-2012 08:20 PM
